Who has 8.04 working with good graphics?
25 Feb 2010 13:08 #2059
by greeder88
Who has 8.04 working with good graphics? was created by greeder88
I tried a new ATI graphics card and not getting good graphics with it using
8.04. Went through a bunch of drivers and configurations.
Who has good graphics and what card are you using?
26 Feb 2010 04:51 #2068
Replied by cmorley on topic Re:Who has 8.04 working with good graphics?
Explain the problem.
AXIS preview garbled?
26 Feb 2010 10:44 #2071
by greeder88
Replied by greeder88 on topic Re:Who has 8.04 working with good graphics?
My screen goes beyond the bottom of the page slightly and the text is crunched up a bit.
My monitor keeps saying I need 1024x768 60hz at boot up.
I think it might be a refresh problem. I have 1024x768 61hz
I think it should be 60 and not 61,
Here is a copy of my xorg.conf
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
SubSection "Display"
Depth 24
Modes "1024x768"
EndSubSection
Defaultdepth 24
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "vesa"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc101"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen "Default Screen"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
Horizsync 31.5 - 48.0
Vertrefresh 56.0 - 65.0
EndSection
Section "Extensions"
EndSection
Section "Screen"
Depth 24
Modes "1024x768"
EndSubSection
Defaultdepth 24
EndSection
Section "Device"
Driver "vesa"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
EndSection
Section "Monitor"
EndSection
EndSection
26 Feb 2010 11:15 #2073
by andreas59
Replied by andreas59 on topic Re:Who has 8.04 working with good graphics?
Hi greeder!
Just a suggestion. Try to change the vertrefresh to 56.0 - 60.0.
Andreas.
Andreas.
26 Feb 2010 11:36 #2074
by greeder88
Changing to 56.0 - 60.0 didn't do anything.
26 Feb 2010 23:17 #2082
by andreas59
Also Horizsync would be of interest.
Did you have a look on 'man xorg.conf' yet?
If not you should possibly do so.
27 Feb 2010 13:34 #2087
by greeder88
I was able to get my graphics sized right by putting the size in millimeters for my 15" monitor
in the xorg.conf file under the Monitor section.
DisplaySize 300 210
I still have garbage on boot up and my monitor telling me I am not in 1024x768@ 60
probably because it says 72 now in the refresh rate but everything is working.
Maybe I can play around and get the monitor to get the proper size signal.
I would stay away from the ATI HD 4350 pcie card. Probably forcing a square peg in a round hole here.
DisplaySize 300 210
27 Feb 2010 18:41 #2098
by andreas59
As I've seen in your xorg.conf your hsync is set to a max of 48 kHz
For 1280x1024 you need settings like the following.
(II) MGA(0): Configured Monitor: Using hsync range of 30.00-82.00 kHz
(II) MGA(0): Configured Monitor: Using vrefresh range of 56.00-76.00 Hz
For 1024x768 it should be enough if you have hsync of 72 kHZ
Time to create page: 0.203 seconds
