Create CNC process function and CNC process plan:
22 Nov 2022 08:32 #257308
by jingwang
Create CNC process function and CNC process plan: was created by jingwang
(1)CNC process considers the process of machining parts, clamping and positioning of machining parts, tool selection, process route, cutting method and process parameters that can be simplified in conventional process.
(2)cnc machining process design is mainly used to guide cnc programming. Our company combines the responsibilities of CNC technicians and programmers, and the programmers are responsible for the CNC machining process of the whole mold, which improves the work efficiency.
(3)CNC processing has a high degree of automation and many influencing factors. Quality and safety itself is very important in CNC processing and must be guaranteed.
(4) The establishment of cnc machining process should have strict rationality of strip steel. CNC process is complex, and there are many influencing factors. We need to think deeply about the whole process of CNC processing, and have good strip rationality, in order to carry out good programming on CNC process. Due to the high degree of automation of CNC processing, poor adaptability, when there is a problem, the staff is difficult to correct, light manufacturing processing defects, safety accidents occur on the way, so we must systematically design CNC process in advance.
(5) The inheritance of CNC numerical control technology is good. Proved to be a good CNC process in production, templates can be made, saved as files, and called when machining similar parts in the future, saving time and ensuring quality.
- Thank you received: 5948
22 Nov 2022 19:49 #257365
Replied by tommylight on topic Create CNC process function and CNC process plan:
The above post is considered spam, but it is related to cnc machining, cnc turning service in china.
The post originated from USA, but with the proliferation of proxy servers, VPN, and TOR, there is no easy way of confirming.
Would be nice if members would voice their mind if this should be deleted or left.
So far we are 2 abstinent and one pro deletion.
22 Nov 2022 23:48 #257406
by phillc54
Replied by phillc54 on topic Create CNC process function and CNC process plan:
I think quite a few folk here have a CNC turning service so I don't see the need for these type of posts.
23 Nov 2022 06:08 #257428
by spumco
Replied by spumco on topic Create CNC process function and CNC process plan:
+1 delete
23 Nov 2022 20:52 #257509
by sirop
Replied by sirop on topic Create CNC process function and CNC process plan:
+1 delete
23 Nov 2022 21:06 #257511
by piflixe
Replied by piflixe on topic Create CNC process function and CNC process plan:
+1 delete
25 Nov 2022 11:17 #257610
5 are pro, none against deleting this topic.
This topic will be deleted later.
Thank you for voting.
Time to create page: 0.152 seconds
