Steppers not moving, 7i96
17 Sep 2023 22:29 #281023
by Joz
Replied by Joz on topic Steppers not moving, 7i96
Update, the stepper motors seem to hold position just fine and step when given a +5V pulse from a separate power supply.
17 Sep 2023 23:38 #281026
Replied by PCW on topic Steppers not moving, 7i96
It might be that the 7I96 step output driver chips have been damaged.
A quick test is to measure the STEP+ and STEP- pin voltage to ground
1. When LinuxCNC is not running
2. When LinuxCNC is running
They should be close to 0V or close to 5V and change state
depending on whether LinuxCNC is running or not.
