emc2 on parallels prob.
- urslee
- Topic Author
- Visitor
22 Apr 2009 20:36 #131
by urslee
emc2 on parallels prob. was created by urslee
23 Apr 2009 07:25 #134
by alex_joni
Replied by alex_joni on topic Re:emc2 on parallels prob.
Ubuntu 8.10 + emc2 is not 100% supported.
You can probably install it, but I am not sure that bad things don't happen
If you're running in a VM, then using the RT version doesn't really help, maybe try loading the sim packages. (replace emc2.3 with emc2.3-sim in your sources list, then install emc2-sim).
To further debug your issue, I would need the output from dmesg (maybe clear it before starting emc2).
Regards,
Alex
Regards,
Alex
- urslee
- Topic Author
- Visitor
10 May 2009 21:11 #234
by urslee
Replied by urslee on topic Re:emc2 on parallels prob.
Hi
Thanks so far
I had a little spare time so i decided to install the Live-CD 8.04 and the problem still exists
I'd like to show you the dmesg after EMC crashes but the keyboard doesn't respond after the crash
so I show it before and the rt kernel seems to be loaded (as far as i can read out of it)
all though i took a look at the realtime script on line 148 ( etc/init.d/realtime )
but this is far beyond my knowledge to understand.
I didn't load the sim installation but i will try next.
-desktop:~$ dmesg
[ 0.000000] Linux version 2.6.24-16-rtai (root@hardy) (gcc version 4.2.3 (Ubuntu 4.2.3-2ubuntu7)) #1 Tue Sep 30 22:54:33 EEST 2008 (Ubuntu 2.6.24-12.22-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] BIOS-e820: 000000003fff0000 - 000000003ffff000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003ffff000 - 0000000040000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffc00000 - 0000000100000000 (reserved)
[ 0.000000] 127MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 262128) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 262128
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 262128
[ 0.000000] On node 0 totalpages: 262128
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 255 pages used for memmap
[ 0.000000] HighMem zone: 32497 pages, LIFO batch:7
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI 2.3 present.
[ 0.000000] Allocating PCI resources starting at 50000000 (gap: 40000000:bec00000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260081
[ 0.000000] Kernel command line: root=UUID=62f92169-52cf-4c8a-88db-ff404be16692 ro quiet splash
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Detected 3059.592 MHz processor.
[ 4.702229] I-pipe 2.0-04: pipeline enabled.
[ 4.702942] Console: colour VGA+ 80x25
[ 4.702945] console [tty0] enabled
[ 4.704903] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 4.705927] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 4.716517] Memory: 1029516k/1048512k available (1440k kernel code, 18200k reserved, 573k data, 228k init, 131008k highmem)
[ 4.716567] virtual kernel memory layout:
[ 4.716590] fixmap : 0xfffed000 - 0xfffff000 ( 72 kB)
[ 4.716592] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 4.716594] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 4.716596] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 4.716598] .init : 0xc02fa000 - 0xc0333000 ( 228 kB)
[ 4.716600] .data : 0xc026836d - 0xc02f77ec ( 573 kB)
[ 4.716602] .text : 0xc0100000 - 0xc026836d (1440 kB)
[ 4.716605] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 4.716944] SLUB: Genslabs=11, HWalign=64, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
[ 4.818349] Calibrating delay using timer specific routine.. 6122.60 BogoMIPS (lpj=12245202)
[ 4.818366] Security Framework initialized
[ 4.818384] SELinux: Disabled at boot.
[ 4.818395] AppArmor: AppArmor initialized
[ 4.818399] Failure registering capabilities with primary security module.
[ 4.818403] Mount-cache hash table entries: 512
[ 4.818748] CPU: After generic identify, caps: 1f89fbfd 20000800 00000000 00000000 00080201 00000000 00000001 00000000
[ 4.818764] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 4.818767] CPU: L2 cache: 6144K
[ 4.818772] CPU: After all inits, caps: 1f89fbfd 20000800 00000000 00000940 00080201 00000000 00000001 00000000
[ 4.818780] Compat vDSO mapped to ffffe000.
[ 4.818838] CPU: Intel(R) Core(TM)2 Duo CPU E8435 @ 3.06GHz stepping 0a
[ 4.818842] Checking 'hlt' instruction... OK.
