newbie questions
25 Apr 2009 17:48 #156
by yol
newbie questions was created by yol
Hi all,
I have a starting problem with the 8.04 ubuntu version.
The installation of the OS went well and so was the configuring with the wizard. however when i go to run the EMC2 itself, the software starts but then i get a message the program had to be terminated with all sort of linux terminal lines - and it turns off.
i cant get it to even start.
any ideas/help will be appreciated.
Thanks!
Thanks!
25 Apr 2009 19:21 #157
by BigJohnT
Replied by BigJohnT on topic Re:newbie questions
Sounds like you have something in your configuration that is halting the start up of EMC. You can copy and paste the error message to a file and attach it to a post and someone can tell what the error is. Nine times out of ten the root of the error is in the last few lines.
Can you open a configuration from the EMC2 Configuration Selector (Applications/CNC/EMC2)?
