Need a programmer for help with custom machine/interface
07 Jul 2019 06:58 #138775
by pl7i92
Replied by pl7i92 on topic Need a programmer for help with custom machine/interface
hi
is this designed to get a GBRL output shield
or special output to a CAD/Cam system related Windows PC
07 Jul 2019 15:03 - 07 Jul 2019 15:04 #138800
by blazini36
Replied by blazini36 on topic Need a programmer for help with custom machine/interface
I'm not sure what you mean I don't know anything about grbl.
The photo I attached above is a daughter card I made for the DE10-Nano. The DE10-Nano is an "SOC-FPGA" dev board which means it has an FPGA chip that has ARM processor cores built into the chip. Machinekit is a fork of LinuxCNC geared towards this type of thing. The daughtercard just takes all of the GPIO pins and makes them usable for interfacing with a machine, like a Mesa card. The Machinekit guys have done some work with the Xylinx SOC-FPGA's too
If I had to make an analogy to what it all looks like in typical LinuxCNC style setup.....
Maachinekit=LinuxCNC
DE10-Nano = Computer+Mesa 5i25
Daughter card = whatever the daughtercard is designed to do, maybe like a 7i76 or something. The only things I know of that are currently out there are a DB25 adapter and an adapter PCB to use with a CRAMPS board
Or maybe compare it to a Beagle bone black with a cape attached, but the IO is a bit more serious since it's FPGA driven.
Last edit: 07 Jul 2019 15:04 by blazini36.
