Installation EMC on kubuntu 9.4/9.10
18 Feb 2010 08:45 #1954 by rogma
Ok,
I'll try that.
18 Feb 2010 12:28 #1958 by kilop
hello i tryied to install rtai deb on 9.10 ubuntu but after instalation i got black screen after boot :( i also try to make rtai with this faq neo-technical.wikispaces.com/emc2-ubuntu
but even if i use only rtai config i got black screen but i also make my config from scrach and afte boot i got problems with pratiton that kernel cant see /dev/sda1 partiton :( i got only on hdd in laptop /dev/sda with sda1 / and sda5 swap procesor is Pentium M and all taht data was included in .config chipsets Intel audio intel is there any one who can help me ?
18 Feb 2010 16:36 #1959 by rogma
mozmck wrote:
Ah, I believe that is a package that went away in 9.10. Try downloading it from here and installing it: packages.ubuntu.com/jaunty/python-xml
I think that's what I had to do to get it to work.
Moses
Thanks,
This package worked. The package name is python-xml, version 0.8.4-10.1ubuntu2.
I have now installed emc2 on 9.10.
19 Feb 2010 21:32 #1964 by rogma
To get emc started I had to create /dev/rtai_shm and /dev/RTAI_SHM.
sudo mknod /dev/RTAI_SHM c 10, 254
sudo ln -s /dev/RTAI_SHM /dev/rtai_shm
But I can only start as root. Non root user gets
Can't write to /dev/rtai_shm - aborting
I tried to change permissions on both files above, but /dev/rtai_shm gets changed back to
crw-rw---- 1 root root 10, 254 2010-02-19 22:14 rtai_shm
as soon as I test with
/etc/init.d/realtime start
I also created udev rules and placed them both at /etc/udev/rules.d/ and /lib/udev/rules.d/ but no change.
$ more /etc/udev/rules.d/99-rtai.rules
KERNEL=="RTAI_SHM",SYMLINK="rtai_shm", MODE="0666"
KERNEL=="rtf[0-9]*", MODE="0666"
I suspect it has something to do with udev!
I need help.
Thanks Janne
20 Feb 2010 01:29 #1965 by mozmck
Make sure you have the following two lines in the configuration file /etc/security/limits.conf, and add them at the end if they are not there.
* soft memlock 20480
* hard memlock 20480
Then you'll need to reboot, and this should allow you to run as a normal user.
22 Feb 2010 12:33 #1980 by Livemill
Will there be a new Realease for Karmic Koala or will the development maybe wait for 10.04.
its not far to the new realease off the new ubuntu version.
22 Feb 2010 21:51 #2001 by acemi
23 Feb 2010 08:42 #2014 by Livemill
thank you very match !
looking forward to see whats happening on these status page!
11 Mar 2010 00:18 #2270 by kgill
Has anyone been able to make a live cd? with 9.4/9.10 like emc 2.3 Ubuntu 8.04.
11 Mar 2010 00:46 #2271 by waynegramlich
I recently bought a new laptop and installed Kubuntu 9.10 on it.
I've been trying to reinstall the EMC2 Simulator with no success
to date. I went to:
emc2-buildbot.colorado.edu/~buildmaster/
loaded the appropriate APT line into my package manager and
attempted to load the emc2-sim package. I get the following compliant:
The following packages have unmet dependencies:
  emc2-sim: Depends: python (< 2.6) but 2.6.4-0ubuntu1 is to be installed
            Recommends: hostmot2-firmware but it is not installable
Given that these are supposed to be Beta packages for 10.4, I thought
I would ask if this issue has come up before?
Any help would be appreciated,
-Wayne
Time to create page: 0.470 seconds
