Spindle PID control not woring
- Bassblaster
11 Dec 2023 17:06 #287867
by Bassblaster
Spindle PID control not woring was created by Bassblaster
Hello community,
there is a problem on my Lathe, where I am not able to get the PID closed loop spindle speed control to work. I think something is messed up in my hal file, because whatever PID values I change in the .ini file, there is no change in the spindle behaviour. I used the Pncconf to get a basic hal and ini. The encoder works and when I command a speed of 1500rpm, it shows around 1900rpm when I check out the hal inspector. Somehow the loop is not closed? Maybe the feedback is somehow not connected? I attached my .HAL and .ini file, maybe somebody can spot the error? I tried to find it, using different halfiles from other people, but no luck so far. I am a beginner, so thank you in advance!
11 Dec 2023 17:41 #287871
Replied by PCW on topic Spindle PID control not woring
The PID has been bypassed with this net command:
net spindle-vel-cmd-rpm-abs => hm2_7i96.0.pwmgen.00.value
- Bassblaster
13 Dec 2023 16:36 #288054
by Bassblaster
Replied by Bassblaster on topic Spindle PID control not woring
Thank you for your answer. I suppose there must be some variable instead of net spindle-vel-cmd-rpm-abs which is not the commanded speed but rather the speed after scale and PID? I tried:
net spindle-speed-abs => hm2_7i96.0.pwmgen.00.value
But that didn't work out, the VfD did not get any signal. Is my thought process correct? Is there another variable which contains my desired speed with the PID feedback?
13 Dec 2023 18:16 #288061
Currently the PID output pid.s.output is routed through a scale component
to the spindle-output signal. I have no idea if this is desired or
correct but that is currently where the PID output is routed:
net spindle-pid-out pid.s.output => scale.gear.in
net gear-ratio ratio_select.out-f => scale.gear.gain
setp ratio_select.in00 0.000667
setp ratio_select.in01 0.000167
net gear-select-a => ratio_select.sel0
net spindle-output <= scale.gear.out
If this is correct, you would need to connect the PWM value pin to
spindle-output
spindle-output
13 Dec 2023 21:06 - 13 Dec 2023 21:10 #288076
by Mecanix
Replied by Mecanix on topic Spindle PID control not woring
*.HAL
loadrt [KINS]KINEMATICS
loadrt abs count=1
loadrt scale count=1
loadrt near
loadrt pid num_chan=1
loadrt sum2 count=1
addf [HMOT](CARD0).read servo-thread
addf abs.0 servo-thread
addf scale.0 servo-thread
addf near.0 servo-thread
addf pid.0.do-pid-calcs servo-thread
addf sum2.0 servo-thread
addf [HMOT](CARD0).write servo-thread
# --- SPINDLE-CW ---
net spindle-cw => [HMOT](CARD0).ssr.00.out-01
# --- SPINDLE-CCW ---
net spindle-ccw => [HMOT](CARD0).ssr.00.out-02
### PWM SPINDLE (CLOSED LOOP)
setp pid.0.Pgain 0
setp pid.0.Igain 2
setp pid.0.Dgain 0
setp pid.0.FF0 0
setp pid.0.FF1 0
setp pid.0.bias 0
setp pid.0.deadband 5
setp pid.0.maxerrorI 100
setp pid.0.maxerror 0
setp pid.0.maxoutput 2000
setp pid.0.error-previous-target true
net spindle-cmd-rpm => hm2_7i96.0.pwmgen.00.value
net spindle-on <= spindle.0.on => hm2_7i96.0.pwmgen.00.enable => pid.0.enable
setp hm2_7i96.0.pwmgen.00.scale [SPINDLE_0]MAX_OUTPUT
net spindle-cmd-rpm <= sum2.0.out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
setp [HMOT](CARD0).encoder.00.position-scale [SPINDLE_0]ENCODER_SCALE
setp [HMOT](CARD0).encoder.00.x4-mode 1
setp scale.0.gain 60
net spindle-position [HMOT](CARD0).encoder.00.position => spindle.0.revs
net spindle-velocity-feedback-rps [HMOT](CARD0).encoder.00.velocity => scale.0.in
net spindle-index-enable [HMOT](CARD0).encoder.00.index-enable <=> spindle.0.index-enable
net pid_feedback pid.0.feedback <= spindle.0.speed-in <= scale.0.out
net pid_command pid.0.command <= spindle.0.speed-out => sum2.0.in0
net pid_output pid.0.output => sum2.0.in1
setp near.0.scale 1.1
net spindle-cmd-rps => near.0.in1
net spindle-velocity-feedback-rps => near.0.in2
net spindle-at-speed <= near.0.out
pyvcp_option.hal
net pid_feedback pyvcp.spindle-speed
net spindle-at-speed => pyvcp.spindle-at-speed-led
loadrt abs count=1
loadrt near
loadrt sum2 count=1
setp pid.0.Pgain 0
setp pid.0.Igain 2
setp pid.0.Dgain 0
setp pid.0.FF0 0
setp pid.0.FF1 0
setp pid.0.bias 0
pyvcp_option.hal
Last edit: 13 Dec 2023 21:10 by Mecanix.
- Bassblaster
28 Dec 2023 17:07 - 28 Dec 2023 17:09 #289266
by Bassblaster
As of today, I got the spindle control working by modifiing:
- Instead of the scale factors 0.0000..., I used 1, effectively bypassing the gear, then the pindle spun up using:
- net spindle-output => hm2_7i96.0.pwmgen.00.value
- The feedback from the encoder was not used, so I used:
- net spindle-vel-fb-rpm <= hm2_7i96.0.encoder.00.velocity-rpm
- then I replaced the spindle-vel-fb-rps everywhere in the .hal file to spindle-vel-fb-rpm
- I had to replace net spindle-vel-cmd-rpm-abs => pid.s.feedback so that net spindle-vel-cmd-rpm => pid.s.feedback, so that reverse also works
However, I am now faving a new problem, where when I use e,g, G95 G96 D1500 S200 F0.04 I would expect a feedrate of 0.04mm per revoliution. However, the feedrate is approximately 60 times faster than I am commanding. I am not quiet sure how this is possible... everything should be in rpm...
I attachedmy current .hal and .ini files.Anybody got an idea as to what the error could be?
Last edit: 28 Dec 2023 17:09 by Bassblaster.
- Thank you received: 5934
28 Dec 2023 19:19 #289274
Replied by tommylight on topic Spindle PID control not woring
spammer booted.
Time to create page: 0.098 seconds
