Converting old config file
- Thank you received: 5935
17 Feb 2024 16:28 #293634
Replied by tommylight on topic Converting old config file
Is the parallel port on the motherboard or is it an add on card?
If built in, go into BIOS and find where the parallel port address can be changed to 378.
If add on
sudo lspci -v | grep parallel
If add on
18 Feb 2024 08:02 #293670
by Anthony H
Replied by Anthony H on topic Converting old config file
lspci -v says card is a serial device, I have a disk of assorted drivers with the card which would require identifying chipsets and drivers, I have started a new thread asking for recommendations for a PCI printer card that works out of the box.
Time to create page: 0.061 seconds