[ 4.839076] Freeing SMP alternatives: 0k freed
[ 4.840223] net_namespace: 64 bytes
[ 4.840662] NET: Registered protocol family 16
[ 4.841293] EISA bus registered
[ 4.841827] PCI: PCI BIOS revision 2.10 entry at 0xf41ab, last bus=2
[ 4.841831] PCI: Using configuration type 1
[ 4.841834] Setting up standard PCI resources
[ 4.844012] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 4.845003] PCI: Probing PCI hardware
[ 4.845042] PCI: Probing PCI hardware (bus 00)
[ 4.847112] PCI quirk: region 4000-407f claimed by ICH6 ACPI/GPIO/TCO
[ 4.862293] PCI: Transparent bridge - 0000:00:1e.0
[ 4.868021] PCI: Using IRQ router default [8086/29a0] at 0000:00:00.0
[ 4.868073] PCI: Cannot allocate resource region 9 of bridge 0000:00:1e.0
[ 4.871064] PCI: Device 0000:00:1d.7 not found by BIOS
[ 4.873048] PCI: Device 0000:00:1f.4 not found by BIOS
[ 4.882298] AppArmor: AppArmor Filesystem Enabled
[ 4.886146] PCI: Bridge: 0000:00:01.0
[ 4.886159] IO window: 6000-7fff
[ 4.886186] MEM window: e0000000-e0ffffff
[ 4.886205] PREFETCH window: b0000000-bfffffff
[ 4.886224] Time: tsc clocksource has been installed.
[ 4.886245] PCI: Bridge: 0000:00:0a.0
[ 4.886262] IO window: 9000-afff
[ 4.886286] MEM window: e4000000-e7ffffff
[ 4.886304] PREFETCH window: c0000000-dfffffff
[ 4.886331] PCI: Bridge: 0000:00:1e.0
[ 4.886343] IO window: c000-dfff
[ 4.886370] MEM window: ec000000-ecffffff
[ 4.886389] PREFETCH window: disabled.
[ 4.886522] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 4.886572] PCI: Setting latency timer of device 0000:00:0a.0 to 64
[ 4.886631] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 4.886647] NET: Registered protocol family 2
[ 4.926208] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 4.926291] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 4.935052] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[ 4.936330] TCP: Hash tables configured (established 131072 bind 65536)
[ 4.936334] TCP reno registered
[ 4.947171] checking if image is initramfs... it is
[ 5.407686] Freeing initrd memory: 6507k freed
[ 5.409715] audit: initializing netlink socket (disabled)
[ 5.409725] audit(1241986326.676:1): initialized
[ 5.410067] highmem bounce pool size: 64 pages
[ 5.413628] VFS: Disk quotas dquot_6.5.1
[ 5.413642] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 5.413961] io scheduler noop registered
[ 5.413964] io scheduler anticipatory registered
[ 5.413966] io scheduler deadline registered
[ 5.413973] io scheduler cfq registered (default)
[ 5.414083] Boot video device is 0000:01:00.0
[ 5.414227] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 5.414429] assign_interrupt_mode Found MSI capability
[ 5.414432] Allocate Port Service[0000:00:01.0:pcie00]
[ 5.415016] isapnp: Scanning for PnP cards...
[ 5.773887] isapnp: No Plug & Play device found
[ 5.805898] Real Time Clock Driver v1.12ac
[ 5.805902] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 5.806904] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 5.806958] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 5.807090] PNP: No PS/2 controller found. Probing ports directly.
[ 5.807523] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 5.807528] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 5.813733] mice: PS/2 mouse device common for all mice
[ 5.816233] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 5.816256] EISA: Probing bus 0 at eisa.0
[ 5.816278] Cannot allocate resource for EISA slot 4
[ 5.816286] Cannot allocate resource for EISA slot 6
[ 5.816289] Cannot allocate resource for EISA slot 7
[ 5.816291] Cannot allocate resource for EISA slot 8
[ 5.816294] EISA: Detected 0 cards.
[ 5.816339] NET: Registered protocol family 1
[ 5.816346] Using IPI Shortcut mode
[ 5.816388] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 5.816391] EDD information not available.
[ 5.816483] Freeing unused kernel memory: 228k freed
[ 7.729099] fuse init (API version 7.9)
[ 8.183594] ne2k-pci.c:v1.03 9/22/2003 D. Becker/P. Gortmaker
[ 8.183937] eth0: RealTek RTL-8029 found at 0x8200, IRQ 10, 00:1c:42:76:2b:05.
