emc2 will stop with an error when 1st run
- anleu1
- Topic Author
- Visitor
29 Oct 2009 17:35 #1060
by anleu1
emc2 will stop with an error when 1st run was created by anleu1
hello all
I'm new to Linux and Emc2,
I just installed (not running from CD) 8.04 hardy with EMC2 iso image downloaded from linuxcnc.org
when I run emc from the applications menu, I get to choose I sim package but then I get this message:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=emcsh
EMC2_IOSH=iosh
EMC2 - 2.3.0
Machine configuration directory is '/home/antonio/emc2/configs/sim'
Machine configuration file is 'axis.ini'
INIFILE=/home/antonio/emc2/configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=5374
Cleanup done
Kernel message information:
[ 0.000000] Linux version 2.6.24-16-rtai (root@hardy) (gcc version 4.2.3 (Ubuntu 4.2.3-2ubuntu7)) #1 Tue Sep 30 22:54:33 EEST 2008 (Ubuntu 2.6.24-12.22-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] 127MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 262128) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 262128
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 262128
[ 0.000000] On node 0 totalpages: 262128
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 255 pages used for memmap
[ 0.000000] HighMem zone: 32497 pages, LIFO batch:7
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI 2.3 present.
[ 0.000000] Allocating PCI resources starting at 50000000 (gap: 40000000:bec00000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260081
[ 0.000000] Kernel command line: root=UUID=140effd2-f418-4520-9ee4-42efe3b10a79 ro quiet splash
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Detected 2210.765 MHz processor.
[ 23.799570] I-pipe 2.0-04: pipeline enabled.
[ 23.799576] spurious 8259A interrupt: IRQ7.
[ 23.801316] Console: colour VGA+ 80x25
[ 23.801320] console [tty0] enabled
[ 23.801924] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 23.802473] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 23.822330] Memory: 1029132k/1048512k available (1440k kernel code, 18568k reserved, 573k data, 228k init, 131008k highmem)
[ 23.822338] virtual kernel memory layout:
[ 23.822339] fixmap : 0xfffed000 - 0xfffff000 ( 72 kB)
[ 23.822341] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 23.822342] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 23.822343] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 23.822344] .init : 0xc02fa000 - 0xc0333000 ( 228 kB)
[ 23.822345] .data : 0xc026836d - 0xc02f77ec ( 573 kB)
[ 23.822347] .text : 0xc0100000 - 0xc026836d (1440 kB)
[ 23.822350] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 23.822393] SLUB: Genslabs=11, HWalign=64, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
[ 23.902382] Calibrating delay using timer specific routine.. 4422.82 BogoMIPS (lpj=8845643)
[ 23.902412] Security Framework initialized
[ 23.902419] SELinux: Disabled at boot.
[ 23.902432] AppArmor: AppArmor initialized
[ 23.902436] Failure registering capabilities with primary security module.
[ 23.902442] Mount-cache hash table entries: 512
[ 23.902562] CPU: After generic identify, caps: 078bfbff e3d3fbff 00000000 00000000 00000001 00000000 00000001 00000000
[ 23.902568] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 23.902571] CPU: L2 Cache: 512K (64 bytes/line)
[ 23.902573] CPU: After all inits, caps: 078bfbff e3d3fbff 00000000 00000410 00000001 00000000 00000001 00000000
[ 23.902583] Compat vDSO mapped to ffffe000.
[ 23.902593] CPU: AMD Athlon(tm) 64 Processor 3500+ stepping 02
[ 23.902598] Checking 'hlt' instruction... OK.
[ 23.918522] Freeing SMP alternatives: 0k freed
[ 23.918695] net_namespace: 64 bytes
[ 23.919038] NET: Registered protocol family 16
[ 23.919169] EISA bus registered
[ 23.948312] PCI: PCI BIOS revision 2.10 entry at 0xfb060, last bus=2
[ 23.948314] PCI: Using configuration type 1
[ 23.948316] Setting up standard PCI resources
[ 23.951616] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 23.951772] PCI: Probing PCI hardware
[ 23.951777] PCI: Probing PCI hardware (bus 00)
[ 23.952890] PCI: Using IRQ router default [10de/00e1] at 0000:00:00.0
[ 23.990410] AppArmor: AppArmor Filesystem Enabled
[ 23.990646] PCI: Bridge: 0000:00:0b.0
[ 23.990647] IO window: disabled.
[ 23.990651] MEM window: f2000000-f3ffffff
[ 23.990654] PREFETCH window: e0000000-efffffff
[ 23.990658] PCI: Bridge: 0000:00:0e.0
[ 23.990660] IO window: 9000-afff
[ 23.990662] MEM window: f4000000-f4ffffff
[ 23.990664] PREFETCH window: disabled.
[ 23.990673] PCI: Setting latency timer of device 0000:00:0e.0 to 64
[ 23.990681] NET: Registered protocol family 2
[ 23.994350] Time: tsc clocksource has been installed.
