need help for installing
- zam
- Topic Author
- Visitor
20 Mar 2010 07:30 - 20 Mar 2010 07:34 #2382
by zam
need help for installing was created by zam
when i install emc ,i matter with the folowing problem:
No. 1 step : ./figure
result :
# EMC2 - Enhanced Machine Controller #
# EMC2 is a software system for computer control of machine tools, #
# such as milling machines. EMC2 is released under the GPL. #
# Check out www.linuxcnc.org/ for more details. #
# It seems that ./configure completed successfully. #
# However, the configuration is for a simulator only, no RT #
# capabilities will be used. In this mode no control of hardware #
# is possible. Drivers won't be built. #
# If things don't work check config.log for errors & warnings #
# Next compile by typing #
# make #
# Before running the software, set the emc environment: #
# . (top dir)/scripts/emc-environment #
# To run the software type #
# emc #
No. 2 step : make clean
No. 3 step :
Compiling emc/rs274ngc/interp_write.cc
Compiling emc/rs274ngc/interp_o_word.cc
Compiling emc/rs274ngc/rs274ngc_errors.cc
Compiling emc/rs274ngc/rs274ngc_pre.cc
Linking librs274.so.0
Linking milltask
Compiling emc/canterp/canterp.cc
Linking milltaskcanon
Compiling emc/iotask/ioControl.cc
Linking io
ln -sf ../lib/librs274.so.0 ../lib/librs274.so
Compiling emc/sai/saicanon.cc
Compiling emc/sai/driver.cc
emc/sai/driver.cc: In function ‘int interpret_from_keyboard(int, int)’:
emc/sai/driver.cc:147: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result
emc/sai/driver.cc: In function ‘int interpret_from_file(int, int, int)’:
emc/sai/driver.cc:230: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result
emc/sai/driver.cc:254: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result
emc/sai/driver.cc: In function ‘int read_tool_file(char*)’:
emc/sai/driver.cc:316: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result
emc/sai/driver.cc: In function ‘int designate_parameter_file(char*)’:
emc/sai/driver.cc:410: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result
emc/sai/driver.cc: In function ‘int adjust_error_handling(int, int*, int*)’:
emc/sai/driver.cc:493: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result
emc/sai/driver.cc: In function ‘int main(int, char**)’:
emc/sai/driver.cc:645: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result
Linking rs274
g++ -L/usr/local/lib -Wl,-rpath,/usr/local/lib -o ../bin/rs274 objects/emc/sai/saicanon.o objects/emc/sai/driver.o ../lib/librs274.so.0 ../lib/libemcini.so.0 -Wall -g -I. -I/work/cnc/emc2-2.3.4/src/include -DULAPI -D_GNU_SOURCE -Os -DLOCALE_DIR=\"/usr/share/locale\" -DPACKAGE=\"emc2\"
msgfmt -o po/de_rs274_err.mo po/de_rs274_err.po
copying de message catalog
msgfmt -o po/fr_rs274_err.mo po/fr_rs274_err.po
copying fr message catalog
msgfmt -o po/it_rs274_err.mo po/it_rs274_err.po
copying it message catalog
msgfmt -o po/pl_rs274_err.mo po/pl_rs274_err.po
copying pl message catalog
none -k_ -o po/rs274_err.pot emc/task/emctaskmain.cc emc/rs274ngc/interp_arc.cc emc/rs274ngc/interp_array.cc emc/rs274ngc/interp_check.cc emc/rs274ngc/interp_convert.cc emc/rs274ngc/interp_queue.cc emc/rs274ngc/interp_cycles.cc emc/rs274ngc/interp_execute.cc emc/rs274ngc/interp_find.cc emc/rs274ngc/interp_internal.cc emc/rs274ngc/interp_inverse.cc emc/rs274ngc/interp_read.cc emc/rs274ngc/interp_write.cc emc/rs274ngc/interp_o_word.cc emc/rs274ngc/rs274ngc_errors.cc emc/rs274ngc/rs274ngc_pre.cc && touch po/rs274_err.pot
/bin/sh: none: not found
make: *** [po/rs274_err.pot] Error 127
why ?
can you help me ? thanks!
result :
# make #
# emc #
No. 3 step :
Linking milltask
Linking io
Linking rs274
why ?
Last edit: 20 Mar 2010 07:34 by zam.
07 Apr 2010 00:24 #2532
by andreas59
Replied by andreas59 on topic Re:need help for installing
If you want help you have at least to describe your problem more precise!
Tell us what you have done. Tell us about your hardware and so on.
Andreas.
Andreas.
Time to create page: 0.158 seconds