[ 8.258187] usbcore: registered new interface driver usbfs
[ 8.258201] usbcore: registered new interface driver hub
[ 8.271797] usbcore: registered new device driver usb
[ 8.272559] USB Universal Host Controller Interface driver v3.0
[ 8.272611] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[ 8.272618] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 8.272717] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 8.272760] uhci_hcd 0000:00:1d.0: irq 11, io base 0x0000b000
[ 8.272838] usb usb1: configuration #1 chosen from 1 choice
[ 8.272850] hub 1-0:1.0: USB hub found
[ 8.272855] hub 1-0:1.0: 2 ports detected
[ 8.339780] SCSI subsystem initialized
[ 8.376934] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[ 8.376942] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 8.376956] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 8.377036] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[ 8.377043] ehci_hcd 0000:00:1d.7: irq 9, io mem 0xe8000000
[ 8.378677] libata version 3.00 loaded.
[ 8.387515] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 8.387618] usb usb2: configuration #1 chosen from 1 choice
[ 8.387632] hub 2-0:1.0: USB hub found
[ 8.387637] hub 2-0:1.0: 8 ports detected
[ 8.493019] ata_piix 0000:00:1f.1: version 2.12
[ 8.493075] PCI: Setting latency timer of device 0000:00:1f.1 to 64
[ 8.495005] scsi0 : ata_piix
[ 8.498856] scsi1 : ata_piix
[ 8.498872] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xe200 irq 14
[ 8.498875] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xe208 irq 15
[ 8.807423] ata1.00: ATA-5: Virtual HDD [0], FWR10003, max UDMA/100
[ 8.807427] ata1.00: 67109616 sectors, multi 128: LBA48
[ 8.807441] ata1.01: ATAPI: Virtual DVD-ROM [1], FWR10003, max UDMA/25
[ 8.807913] ata1.00: configured for UDMA/100
[ 8.962628] ata1.01: configured for UDMA/25
[ 9.118298] scsi 0:0:0:0: Direct-Access ATA Virtual HDD [0] FWR1 PQ: 0 ANSI: 5
[ 9.118575] scsi 0:0:1:0: CD-ROM Virtual DVD-ROM R103 PQ: 0 ANSI: 5
[ 11.039660] Driver 'sd' needs updating - please use bus_type methods
[ 11.042712] sd 0:0:0:0: [sda] 67109616 512-byte hardware sectors (34360 MB)
[ 11.042725] sd 0:0:0:0: [sda] Write Protect is off
[ 11.042728] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 11.042749] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 11.042787] sd 0:0:0:0: [sda] 67109616 512-byte hardware sectors (34360 MB)
[ 11.042799] sd 0:0:0:0: [sda] Write Protect is off
[ 11.042802] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 11.042823] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 11.042826] sda:<4>Driver 'sr' needs updating - please use bus_type methods
[ 11.055174] sda1 sda2 < sda5 >
[ 11.056934] sd 0:0:0:0: [sda] Attached SCSI disk
[ 11.069338] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 11.069349] scsi 0:0:1:0: Attached scsi generic sg1 type 5
[ 11.071056] sr0: scsi3-mmc drive: 44x/44x cd/rw xa/form2 cdda tray
[ 11.071059] Uniform CD-ROM driver Revision: 3.20
[ 11.071081] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 11.690910] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 11.690914] EXT3-fs: write access will be enabled during recovery.
[ 11.768260] kjournald starting. Commit interval 5 seconds
[ 11.768274] EXT3-fs: recovery complete.
[ 11.768573] EXT3-fs: mounted filesystem with ordered data mode.
[ 15.959348] Linux agpgart interface v0.102
[ 16.252836] iTCO_vendor_support: vendor-support=0
[ 16.254268] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.02 (26-Jul-2007)
[ 16.254356] BUG: unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 16.254360] printing eip: f8816013 *pde = 00000000
[ 16.254367] Oops: 0000 [#1]
[ 16.254369] Modules linked in: iTCO_wdt iTCO_vendor_support intel_agp agpgart ext3 jbd mbcache sg sr_mod cdrom sd_mod ata_piix ata_generic libata scsi_mod ehci_hcd uhci_hcd usbcore ne2k_pci 8390 fuse
