- Other Stuff
- User Exchange
- Trying to avoid learning by asking if someone can be paid (very little) to help
30 May 2019 19:59 #135419
by rudy
What I want to do is put the image of a buffalo in 3d on a panel that's 84" high and 118" wide. It will actually consist of 6 doors fitted tightly together (they pop out 2" when pushed in, then open on hinges). I have not determined the type of wood - test doors made from solid hickory, poplar, and hemlock are currently hanging to see how much they warp. Test doors are about 3/4" inch. real ones can be thicker. I have a friend who has a 22" wide CNC router who can do the cutting (don't know right now what machine he has, will find out). I have collected some candidate buffalo pictures from the web but have absolutely no artistic sense and would like to avoid the rather steep learning curve between knowing nothing and being able to do at least a half decent job of creating the gcode needed.
Is anyone interested in helping out? if so, please contact me rudy at winface.com
31 May 2019 09:07 #135452
by pl7i92
31 May 2019 13:16 #135465
by rudy
Replied by rudy on topic Trying to avoid learning by asking if someone can be paid (very little) to help
Wow!
Your buffalo is pretty much exactly what I have in mind - guess that's a "plate 3d sculpt"?
I don't know how big yours is, (particularly in terms of depth) or how scalable the gcode is but that image exemplifies the idea.
Now.. the wall this is going on is 118" (nearly 3M) wide by 90" (about 2.25M) from carpet to ceiling so net about 118 x 82 seems likely. My big issue, other than the gcode, is ensuring that the wood doesn't warp or expand/contract and that will be affected by the depth needed for the image. So, for this to work, how thick do you need the wood to be?
31 May 2019 15:14 #135475
by pl7i92
Replied by pl7i92 on topic Trying to avoid learning by asking if someone can be paid (very little) to help
this is all scalable in all axis
Primary wood be to know what your friend can do
the toolsize BALL Cutter
the mashine Rough capability (( ok Feeds can be Changed )))
BUT nit the steps
IS Your friend able to get a G-code from a STL file i guess YES as he ownes a mashine
I will do a Gcode on your Request of the TOP tread
BUT nit the steps
31 May 2019 15:48 #135479
by rudy
I have asked Euan for details on his machine. I know he can handle up to 22" in width and can feed whatever length is needed. He has many different cutters, and we can get anything needed.
What thickness should the wood be?
(Ich spreche oder schreibe kein Deutsch, kann es aber gut genug lesen, um zurechtzukommen - insbesondere mit Hilfe von Google Translate. Bitte verwenden Sie Deutsch, wenn es Ihnen leichter fällt.)
31 May 2019 18:30 #135495
by pl7i92
31 May 2019 19:56 #135499
by rudy
Thank you!
I should find out about machine options and scale during the next week or so and will get back to you (via this site) as soon as I have the info.
01 Jun 2019 00:08 #135514
Replied by andypugh on topic Trying to avoid learning by asking if someone can be paid (very little) to help
If the router in question runs LinuxCNC then you can just open the JPEG file in Axis.
That will automatically run the image-to-G-code application.
01 Jun 2019 08:18 #135549
by pl7i92
the image is to Dark for details
Tryed it
Tryed it
11 Jun 2019 07:42 - 11 Jun 2019 07:43 #136562
by pl7i92
Last edit: 11 Jun 2019 07:43 by pl7i92.
- Other Stuff
- User Exchange
Time to create page: 0.582 seconds
