problems of using git to fetch EMC2
04 Jan 2010 14:27 #1438
by vincent
problems of using git to fetch EMC2 was created by vincent
I did follow the steps of fetching EMC2 with git, but some of the timeout problems occured~~
first install git, then
root@vc-desktop:~# git clone git://git.linuxcnc.org/git/emc2.git emc2-dev
Initialized empty Git repository in /root/emc2-dev/.git/
git.linuxcnc.org[0: 76.79.58.172]: errno=Connection timed out
fatal: unable to connect a socket (Connection timed out)
fetch-pack from 'git://git.linuxcnc.org/git/emc2.git' failed.
is it because of the network problems???
besides, I tried to use the proxy, and tried again, but failed one more time~~!!
04 Jan 2010 15:52 #1439
by mozmck
Replied by mozmck on topic Re:problems of using git to fetch EMC2
That looks like network problems. Make the computer you are doing this on has a good internet connection, and try again later.
Time to create page: 0.164 seconds