[ 24.026383] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 24.026662] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 24.027942] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[ 24.028292] TCP: Hash tables configured (established 131072 bind 65536)
[ 24.028295] TCP reno registered
[ 24.038480] checking if image is initramfs... it is
[ 24.531095] Freeing initrd memory: 6869k freed
[ 24.531476] audit: initializing netlink socket (disabled)
[ 24.531490] audit(1256836650.712:1): initialized
[ 24.531604] highmem bounce pool size: 64 pages
[ 24.532777] VFS: Disk quotas dquot_6.5.1
[ 24.532799] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 24.532897] io scheduler noop registered
[ 24.532899] io scheduler anticipatory registered
[ 24.532900] io scheduler deadline registered
[ 24.532908] io scheduler cfq registered (default)
[ 24.532935] Boot video device is 0000:01:00.0
[ 24.533091] isapnp: Scanning for PnP cards...
[ 24.886474] isapnp: No Plug & Play device found
[ 24.906699] Real Time Clock Driver v1.12ac
[ 24.906702] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 24.906797] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 24.907448] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 24.907511] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 24.907590] PNP: No PS/2 controller found. Probing ports directly.
[ 24.910236] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 24.910240] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 24.918097] mice: PS/2 mouse device common for all mice
[ 24.918172] EISA: Probing bus 0 at eisa.0
[ 24.918179] Cannot allocate resource for EISA slot 1
[ 24.918181] Cannot allocate resource for EISA slot 2
[ 24.918192] EISA: Detected 0 cards.
[ 24.918273] NET: Registered protocol family 1
[ 24.918280] Using IPI Shortcut mode
[ 24.918371] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 24.918373] EDD information not available.
[ 24.918631] Freeing unused kernel memory: 228k freed
[ 24.954041] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 26.122885] fuse init (API version 7.9)
[ 26.291884] usbcore: registered new interface driver usbfs
[ 26.291903] usbcore: registered new interface driver hub
[ 26.305594] usbcore: registered new device driver usb
[ 26.306274] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 26.306305] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 26.306308] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 26.306573] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
[ 26.306585] ohci_hcd 0000:00:02.0: irq 11, io mem 0xf5002000
[ 26.340829] SCSI subsystem initialized
[ 26.363654] usb usb1: configuration #1 chosen from 1 choice
[ 26.363674] hub 1-0:1.0: USB hub found
[ 26.363680] hub 1-0:1.0: 4 ports detected
[ 26.372853] 8139too Fast Ethernet driver 0.9.28
[ 26.373141] libata version 3.00 loaded.
[ 26.465591] PCI: Setting latency timer of device 0000:00:02.1 to 64
[ 26.465595] ohci_hcd 0000:00:02.1: OHCI Host Controller
[ 26.465614] ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
[ 26.465625] ohci_hcd 0000:00:02.1: irq 11, io mem 0xf5003000
[ 26.523549] usb usb2: configuration #1 chosen from 1 choice
[ 26.523571] hub 2-0:1.0: USB hub found
[ 26.523578] hub 2-0:1.0: 4 ports detected
[ 26.625618] PCI: Setting latency timer of device 0000:00:02.2 to 64
[ 26.625623] ehci_hcd 0000:00:02.2: EHCI Host Controller
[ 26.625643] ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 3
[ 26.625674] ehci_hcd 0000:00:02.2: debug port 1
[ 26.625677] PCI: cache line size of 64 is not supported by device 0000:00:02.2
[ 26.625683] ehci_hcd 0000:00:02.2: irq 11, io mem 0xf5004000
[ 26.638294] ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 26.638391] usb usb3: configuration #1 chosen from 1 choice
[ 26.638408] hub 3-0:1.0: USB hub found
[ 26.638419] hub 3-0:1.0: 8 ports detected
[ 26.742043] eth0: RealTek RTL8139 at 0x9800, 00:40:f4:ef:ab:e2, IRQ 11
[ 26.742047] eth0: Identified 8139 chip type 'RTL-8100B/8139D'
[ 26.742112] pata_amd 0000:00:08.0: version 0.3.10
[ 26.742161] PCI: Setting latency timer of device 0000:00:08.0 to 64
