- Configuring LinuxCNC
- Basic Configuration
- Joint2 following error, during homing switch reports on, 7i97
14 Oct 2023 18:42 #283005
Replied by PCW on topic Joint2 following error, during homing switch reports on, 7i97
The key thing here is that gpio.008.in is not a limit switch input
but a pin that reflects the state of PWM enable.
[HMOT](CARD0).inmux.00.input-08 is the actual limit switch input
The state of gpio.008.in will change because a following error will disable
the analog outputs (turning the 7I97 enable outputs off and setting the analog voltage to 0)
- smc.collins
- Thank you received: 109
17 Oct 2023 00:32 #283146
by smc.collins
Replied by smc.collins on topic Joint2 following error, during homing switch reports on, 7i97
yeah, I realized that after I did more digging around. GPIO " traditionally" stands for.
General purpose input output.
the pin naming on the card is a mess. Do you need help cleaning this up ?
Time to create page: 0.133 seconds
