Retrofitted Hardinge CHNC Lathe
- jsflanagan
01 Dec 2020 01:53 - 01 Dec 2020 01:59 #190733
by jsflanagan
Retrofitted Hardinge CHNC Lathe was created by jsflanagan
Hardinge CHNC Lathe for sale. 8 station turret, 16c collet. 12" of Z travel. Machine had been running until the spindle drive went out. The rest of the machine functions perfectly. I don't use the machine enough to bother to fix it and want the space back in my workshop. The spindle drive can be repaired, motor swapped to an AC motor and VFD or I have a DC motor drive that could be hooked up to it. 16C collets and tool holders to go with the machine. I also have an 8" power chuck to go along with the lathe.
The conversion was done using a pair of 7i43's with the following adapter boards:
7i49 resolver interface
7i37 I/O
7i33 servo interface
2nd 7i37 for additional I/O
$1500 The lathe is located in Greenville, SC. Delivery is available.
-Scott
7i37 I/O
-Scott
Last edit: 01 Dec 2020 01:59 by jsflanagan.
The following user(s) said Thank You: biqut2
- Thank you received: 5949
12 Dec 2020 17:17 #191744
Replied by tommylight on topic Retrofitted Hardinge CHNC Lathe
Nice machine, to bad i am to far from everything.
And the price seems very low.
26 Feb 2021 01:56 #200168
by biqut2
Replied by biqut2 on topic Retrofitted Hardinge CHNC Lathe
I'm interested if you still have it. Get back with me This email address is being protected from spambots. You need JavaScript enabled to view it. or 2052343445.
27 Feb 2021 21:34 #200351
by Art
Replied by Art on topic Retrofitted Hardinge CHNC Lathe
Hi, do you still have the Allen-Bradley 7300 controller? Could have also been a different original controller. I'd be interested.
Time to create page: 0.306 seconds