[ 26.743577] scsi0 : pata_amd
[ 26.744154] scsi1 : pata_amd
[ 26.744180] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[ 26.744183] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[ 26.913553] ata1.00: HPA unlocked: 26562719 -> 26564832, native 26564832
[ 26.913559] ata1.00: ATA-4: WDC WD136AA, 08.05D08, max UDMA/66
[ 26.913562] ata1.00: 26564832 sectors, multi 16: LBA
[ 26.930197] ata1.00: configured for UDMA/66
[ 27.405386] ata2.00: ATAPI: PIONEER DVD-RW DVR-116D, 1.03, max UDMA/66
[ 27.405402] ata2.01: ATAPI: SAMSUNG DVD-ROM SD-616T, F300, max UDMA/33
[ 27.577265] ata2.00: configured for UDMA/66
[ 27.741303] ata2.01: configured for UDMA/33
[ 27.741396] scsi 0:0:0:0: Direct-Access ATA WDC WD136AA 08.0 PQ: 0 ANSI: 5
[ 27.747890] scsi 1:0:0:0: CD-ROM PIONEER DVD-RW DVR-116D 1.03 PQ: 0 ANSI: 5
[ 27.748298] scsi 1:0:1:0: CD-ROM SAMSUNG DVD-ROM SD-616T F300 PQ: 0 ANSI: 5
[ 27.804085] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[3] MMIO=[f4005000-f40057ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 27.805865] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 27.805869] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 27.813782] Driver 'sd' needs updating - please use bus_type methods
[ 27.813863] sd 0:0:0:0: [sda] 26564832 512-byte hardware sectors (13601 MB)
[ 27.813874] sd 0:0:0:0: [sda] Write Protect is off
[ 27.813876] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 27.813888] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 27.813924] sd 0:0:0:0: [sda] 26564832 512-byte hardware sectors (13601 MB)
[ 27.813930] sd 0:0:0:0: [sda] Write Protect is off
[ 27.813932] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 27.813942] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 27.813945] sda:<4>Driver 'sr' needs updating - please use bus_type methods
[ 27.839399] sda1 sda2 sda3
[ 27.859718] sd 0:0:0:0: [sda] Attached SCSI disk
[ 27.864249] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 27.864265] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 27.864278] scsi 1:0:1:0: Attached scsi generic sg2 type 5
[ 27.894814] sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
[ 27.894818] Uniform CD-ROM driver Revision: 3.20
[ 27.894867] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 27.896994] sr1: scsi3-mmc drive: 1x/48x cd/rw xa/form2 cdda tray
[ 27.897020] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 28.134060] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 28.134064] EXT3-fs: write access will be enabled during recovery.
[ 29.076662] ieee1394: Host added: ID:BUS[0-00:1023] GUID[00023c0101012080]
[ 30.541873] kjournald starting. Commit interval 5 seconds
[ 30.541889] EXT3-fs: recovery complete.
[ 30.555979] EXT3-fs: mounted filesystem with ordered data mode.
[ 38.101103] Linux agpgart interface v0.102
[ 38.102399] agpgart: Detected AGP bridge 0
[ 38.102414] agpgart: Setting up Nforce3 AGP.
[ 38.103747] agpgart: AGP aperture is 32M @ 0xf0000000
[ 38.117497] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 38.145627] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x1c00
[ 38.145639] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x2000
[ 38.306902] gameport: EMU10K1 is pci0000:02:09.1/gameport0, io 0xa000, speed 1217kHz
[ 38.491818] Linux video capture interface: v2.00
[ 38.855610] saa7130/34: v4l2 driver version 0.2.14 loaded
[ 38.855657] saa7130[0]: found at 0000:02:0a.0, rev: 1, irq: 3, latency: 32, mmio: 0xf4007000
[ 38.855663] saa7134: <rant>
[ 38.855664] saa7134: Congratulations! Your TV card vendor saved a few
[ 38.855665] saa7134: cents for a eeprom, thus your pci board has no
[ 38.855666] saa7134: subsystem ID and I can't identify it automatically
[ 38.855668] saa7134: </rant>
[ 38.855668] saa7134: I feel better now. Ok, here are the good news:
[ 38.855670] saa7134: You can use the card=<nr> insmod option to specify
[ 38.855671] saa7134: which board do you have. The list:
[ 38.855674] saa7134: card=0 -> UNKNOWN/GENERIC
[ 38.855677] saa7134: card=1 -> Proteus Pro [philips reference design] 1131:2001 1131:2001
