Need Help! Running EMC2
10 Jan 2010 14:39 #1484
by faran
Need Help! Running EMC2 was created by faran
hello everybody,
I'm new to Linux and Emc2, i install emc2 from live CD. and now i want to install it from source code. it built successfully. when i want to run it, i got this error in terminal:
Starting EMC2...
module_helper is not setuid root
Realtime system did not load
Shutting down and cleaning up EMC2...
RTAPI: ERROR: could not open shared memory (errno=13)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -9
NOTE: 'rtapi' kernel module must be loaded
Cleanup done
EMC terminated with an error. You can find more information in the log:
/home/faran/emc_debug.txt
and
/home/faran/emc_print.txt
NOTE: when i configure it as simulator (./configure --enable-run-in-place --enable-simulator
) it works correctly
thanks
Starting EMC2...
Cleanup done
and
thanks
10 Jan 2010 19:27 #1485
by cblack
Looks like you forgot the
sudo make setuid
command after compiling and your user doesn't have enough access to load the realtime drivers.
Replied by cblack on topic Re:Need Help! Running EMC2
sudo make setuid
12 Jan 2010 05:41 #1496
by faran
Replied by faran on topic Re:Need Help! Running EMC2
Dear cblack
I do these commands
$ cd src
$ ./configure --enable-run-in-place
$ make
$ sudo make setuid
after it completes and tell build successfully, when i run emc with this command
cd scripts
./emc
those error will appear in terminal
and if i don't run the last command "$ sudo make setuid" again, these error will appear.
I mean with or without this command i get this error
Starting EMC2...
I do these commands
$ cd src
$ make
$ sudo make setuid
cd scripts
./emc
Starting EMC2...
17 Jan 2010 13:10 #1527
by faran
my problem solve. that's for root.
I should use root user
17 Jan 2010 21:40 #1538
by acemi
Replied by acemi on topic Re:Need Help! Running EMC2
It's not a good idea to run EMC using root account.
Could you give the following command in the EMC src directory again and send the output?
sudo make setuid
sudo make setuid
21 Jan 2010 07:06 #1568
by faran
Dear acemi
this is the complete command that i enterd, and the output that i gave
$ cd src
$make clean
$ make
$ sudo make setuid
my output after enter "sudo make setuid"
[sudo] password for faran:
chown root ../bin/emc_module_helper
chmod 4750 ../bin/emc_module_helper
chown root ../bin/bfload
chmod 4750 ../bin/bfload
chown root ../bin/pci_write
chmod 4750 ../bin/pci_write
chown root ../bin/pci_read
chmod 4750 ../bin/pci_read
faran@faran-desktop:/media/Faran/Computer/EMC/Run_Emc/emc2-2.3.4/src$
and then I enter this command
$cd scripts
$./emc
and my complete output after running emc2 is:
EMC2 - 2.3.4
Machine configuration directory is '/home/faran/emc2/configs/stepper'
Machine configuration file is 'stepper_mm.ini'
Starting EMC2...
RTAPI: ERROR: could not open shared memory (errno=2)
Cleanup done
and
as well as in the output of the shell command 'dmesg' and in the terminal
faran@faran-desktop:/media/Faran/Computer/EMC/Run_Emc/emc2-2.3.4/scripts$
and now, in this state, if i enter these command
$sudo su
#./emc
the EMC2 run and and the axis.ngc loaded
and a guestion:
why is't good idea to run EMC using root account?
Thanks for your attention
$ cd src
$make clean
$ make
$ sudo make setuid
$cd scripts
$./emc
EMC2 - 2.3.4
Starting EMC2...
Cleanup done
and
$sudo su
#./emc
and a guestion:
21 Jan 2010 08:05 #1570
by acemi
Hi faran,
Could you send the output for the following commands?
$ ulimit -a
$ cat /etc/security/limits.conf
$ grep rtai /etc/udev/rules.d/*
$ ulimit -a
21 Jan 2010 10:28 #1575
by acemi
Is EMC directory in a FAT partition?
21 Jan 2010 11:13 #1578
by faran
Hi acemi
yes of course
faran@faran-desktop:~/Desktop$ ulimit -a
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 4095
max locked memory (kbytes, -l) 20480
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) 8192
cpu time (seconds, -t) unlimited
max user processes (-u) 4095
virtual memory (kbytes, -v) unlimited
file locks
faran@faran-desktop:~/Desktop$ cat /etc/security/limits.conf
# /etc/security/limits.conf
#Each line describes a limit for a user in the form:
#<domain> <type> <item> <value>
#Where:
#<domain> can be:
# - an user name
# - a group name, with @group syntax
# - the wildcard *, for default entry
# - the wildcard %, can be also used with %group syntax,
# for maxlogin limit
#<type> can have the two values:
# - "soft" for enforcing the soft limits
# - "hard" for enforcing hard limits
#<item> can be one of the following:
# - core - limits the core file size (KB)
# - data - max data size (KB)
# - fsize - maximum filesize (KB)
# - memlock - max locked-in-memory address space (KB)
# - nofile - max number of open files
# - rss - max resident set size (KB)
# - stack - max stack size (KB)
# - cpu - max CPU time (MIN)
# - nproc - max number of processes
# - as - address space limit
# - maxlogins - max number of logins for this user
# - maxsyslogins - max number of logins on the system
# - priority - the priority to run user process with
# - locks - max number of file locks the user can hold
# - sigpending - max number of pending signals
# - msgqueue - max memory used by POSIX message queues (bytes)
# - nice - max nice priority allowed to raise to
# - rtprio - max realtime priority
# - chroot - change root to directory (Debian-specific)
#* soft core 0
#* hard rss 10000
#@student hard nproc 20
#@faculty soft nproc 20
#@faculty hard nproc 50
#ftp hard nproc 0
#ftp - chroot /ftp
#@student - maxlogins 4
# End of file
* hard memlock 20480 #EMC2
faran@faran-desktop:~/Desktop$ $ grep rtai /etc/udev/rules.d
bash: $: command not found
The grep is installed, but when i run your command, the command not found
No, It is in a NTFS partition
yes of course
$ ulimit -a[/b]
file locks
#Where:
#<domain> can be:
# - an user name
#* soft core 0
#* hard rss 10000
#ftp hard nproc 0
#ftp - chroot /ftp
# End of file
21 Jan 2010 17:21 #1579
by acemi
I think that it is not possible to set user ID bit in NTFS partition. This is for ext2/ext3 partition.Therefore the normal users can not run the program (like module_helper) with root privileges.
If you compile EMC in an ext3 partition, this problem will disappear
Time to create page: 0.414 seconds
