Help to understand Net command
13 Oct 2023 10:56 - 13 Oct 2023 10:56 #282886
by karnalta
Help to understand Net command was created by karnalta
Hello all,
I am sorry to ask this, I know there is help file about it but I cannot get my mind around the net command...
Here is a working line from my HAL file :
net max-home-x joint.0.home-sw-in joint.0.pos-lim-sw-in <= hm2_7i96s.0.inm.00.input-00-not
max-home-x is the signal name and "<=" is unused, it's just for readability. That's easy to understand.
But what I am not sure about is how the command set what is output and what is input.
From that line, I guest "max-home-x" signal is outputted to "joint.0.home-sw-in" and "joint.0.pos-lim-sw-in" and get his value (input) from "hm2_7i96s.0.inm.00.input-00-not".
So how does it work ? The last parameter is always the input ?
What it does if I just set :
net max-home-x hm2_7i96s.0.inm.00.input-00-not
or
Thank a lot for your help.
or
Last edit: 13 Oct 2023 10:56 by karnalta.
13 Oct 2023 14:53 - 13 Oct 2023 14:54 #282894
Replied by PCW on topic Help to understand Net command
On a net command the order of pins is unimportant:
net signal pin pin pin pin
The inputs and outputs are handled automatically.
With one exception, you can only have one output pin
connected to a signal. The exception is tri-state pins
Note that hm2_7i96s.0.inm.00.input-00-not is an output,
that is, it provides data to hal.
joint.0.home-sw-in and joint.0.pos-lim-sw-in are input
pins as they accept data from hal.
Last edit: 13 Oct 2023 14:54 by PCW.
The following user(s) said Thank You: tommylight, karnalta
13 Oct 2023 18:37 #282925
by beefy
Replied by beefy on topic Help to understand Net command
Think of "net" as a command stating "make a group of connected signals".
Think of "max-home-x" as "the name of this group"
Anything after that are the signals which are all connected to each other, e.g.
joint.0.home-sw-in
And as PCW explained, the order has nothing to do with whether they are input or output. That is unique to each signal and can be found in the docs (documentation).
Example joint.0.home-sw-in is part of the "motion" module.
Go to the docs main page:
linuxcnc.org/docs/
Select your Linuxcnc release and html:
linuxcnc.org/docs/2.9/html/
Scroll down the page to the heading "Man Pages", and then click on "motion"
linuxcnc.org/docs/2.9/html/man/man9/motion.9.html
In that document you'll find:
joint.N.home-sw-in IN BIT Should be driven TRUE if the home switch for this joint is closed.
That tells you the signal is an input (IN) and it's a bit type (BIT).
Also you don't have to have all the signals written on the same line, so this:
is the same as this:
net max-home-x joint.0.pos-lim-sw-in
And you don't even have to have those lines all together. They could each be 20 lines apart.
Look for Youtube videos by Swolebro and the Feral Engineer for some good teaching on hal.
joint.0.home-sw-in
linuxcnc.org/docs/
13 Oct 2023 18:42 #282927
by JPL
If you write both lines, one after the other:
The first line will create or use the net 'max-home-x' and connect it to 'hm2_7i96s.0.inm.00.input-00-not'.
Think of it as a wire that is connected on one side to something.
Then the second line will 'connect' the same 'wire' to 'joint.0.home-sw-in joint.0.pos-lim-sw-in'.
Effectively connecting it to 'hm2_7i96s.0.inm.00.input-00-not'
Those two lines are then the equivalent of:
Which is also the same as
net max-home-x hm2_7i96s.0.inm.00.input-00-not => joint.0.home-sw-in joint.0.pos-lim-sw-in
You can then connect pins together via a net, one at a time or all of the on the same line (net signal pin pin pin pin...). Results will be the same.
Replied by JPL on topic Help to understand Net command
To elaborate on what PCW wrote...So how does it work ? The last parameter is always the input ?
or
The following user(s) said Thank You: karnalta
13 Oct 2023 18:49 #282929
by JPL
... Was writing my answer at the same time as you
Here is a link to the first video of a series of five from Feral engineer:
- Thank you received: 5944
13 Oct 2023 19:03 #282930
Replied by tommylight on topic Help to understand Net command
@JPL
@Beefy
Thank you for everything you do on this forum.
@Beefy
13 Oct 2023 19:24 #282934
by karnalta
Replied by karnalta on topic Help to understand Net command
Thank you all for all the information.
Make more sense that order as no impact on net command, I do understand better now.
I also have reverse my thinking about input/output, "we are" the mesa card, so an output is data going from the card to the HAL.
So, if a signal has to turn on "output pin" on the mesa controller, we are talking about an INPUT for the net command ? And it can have an unlimited amount of input ?
Only one board's pin can set value for a net signal but a net signal can turn on an unlimited amount of board pin/switch ?
One last thing, how does LinuxCNC recognize which pin is the output in a sequence of pin pin pin ... All boards definitions pins are hardcoded inside LinuxCNC ?
13 Oct 2023 21:57 #282944
Yes, one hal output pin can connect to any number of hal input pins
(well the number is limited only by the limit to the maximum number of pins)
As far as recognizing pin types, this is done when the hal file is parsed
Each hal pin has a type attribute and a direction attribute that the parser
can access so the proper data direction is established.
You can list these directions with halcmd:
For example to list all pins:
halcmd show pin
(typed in a terminal when linuxCNC is running)
To just list Mesa hardware pins:
halcmd show pin hm2
Here's a small sample:
cut
35 bit IN FALSE hm2_7i96s.0.outm.00.out-05
35 bit OUT FALSE hm2_7i96s.0.packet-error
35 bit OUT FALSE hm2_7i96s.0.packet-error-exceeded
35 s32 OUT 0 hm2_7i96s.0.packet-error-level
35 u32 I/O 0x00000000 hm2_7i96s.0.packet-error-total
35 bit IN FALSE hm2_7i96s.0.pwmgen.00.enable
35 float IN 0 hm2_7i96s.0.pwmgen.00.value
35 s32 OUT 0 hm2_7i96s.0.read-request.time
cut
Notice that there are different data types (bit, float,u32,s32)
and different directions (IN,OUT,I/O)
halcmd show pin
halcmd show pin hm2
cut
cut
14 Oct 2023 01:01 #282952
Maybe this makes it easier:
net this_is_my_signal_name => machine-is-enabled
net this_is_my_signal_name => hm2_7i96s.0.outm.00.out-05
That is the same as
net this_is_my_signal_name => machine-is-enabled => hm2_7i96s.0.outm.00.out-05
net <= think of it as a plug, so you are inserting wires "machine-is-enabled" and "hm2_7i96s.0.outm.00.out-05" into it and naming that plug "this_is_my_signal_name".
That is the same as
14 Oct 2023 10:41 #282979
by karnalta
Things are way more clear now, thank you.
I hope this post will help others LinuxCNC newbies
Time to create page: 0.181 seconds
