How to and2 the probe input with a digital input
- Thank you received: 5945
11 Oct 2023 23:05 #282779
Replied by tommylight on topic How to and2 the probe input with a digital input
This is off the top of my head, so double checking is preferable:The names with _ on the left side can be any name you like to make it easier to follow, the name with _ on the right side must be an existing signal like "probing is active" or something like that.
loadrt and2
addf and2.0 servo period
net input_from_probe and2.0.in1 paraport.0.in-9
net input_from_something_else and2.0.in2 from_wehre_the_signal_comes
net output_signal_from_and2 and2.0.out probe-in
02 Nov 2023 11:42 #284317
by Waldemar
Replied by Waldemar on topic How to and2 the probe input with a digital input
Regarding debounce - is this info still relevant?[url=https://www.forum.linuxcnc.org/24-hal-components/32621-need-help-adding-debounce-to-probe
02 Nov 2023 12:18 #284320
From your error report, on line 5 you are trying to add something to base-thread, and base-thread does not exist on Mesa configs as there is no need for it.
Probably changing that add to servo-thread will work, although also probably should be servo-period, not servo-thread.
Debug file information:
Note: Using POSIX realtime
HAL: ERROR: thread 'base-thread' not found
./custom.hal:5: addf failed
The following user(s) said Thank You: Waldemar
- smc.collins
- Thank you received: 109
02 Nov 2023 13:06 - 02 Nov 2023 13:07 #284325
by smc.collins
Replied by smc.collins on topic How to and2 the probe input with a digital input
I'll post up my hal component this weekend for tool measuring and probing etc. It has a spindle enabled block function, i also have a bouncy switch probe.
Last edit: 02 Nov 2023 13:07 by smc.collins.
03 Nov 2023 16:22 #284471
by Waldemar
Cheers Tommy - servo-thread worked:
Just repeating the probing op, so far so good.
Thanks again.
Wal.
loadrt debounce cfg=1
addf debounce.0 servo-thread
setp debounce.0.delay 100
unlinkp motion.probe-input
net probe-in debounce.0.0.in
net probe-filt debounce.0.0.out => motion.probe-input
Thanks again.
Wal.
03 Nov 2023 16:25 #284472
Glad you got it working and thank you for reporting back.
Time to create page: 0.234 seconds
