Plasma machine setup with Proma SD
- Thank you received: 5951
25 Jul 2016 12:22 #77973
Replied by tommylight on topic Plasma machine setup with Proma SD
403
Forbidden
Access to this resource on the server is denied!
It should work, just take care of proper grounding and shielding.
As for the macro, install Inkscape, install gcode tools, there you already have a macro for plasma use with Linuxcnc.
I use that on all the plasma machines.
Regards,
Tom
Forbidden
Regards,
Tom
The following user(s) said Thank You: stan
25 Jul 2016 12:57 #77982
by stan
Replied by stan on topic Plasma machine setup with Proma SD
Thank you. Because is a cheap plasma cutter and the arc doesn't start as it's supposed, a wire from tip of the torch to material was added. This is highly risky and should be avoided by newbies. Now works nice.
01 Aug 2016 17:32 #78245
by stan
Hello all,
I used this M3 macro:
Offset = 1
PierceHeight = 2
FeedCurrent = GetOemDRO(818) 'Get the current settings
Dim numar As Double
numar = GetOEMDro(186)
Code"G31 Z-100 F400"
While Ismoving()
Wend
Code"G92 Z0"
Code"G0 Z" & Offset 'Switch offset, merge la Z 1
While Ismoving()
Wend
Code"G92 Z0.000"
While Ismoving()
Wend
Code" G0 Z" & PierceHeight 'Pierce Height
While Ismoving()
Wend
SetOEMDro(186,numar)
'While Ismoving()
'Wend
DoSpinCW()
'Code "F1500"
Code "F" &FeedCurrent 'restore starting feed rate
Offset = 1
PierceHeight = 2
Dim numar As Double
While Ismoving()
Wend
Code"G92 Z0"
While Ismoving()
Wend
Code"G92 Z0.000"
While Ismoving()
Wend
While Ismoving()
Wend
'While Ismoving()
'Wend
DoSpinCW()
'Code "F1500"
13 Aug 2016 10:51 #78701
by stan
Now we will try Proma SD with Hypertherm 45.
Time to create page: 0.123 seconds