[ 38.855681] saa7134: card=2 -> LifeView FlyVIDEO3000 5168:0138 4e42:0138
[ 38.855685] saa7134: card=3 -> LifeView/Typhoon FlyVIDEO2000 5168:0138 4e42:0138
[ 38.855688] saa7134: card=4 -> EMPRESS 1131:6752
[ 38.855691] saa7134: card=5 -> SKNet Monster TV 1131:4e85
[ 38.855694] saa7134: card=6 -> Tevion MD 9717
[ 38.855697] saa7134: card=7 -> KNC One TV-Station RDS / Typhoon TV Tune 1131:fe01 1894:fe01
[ 38.855700] saa7134: card=8 -> Terratec Cinergy 400 TV 153b:1142
[ 38.855703] saa7134: card=9 -> Medion 5044
[ 38.855706] saa7134: card=10 -> Kworld/KuroutoShikou SAA7130-TVPCI
[ 38.855708] saa7134: card=11 -> Terratec Cinergy 600 TV 153b:1143
[ 38.855711] saa7134: card=12 -> Medion 7134 16be:0003
[ 38.855714] saa7134: card=13 -> Typhoon TV+Radio 90031
[ 38.855717] saa7134: card=14 -> ELSA EX-VISION 300TV 1048:226b
[ 38.855720] saa7134: card=15 -> ELSA EX-VISION 500TV 1048:226a
[ 38.855723] saa7134: card=16 -> ASUS TV-FM 7134 1043:4842 1043:4830 1043:4840
[ 38.855727] saa7134: card=17 -> AOPEN VA1000 POWER 1131:7133
[ 38.855730] saa7134: card=18 -> BMK MPEX No Tuner
[ 38.855732] saa7134: card=19 -> Compro VideoMate TV 185b:c100
[ 38.855735] saa7134: card=20 -> Matrox CronosPlus 102b:48d0
[ 38.855738] saa7134: card=21 -> 10MOONS PCI TV CAPTURE CARD 1131:2001
[ 38.855741] saa7134: card=22 -> AverMedia M156 / Medion 2819 1461:a70b
[ 38.855744] saa7134: card=23 -> BMK MPEX Tuner
[ 38.855747] saa7134: card=24 -> KNC One TV-Station DVR 1894:a006
[ 38.855750] saa7134: card=25 -> ASUS TV-FM 7133 1043:4843
[ 38.855753] saa7134: card=26 -> Pinnacle PCTV Stereo (saa7134) 11bd:002b
[ 38.855756] saa7134: card=27 -> Manli MuchTV M-TV002/Behold TV 403 FM
[ 38.855758] saa7134: card=28 -> Manli MuchTV M-TV001/Behold TV 401
[ 38.855761] saa7134: card=29 -> Nagase Sangyo TransGear 3000TV 1461:050c
[ 38.855764] saa7134: card=30 -> Elitegroup ECS TVP3XP FM1216 Tuner Card( 1019:4cb4
[ 38.855767] saa7134: card=31 -> Elitegroup ECS TVP3XP FM1236 Tuner Card 1019:4cb5
[ 38.855770] saa7134: card=32 -> AVACS SmartTV
[ 38.855772] saa7134: card=33 -> AVerMedia DVD EZMaker 1461:10ff
[ 38.855775] saa7134: card=34 -> Noval Prime TV 7133
[ 38.855778] saa7134: card=35 -> AverMedia AverTV Studio 305 1461:2115
[ 38.855781] saa7134: card=36 -> UPMOST PURPLE TV 12ab:0800
[ 38.855784] saa7134: card=37 -> Items MuchTV Plus / IT-005
[ 38.855786] saa7134: card=38 -> Terratec Cinergy 200 TV 153b:1152
[ 38.855789] saa7134: card=39 -> LifeView FlyTV Platinum Mini 5168:0212 4e42:0212
[ 38.855793] saa7134: card=40 -> Compro VideoMate TV PVR/FM 185b:c100
[ 38.855796] saa7134: card=41 -> Compro VideoMate TV Gold+ 185b:c100
[ 38.855799] saa7134: card=42 -> Sabrent SBT-TVFM (saa7130)
[ 38.855801] saa7134: card=43 -> :Zolid Xpert TV7134
[ 38.855804] saa7134: card=44 -> Empire PCI TV-Radio LE
[ 38.855806] saa7134: card=45 -> Avermedia AVerTV Studio 307 1461:9715
[ 38.855809] saa7134: card=46 -> AVerMedia Cardbus TV/Radio (E500) 1461:d6ee
[ 38.855812] saa7134: card=47 -> Terratec Cinergy 400 mobile 153b:1162
[ 38.855815] saa7134: card=48 -> Terratec Cinergy 600 TV MK3 153b:1158
[ 38.855818] saa7134: card=49 -> Compro VideoMate Gold+ Pal 185b:c200
[ 38.855821] saa7134: card=50 -> Pinnacle PCTV 300i DVB-T + PAL 11bd:002d
[ 38.855824] saa7134: card=51 -> ProVideo PV952 1540:9524
[ 38.855827] saa7134: card=52 -> AverMedia AverTV/305 1461:2108
[ 38.855830] saa7134: card=53 -> ASUS TV-FM 7135 1043:4845
[ 38.855833] saa7134: card=54 -> LifeView FlyTV Platinum FM / Gold 5168:0214 5168:5214 1489:0214 5168:0304
[ 38.855838] saa7134: card=55 -> LifeView FlyDVB-T DUO / MSI TV@nywhere D 5168:0306 4e42:0306
[ 38.855841] saa7134: card=56 -> Avermedia AVerTV 307 1461:a70a
[ 38.855844] saa7134: card=57 -> Avermedia AVerTV GO 007 FM 1461:f31f
[ 38.855847] saa7134: card=58 -> ADS Tech Instant TV (saa7135) 1421:0350 1421:0351 1421:0370 1421:1370
[ 38.855852] saa7134: card=59 -> Kworld/Tevion V-Stream Xpert TV PVR7134
[ 38.855854] saa7134: card=60 -> LifeView/Typhoon/Genius FlyDVB-T Duo Car 5168:0502 4e42:0502 1489:0502
[ 38.855858] saa7134: card=61 -> Philips TOUGH DVB-T reference design 1131:2004
