Spindle PWM / PDM glitch
12 Jul 2023 04:15 #275254
by PedroSMS
Spindle PWM / PDM glitch was created by PedroSMS
Hi all,
I am at the beginning of a LinuxCNC setup phase. I am using a parallel port to control the motors.
I am having an issue with the Spindle speed - every few seconds (randomly) it momentarily increases speed, then comes back down. It's only very brief.
I have placed an oscilloscope onto the PWM signal, I can that the PC is generating a single extra wide pulse, which is making this happen.
It does the same if I use PDM, or vary the frequency for PWM (100, 500, 1000Hz).
Can anyone help with this issue?
Kind regards
Pedro
Kind regards
Pedro
- Thank you received: 5944
12 Jul 2023 09:55 #275269
Replied by tommylight on topic Spindle PWM / PDM glitch
Do you get latency warnings when starting LinuxCNC?
Might also be interference, use a shielded cable for PWM.
13 Jul 2023 03:54 #275313
by PedroSMS
Replied by PedroSMS on topic Spindle PWM / PDM glitch
Thank you for your reply @tommylight.
My bad - for some unknown reason, the BIOS had the PCI bus frequency at 333MHz. I've put it back to the standard 100MHz - all good now.
Where do I find the latency warnings?
Kind regards
Pedro
Kind regards
Pedro
13 Jul 2023 11:17 #275326
Depends on GUI being used, Axis shows warnings on lower right side, GmoccaPy shows them on upper right, QtPlasmaC shows them on a separate tab.
Time to create page: 0.082 seconds
