Realtime Kernal Required
- volumetone
26 Nov 2009 05:49 #1202
by volumetone
Realtime Kernal Required was created by volumetone
Hello all,
Sorry, this is probably an easy question:
I just installed EMC and rebooted my computer. Now, when I try to run the program I get the following message pop up:
"EMC2 required the real-time kernal 2.6.24-16-rtai to run. Before running EMC2, reboot and choose this kernel at the boot menu."
How do I do this? This is really my first time interacting with Linux.
Thank you for any help!
26 Nov 2009 08:16 - 26 Nov 2009 08:18 #1203
Replied by cmorley on topic Re:Realtime Kernal Required
I would bet you did an update of ubuntu after installing EMC. That would have added different kernels. EMC needs to use the rtai kernel.
This will happen every time an Ubuntu update includes a new kernel image.
When starting the computer you should see text that mentions the grub menu (like push escape button to enter the grub menu)
get to this grub menu and using the arrow keys choose the rtai kernal and push enter.
Now you have loaded the proper kernel and EMC should be happy.
To make Ubuntu always load the rtai kernel involves using sudo privileges to edit grub's menu.lst file.
I will let someone else explain that.
Hope that helps!
Hope that helps!
Last edit: 26 Nov 2009 08:18 by cmorley.
- volumetone
26 Nov 2009 17:45 #1208
by volumetone
Replied by volumetone on topic Re:Realtime Kernal Required
Thank you very much! It works now :>
If anyone can tell me, or where I might be able to find instructions, on how to change the system to start with this kernal each time, it would be much appreciated.
Thanks again!
Thanks again!
- volumetone
27 Nov 2009 04:10 #1209
by volumetone
Nevermind; Your hint was good enough so I figured it out. Thanks again! :>
- Gonefishing
28 Jul 2010 17:23 #3508
by Gonefishing
Replied by Gonefishing on topic Re:Realtime Kernal Required
Hi I know this is an old thread but I have recently installed and am having the same issue. Is there any chance someone could describe for me how to make Ubuntu load to the rtai kernal without my intervention.Thanks in advance:huh:
28 Jul 2010 18:31 #3509
by aike
Replied by aike on topic Re:Realtime Kernal Required
The first of all!
After the FIRST installing ubuntu+emc type the next command
dpkg -l | grep linux-image
You will see the right name of RTAI linux omage name
The second command you nedd to do:
sudo aptitude hold linux-image-blblbl-rtai016.24
linux-image-blblbl-rtai016.24 - it is the right name of you current RTAI linux image
That's all.
And the third command
sudo aptitude update
The forth commans
sudo aptitude safe-upgrade.
Vu a la!
All will be work and you will never will be prompt to install new image...
That's all.
The forth commans
Vu a la!
- Gonefishing
28 Jul 2010 18:46 #3510
by Gonefishing
Thanks for the fast reply but I am not sure I am getting the first command correct as nothing happens and also should I be entering it inside a terminal
Time to create page: 0.276 seconds