[ 38.855861] saa7134: card=62 -> Compro VideoMate TV Gold+II
[ 38.855864] saa7134: card=63 -> Kworld Xpert TV PVR7134
[ 38.855866] saa7134: card=64 -> FlyTV mini Asus Digimatrix 1043:0210
[ 38.855869] saa7134: card=65 -> V-Stream Studio TV Terminator
[ 38.855872] saa7134: card=66 -> Yuan TUN-900 (saa7135)
[ 38.855874] saa7134: card=67 -> Beholder BeholdTV 409 FM 0000:4091
[ 38.855877] saa7134: card=68 -> GoTView 7135 PCI 5456:7135
[ 38.855880] saa7134: card=69 -> Philips EUROPA V3 reference design 1131:2004
[ 38.855883] saa7134: card=70 -> Compro Videomate DVB-T300 185b:c900
[ 38.855886] saa7134: card=71 -> Compro Videomate DVB-T200 185b:c901
[ 38.855889] saa7134: card=72 -> RTD Embedded Technologies VFG7350 1435:7350
[ 38.855892] saa7134: card=73 -> RTD Embedded Technologies VFG7330 1435:7330
[ 38.855895] saa7134: card=74 -> LifeView FlyTV Platinum Mini2 14c0:1212
[ 38.855898] saa7134: card=75 -> AVerMedia AVerTVHD MCE A180 1461:1044
[ 38.855901] saa7134: card=76 -> SKNet MonsterTV Mobile 1131:4ee9
[ 38.855904] saa7134: card=77 -> Pinnacle PCTV 40i/50i/110i (saa7133) 11bd:002e
[ 38.855907] saa7134: card=78 -> ASUSTeK P7131 Dual 1043:4862 1043:4857
[ 38.855911] saa7134: card=79 -> Sedna/MuchTV PC TV Cardbus TV/Radio (ITO
[ 38.855913] saa7134: card=80 -> ASUS Digimatrix TV 1043:0210
[ 38.855916] saa7134: card=81 -> Philips Tiger reference design 1131:2018
[ 38.855919] saa7134: card=82 -> MSI TV@Anywhere plus 1462:6231
[ 38.855922] saa7134: card=83 -> Terratec Cinergy 250 PCI TV 153b:1160
[ 38.855925] saa7134: card=84 -> LifeView FlyDVB Trio 5168:0319
[ 38.855928] saa7134: card=85 -> AverTV DVB-T 777 1461:2c05 1461:2c05
[ 38.855932] saa7134: card=86 -> LifeView FlyDVB-T / Genius VideoWonder D 5168:0301 1489:0301
[ 38.855935] saa7134: card=87 -> ADS Instant TV Duo Cardbus PTV331 0331:1421
[ 38.855938] saa7134: card=88 -> Tevion/KWorld DVB-T 220RF 17de:7201
[ 38.855941] saa7134: card=89 -> ELSA EX-VISION 700TV 1048:226c
[ 38.855944] saa7134: card=90 -> Kworld ATSC110/115 17de:7350 17de:7352
[ 38.855947] saa7134: card=91 -> AVerMedia A169 B 1461:7360
[ 38.855950] saa7134: card=92 -> AVerMedia A169 B1 1461:6360
[ 38.855953] saa7134: card=93 -> Medion 7134 Bridge #2 16be:0005
[ 38.855956] saa7134: card=94 -> LifeView FlyDVB-T Hybrid Cardbus/MSI TV 5168:3306 5168:3502 4e42:3502
[ 38.855960] saa7134: card=95 -> LifeView FlyVIDEO3000 (NTSC) 5169:0138
[ 38.855963] saa7134: card=96 -> Medion Md8800 Quadro 16be:0007 16be:0008
[ 38.855967] saa7134: card=97 -> LifeView FlyDVB-S /Acorp TV134DS 5168:0300 4e42:0300
[ 38.855970] saa7134: card=98 -> Proteus Pro 2309 0919:2003
[ 38.855973] saa7134: card=99 -> AVerMedia TV Hybrid A16AR 1461:2c00
[ 38.855976] saa7134: card=100 -> Asus Europa2 OEM 1043:4860
[ 38.855979] saa7134: card=101 -> Pinnacle PCTV 310i 11bd:002f
[ 38.855982] saa7134: card=102 -> Avermedia AVerTV Studio 507 1461:9715
[ 38.855985] saa7134: card=103 -> Compro Videomate DVB-T200A
[ 38.855988] saa7134: card=104 -> Hauppauge WinTV-HVR1110 DVB-T/Hybrid 0070:6701
[ 38.855991] saa7134: card=105 -> Terratec Cinergy HT PCMCIA 153b:1172
[ 38.855994] saa7134: card=106 -> Encore ENLTV 1131:2342 1131:2341 3016:2344
[ 38.855998] saa7134: card=107 -> Encore ENLTV-FM 1131:230f
[ 38.856001] saa7134: card=108 -> Terratec Cinergy HT PCI 153b:1175
[ 38.856004] saa7134: card=109 -> Philips Tiger - S Reference design
[ 38.856007] saa7134: card=110 -> Avermedia M102 1461:f31e
[ 38.856010] saa7134: card=111 -> ASUS P7131 4871 1043:4871
[ 38.856013] saa7134: card=112 -> ASUSTeK P7131 Hybrid 1043:4876
[ 38.856016] saa7134: card=113 -> Elitegroup ECS TVP3XP FM1246 Tuner Card 1019:4cb6
[ 38.856019] saa7134: card=114 -> KWorld DVB-T 210 17de:7250
[ 38.856022] saa7134: card=115 -> Sabrent PCMCIA TV-PCB05 0919:2003
[ 38.856025] saa7134: card=116 -> 10MOONS TM300 TV Card 1131:2304
[ 38.856028] saa7134: card=117 -> Avermedia Super 007 1461:f01d
[ 38.856032] saa7130[0]: subsystem: 1131:0000, board: UNKNOWN/GENERIC [card=0,autodetected]
[ 38.856044] saa7130[0]: board init: gpio is c04000
[ 38.957716] saa7130[0]: Huh, no eeprom present (err=-5)?