[ 16.254376]
[ 16.254379] Pid: 2513, comm: modprobe Not tainted (2.6.24-16-rtai #1)
[ 16.254382] EIP: 0060:[<f8816013>] EFLAGS: 00010246 CPU: 0
[ 16.254386] EIP is at iTCO_wdt_unset_NO_REBOOT_bit+0x13/0x92 [iTCO_wdt]
[ 16.254389] EAX: 00000000 EBX: f7c1b800 ECX: c1000060 EDX: 00000000
[ 16.254392] ESI: f8818658 EDI: df92bdd8 EBP: ffffffea ESP: df92bdb8
[ 16.254395] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
[ 16.254398] Process modprobe (pid: 2513, ti=df92a000 task=f7f76560 task.ti=df92a000)<0>
[ 16.254400] I-pipe domain Linux
[ 16.254402] Stack: f8818658 df92bdd8 f7c1b800 f8816595 df92bdd8 00000000 f7e9e808 f7e9e870
[ 16.254406] 00000000 f7e9e808 00000000 f8818934 c01f77d9 c01f6824 f8818970 c0263911
[ 16.254410] f881896c f7e9e808 f7e9e808 00000000 f7e9e808 c01f5d70 c02ecc38 c02ecc38
[ 16.254414] Call Trace:
[ 16.254417] [<f8816595>] iTCO_wdt_probe+0xbb/0x296 [iTCO_wdt]
[ 16.254422] [<c01f77d9>] platform_drv_probe+0xc/0xd
[ 16.254427] [<c01f6824>] driver_probe_device+0xc4/0x146
[ 16.254430] [<c0263911>] klist_next+0x46/0x61
[ 16.254434] [<c01f5d70>] bus_for_each_drv+0x30/0x56
[ 16.254439] [<c01f6928>] device_attach+0x62/0x75
[ 16.254442] [<c01f68a6>] __device_attach+0x0/0x5
[ 16.254445] [<c01f5cf1>] bus_attach_device+0x26/0x75
[ 16.254449] [<c01f5079>] device_add+0x281/0x42b
[ 16.254453] [<c01549ba>] __kmalloc+0xa9/0xe4
[ 16.254457] [<c01f7aa1>] platform_device_add+0xe8/0x116
[ 16.254460] [<c01bc22b>] kobject_init+0x29/0x37
[ 16.254464] [<c01f4a7f>] device_initialize+0x66/0x81
[ 16.254468] [<c01f7bc6>] platform_device_alloc+0x40/0x51
[ 16.254472] [<c01f7c3c>] platform_device_register_simple+0x34/0x4a
[ 16.254475] [<f8886047>] iTCO_wdt_init_module+0x47/0x69 [iTCO_wdt]
[ 16.254480] [<c012cec6>] sys_init_module+0x12ee/0x13a6
[ 16.254484] [<c0149cad>] vma_link+0x89/0x92
[ 16.254488] [<c014a372>] mmap_region+0x308/0x3c4
[ 16.254495] [<c0103c25>] sysenter_past_esp+0x6e/0x72
[ 16.254499] =======================
[ 16.254502] Code: <8b> 10 83 e2 df 89 54 24 04 89 10 8b 00 a8 20 eb 5f 48 75 65 a1 18
[ 16.254512] EIP: [<f8816013>] iTCO_wdt_unset_NO_REBOOT_bit+0x13/0x92 [iTCO_wdt] SS:ESP 0068:df92bdb8
[ 16.254517] ---[ end trace b08ff8af47960bd2 ]---
[ 16.703864] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 17.006920] PCI: Setting latency timer of device 0000:00:1f.4 to 64
[ 17.067795] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input3
[ 17.330378] intel8x0_measure_ac97_clock: measured 54067 usecs
[ 17.331057] intel8x0: measured clock 0 rejected
[ 17.331059] intel8x0: clocking to 48000
[ 21.285917] lp: driver loaded but no devices found
[ 21.512494] Adding 1421712k swap on /dev/sda5. Priority:-1 extents:1 across:1421712k
[ 22.202594] EXT3 FS on sda1, internal journal
[ 23.991825] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 27.044952] ppdev: user-space parallel port driver
[ 27.131722] audit(1241986349.183:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=4080 profile="/usr/sbin/cupsd" namespace="default"
[ 28.608700] Bluetooth: Core ver 2.11
[ 28.616453] NET: Registered protocol family 31
[ 28.616456] Bluetooth: HCI device and connection manager initialized
[ 28.616459] Bluetooth: HCI socket layer initialized
[ 28.683512] Bluetooth: L2CAP ver 2.9
[ 28.683516] Bluetooth: L2CAP socket layer initialized
[ 28.731524] Bluetooth: RFCOMM socket layer initialized
[ 28.731533] Bluetooth: RFCOMM TTY layer initialized
[ 28.731535] Bluetooth: RFCOMM ver 1.8
[ 45.153270] NET: Registered protocol family 10
[ 45.153372] lo: Disabled Privacy Extensions
[ 50.505377] UDF-fs: No VRS found
[ 50.509617] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 50.511342] ISO 9660 Extensions: RRIP_1991A
[ 55.928345] eth0: no IPv6 routers present
Thanks so far
-desktop:~$ dmesg
[ 16.254376]
Time to create page: 0.082 seconds