[ 38.957754] saa7130[0]: registered device video0 [v4l2]
[ 38.957767] saa7130[0]: registered device vbi0
[ 39.043682] saa7134 ALSA driver for DMA sound loaded
[ 39.043712] saa7130[0]/alsa: saa7130[0] at 0xf4007000 irq 3 registered as card -2
[ 39.080177] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3
[ 39.138896] ALSA /home/juve/hardy-packages/linux-git/ubuntu-hardy-lum/debian/build/build-rtai/sound/alsa-driver/pci/emu10k1/../../alsa-kernel/pci/emu10k1/emufx.c:1544: Installing spdif_bug patch: Audigy 2 [SB0240]
[ 40.282594] lp: driver loaded but no devices found
[ 40.415514] Adding 971924k swap on /dev/sda3. Priority:-1 extents:1 across:971924k
[ 40.945212] EXT3 FS on sda1, internal journal
[ 42.056454] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 43.265285] ppdev: user-space parallel port driver
[ 43.428180] audit(1256836670.270:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=4421 profile="/usr/sbin/cupsd" namespace="default"
[ 44.408657] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 44.474414] Bluetooth: Core ver 2.11
[ 44.476222] NET: Registered protocol family 31
[ 44.476226] Bluetooth: HCI device and connection manager initialized
[ 44.476230] Bluetooth: HCI socket layer initialized
[ 44.504350] Bluetooth: L2CAP ver 2.9
[ 44.504355] Bluetooth: L2CAP socket layer initialized
[ 44.521427] Bluetooth: RFCOMM socket layer initialized
[ 44.521915] Bluetooth: RFCOMM TTY layer initialized
[ 44.521918] Bluetooth: RFCOMM ver 1.8
[ 48.574944] NET: Registered protocol family 17
[ 53.930109] NET: Registered protocol family 10
[ 53.930287] lo: Disabled Privacy Extensions
[ 63.988365] eth0: no IPv6 routers present
[ 70.999502] BUG: unable to handle kernel NULL pointer dereference at virtual address 00000038
[ 70.999509] printing eip: f8a1b4d5 *pde = 00000000
[ 70.999513] Oops: 0000 [#1]
[ 70.999516] Modules linked in: ipv6 af_packet rfcomm l2cap bluetooth ppdev iptable_filter ip_tables x_tables sbp2 lp parport snd_emu10k1_synth snd_emux_synth snd_seq_virmidi snd_seq_midi_emul snd_emu10k1 snd_ac97_codec ac97_bus snd_util_mem snd_hwdep saa7134_alsa snd_pcm_oss snd_mixer_oss snd_seq_dummy snd_pcm snd_page_alloc snd_seq_oss snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq saa7134 snd_timer snd_seq_device compat_ioctl32 videobuf_dma_sg videobuf_core ir_kbd_i2c snd serio_raw ir_common videodev v4l2_common v4l1_compat psmouse soundcore emu10k1_gp gameport i2c_nforce2 i2c_core pcspkr amd64_agp agpgart evdev ext3 jbd mbcache sg sr_mod cdrom sd_mod amd74xx ide_core ata_generic ohci1394 ieee1394 pata_amd 8139too mii libata scsi_mod ehci_hcd ohci_hcd usbcore fuse
[ 70.999548]
[ 70.999551] Pid: 5191, comm: pulseaudio Not tainted (2.6.24-16-rtai #1)
[ 70.999554] EIP: 0060:[<f8a1b4d5>] EFLAGS: 00010282 CPU: 0
[ 70.999561] EIP is at snd_card_saa7134_capture_open+0xf/0x101 [saa7134_alsa]
[ 70.999564] EAX: f7fdc100 EBX: 00000000 ECX: f6dbe278 EDX: f8a1e0ac
[ 70.999567] ESI: f7fdc100 EDI: f6dbec00 EBP: 00000000 ESP: f6e83e64
[ 70.999569] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
[ 70.999572] Process pulseaudio (pid: 5191, ti=f6e82000 task=f7c96560 task.ti=f6e82000)<0>
[ 70.999574] I-pipe domain Linux
[ 70.999575] Stack: ffffffff f6dbec00 00000000 f6e83eb0 f6e54300 df9a8f08 f8a2cc25 f6e83e84
[ 70.999580] f7fdc100 df9a8f08 df9a8e00 f8a2ccf9 f6e83eb0 00000001 00000000 f7c96560
[ 70.999584] c010f197 df9a8f14 df9a8f14 f6e54300 f89c03e4 00000000 f6e54300 f7e64d1c
[ 70.999588] Call Trace:
[ 70.999600] [<f8a2cc25>] snd_pcm_open_substream+0x3c/0x76 [snd_pcm]
[ 70.999622] [<f8a2ccf9>] snd_pcm_open+0x9a/0x172 [snd_pcm]
[ 70.999638] [<c010f197>] default_wake_function+0x0/0x5
[ 70.999657] [<f89bc38f>] snd_open+0xbb/0x105 [snd]
[ 70.999676] [<c0158c89>] chrdev_open+0xe0/0xf6
[ 70.999688] [<c0158ba9>] chrdev_open+0x0/0xf6
[ 70.999691] [<c01554da>] __dentry_open+0xc1/0x16d
[ 70.999704] [<c0155600>] nameidata_to_filp+0x24/0x33
[ 70.999711] [<c0155646>] do_filp_open+0x37/0x3e
[ 70.999723] [<f89bf5c0>] snd_ctl_release+0xbd/0xd9 [snd]
[ 70.999751] [<c01553b3>] get_unused_fd_flags+0x49/0xa8
[ 70.999764] [<c0155691>] do_sys_open+0x44/0xca
[ 70.999777] [<c0155750>] sys_open+0x1c/0x1e
[ 70.999781] [<c0103c25>] sysenter_past_esp+0x6e/0x72
[ 70.999812] =======================
[ 70.999814] Code: 78 42 00 8b 50 38 74 11 c7 82 54 05 00 00 01 00 00 00 89 d0 e8 d0 fa fd ff 31 c0 c3 55 57 56 89 c6 53 83 ec 08 8b 68 08 8b 78 70 <8b> 5d 38 8d 43 48 89 44 24 04 e8 59 91 84 c7 8b 83 b8 05 00 00
[ 70.999830] EIP: [<f8a1b4d5>] snd_card_saa7134_capture_open+0xf/0x101 [saa7134_alsa] SS:ESP 0068:f6e83e64
[ 70.999838] ---[ end trace b15e9844f98da9d5 ]---
[ 1008.806299] I-pipe: Domain RTAI registered.
[ 1008.806304] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 1008.806323] BUG: Unhandled exception over domain RTAI at 0xc013a453 - switching to ROOT
[ 1008.806327] Pid: 5389, comm: insmod Tainted: G D 2.6.24-16-rtai #1
[ 1008.806334] [<c010b98e>] __ipipe_handle_exception+0x104/0x156
[ 1008.806345] [<c013a453>] __ipipe_restore_root+0xc/0x22
[ 1008.806362] [<c026529f>] error_code+0x6f/0x80
[ 1008.806386] [<c013a453>] __ipipe_restore_root+0xc/0x22
[ 1008.806393] [<c0112967>] release_console_sem+0x15f/0x1b1
[ 1008.806407] [<c0112d33>] vprintk+0x239/0x261
[ 1008.806438] [<c01bf46a>] vsnprintf+0x29c/0x469
[ 1008.806458] [<c0112da7>] printk+0x4c/0xb5
[ 1008.806472] [<f8bf3379>] rt_printk+0x3f/0x47 [rtai_hal]
[ 1008.806523] [<c01ec5fe>] vt_console_print+0x0/0x249
[ 1008.806529] [<c0112542>] __call_console_drivers+0x34/0x40
[ 1008.806539] [<c01129a0>] release_console_sem+0x198/0x1b1
[ 1008.806553] [<c0112d4f>] vprintk+0x255/0x261
[ 1008.806596] [<c01bbb53>] idr_get_new+0xa/0x24
[ 1008.806606] [<c0112da7>] printk+0x4c/0xb5
[ 1008.806612] [<f8bf33a8>] rtai_domain_entry+0x27/0x3f [rtai_hal]
[ 1008.806627] [<c013afa7>] ipipe_register_domain+0x198/0x1cb
[ 1008.806639] [<f8bf4642>] __rtai_hal_init+0x1da/0x287 [rtai_hal]
[ 1008.806647] [<f8bf3000>] rtai_uvec_handler+0x0/0x3a [rtai_hal]
[ 1008.806659] [<c014c9f0>] __vunmap+0xbd/0xd1
[ 1008.806678] [<f8bf3381>] rtai_domain_entry+0x0/0x3f [rtai_hal]
[ 1008.806689] [<c012cec6>] sys_init_module+0x12ee/0x13a6
[ 1008.806784] [<c0103c25>] sysenter_past_esp+0x6e/0x72
[ 1008.806818] =======================
[ 1008.806825]
[ cut here ]
[ 1008.806827] Kernel BUG at c013a453 [verbose debug info unavailable]
[ 1008.806830] invalid opcode: 0000 [#2]
[ 1008.806831] Modules linked in: rtai_hal ipv6 af_packet rfcomm l2cap bluetooth ppdev iptable_filter ip_tables x_tables sbp2 lp parport snd_emu10k1_synth snd_emux_synth snd_seq_virmidi snd_seq_midi_emul snd_emu10k1 snd_ac97_codec ac97_bus snd_util_mem snd_hwdep saa7134_alsa snd_pcm_oss snd_mixer_oss snd_seq_dummy snd_pcm snd_page_alloc snd_seq_oss snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq saa7134 snd_timer snd_seq_device compat_ioctl32 videobuf_dma_sg videobuf_core ir_kbd_i2c snd serio_raw ir_common videodev v4l2_common v4l1_compat psmouse soundcore emu10k1_gp gameport i2c_nforce2 i2c_core pcspkr amd64_agp agpgart evdev ext3 jbd mbcache sg sr_mod cdrom sd_mod amd74xx ide_core ata_generic ohci1394 ieee1394 pata_amd 8139too mii libata scsi_mod ehci_hcd ohci_hcd usbcore fuse
[ 1008.806859]
[ 1008.806861] Pid: 5389, comm: insmod Tainted: G D (2.6.24-16-rtai #1)
[ 1008.806863] EIP: 0060:[<c013a453>] EFLAGS: 00010202 CPU: 0
[ 1008.806866] EIP is at __ipipe_restore_root+0xc/0x22
[ 1008.806868] EAX: 00000001 EBX: 0000785e ECX: ffffffff EDX: 000078a5
[ 1008.806870] ESI: 000078a5 EDI: 000078a5 EBP: 000078a5 ESP: f2491cac
[ 1008.806872] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
[ 1008.806874] Process insmod (pid: 5389, ti=f2490000 task=f24d9020 task.ti=f2490000)<0>
[ 1008.806876] I-pipe domain Linux
[ 1008.806877] Stack: c0112967 00000000 fffff330 f2491d08 00000200 00000012 f2491d08 c0112d33
[ 1008.806881] f2491cf6 c02a1d48 00000036 000003f0 000c4da0 01376288 0000004a c033dcd3
[ 1008.806885] e18a9c08 300f3c08 363cffce 31205b3e 2e383030 33363038 205d3430 000c4d00
[ 1008.806889] Call Trace:
[ 1008.806890] [<c0112967>] release_console_sem+0x15f/0x1b1
[ 1008.806903] [<c0112d33>] vprintk+0x239/0x261
[ 1008.806935] [<c01bf46a>] vsnprintf+0x29c/0x469
[ 1008.806954] [<c0112da7>] printk+0x4c/0xb5
[ 1008.806968] [<f8bf3379>] rt_printk+0x3f/0x47 [rtai_hal]
[ 1008.807017] [<c01ec5fe>] vt_console_print+0x0/0x249
[ 1008.807022] [<c0112542>] __call_console_drivers+0x34/0x40
[ 1008.807032] [<c01129a0>] release_console_sem+0x198/0x1b1
[ 1008.807046] [<c0112d4f>] vprintk+0x255/0x261
[ 1008.807089] [<c01bbb53>] idr_get_new+0xa/0x24
[ 1008.807099] [<c0112da7>] printk+0x4c/0xb5
[ 1008.807104] [<f8bf33a8>] rtai_domain_entry+0x27/0x3f [rtai_hal]
[ 1008.807119] [<c013afa7>] ipipe_register_domain+0x198/0x1cb
[ 1008.807131] [<f8bf4642>] __rtai_hal_init+0x1da/0x287 [rtai_hal]
[ 1008.807139] [<f8bf3000>] rtai_uvec_handler+0x0/0x3a [rtai_hal]
[ 1008.807151] [<c014c9f0>] __vunmap+0xbd/0xd1
[ 1008.807170] [<f8bf3381>] rtai_domain_entry+0x0/0x3f [rtai_hal]
[ 1008.807181] [<c012cec6>] sys_init_module+0x12ee/0x13a6
[ 1008.807274] [<c0103c25>] sysenter_past_esp+0x6e/0x72
[ 1008.807308] =======================
[ 1008.807309] Code: 0b eb fe fa 0f ba 35 a4 14 2e c0 00 83 3d a8 14 2e c0 00 74 08 83 c8 ff e8 f4 fb ff ff fb c3 81 3d 24 19 2e c0 80 31 38 c0 74 04 <0f> 0b eb fe 85 c0 74 09 0f ba 2d a4 14 2e c0 00 c3 e9 b2 ff ff
[ 1008.807323] EIP: [<c013a453>] __ipipe_restore_root+0xc/0x22 SS:ESP 0068:f2491cac
[ 1008.807328] ---[ end trace b15e9844f98da9d5 ]---
Debug file information:
/etc/init.d/realtime: line 148: 5389 Segmentation fault $INSMOD $MOD
5374
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -9
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal is in use
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=emcsh
EMC2_IOSH=iosh
EMC2 - 2.3.0
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
Cleanup done
[ 70.999548]
[ 1008.806825]
[ cut here ]
[ 1008.806859]
5374
22 Feb 2010 15:56 #1990
by andreas59
Replied by andreas59 on topic Re:emc2 will stop with an error when 1st run
I am not shure, but try to diable the TV hardware in BIOS and try aggain.
Andreas.
Andreas.
Time to create page: 0.260 seconds
