help reading this error log
23 Apr 2010 22:50 - 23 Apr 2010 23:09 #2661
by sully0400
help reading this error log was created by sully0400
i think my problem is the add on port card. my computer has a pararell port on the mb but no connector. so i tryed with it disabled and not disabled. how can i check to see if linux detects my port card and the address is corect. or other sugestions if the below file says other.
thanks
I used the stepconf and this is the result when runing the created 'profile'
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=emcsh
EMC2_IOSH=iosh
EMC2 - 2.3.5
Machine configuration directory is '/home/cnc/emc2/configs'
Machine configuration file is ''
Could not find ini file '/home/cnc/emc2/configs/'
Kernel message information:
[ 0.000000] Linux version 2.6.24-16-rtai (root@hardy) (gcc version 4.2.3 (Ubuntu 4.2.3-2ubuntu7)) #1 Tue Sep 30 22:54:33 EEST 2008 (Ubuntu 2.6.24-12.22-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ffa0000 (usable)
[ 0.000000] BIOS-e820: 000000007ffa0000 - 000000007ffae000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007ffae000 - 000000007fff0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fff0000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] 1151MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 524192) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 524192
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 524192
[ 0.000000] On node 0 totalpages: 524192
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2303 pages used for memmap
[ 0.000000] HighMem zone: 292513 pages, LIFO batch:31
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI present.
[ 0.000000] Allocating PCI resources starting at 88000000 (gap: 80000000:7ec00000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520097
[ 0.000000] Kernel command line: root=UUID=84ffd229-6ea4-4c8a-a2d8-b2a89245b9d4 ro quiet splash
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Detected 2812.823 MHz processor.
[ 29.345967] I-pipe 2.0-04: pipeline enabled.
[ 29.345975] spurious 8259A interrupt: IRQ7.
[ 29.347737] Console: colour VGA+ 80x25
[ 29.347739] console [tty0] enabled
[ 29.347931] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 29.348165] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 29.387525] Memory: 2068716k/2096768k available (1440k kernel code, 26752k reserved, 573k data, 228k init, 1179264k highmem)
[ 29.387530] virtual kernel memory layout:
[ 29.387531] fixmap : 0xfffed000 - 0xfffff000 ( 72 kB)
[ 29.387532] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 29.387533] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 29.387534] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 29.387535] .init : 0xc02fa000 - 0xc0333000 ( 228 kB)
[ 29.387535] .data : 0xc026836d - 0xc02f77ec ( 573 kB)
[ 29.387536] .text : 0xc0100000 - 0xc026836d (1440 kB)
[ 29.387539] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 29.387561] SLUB: Genslabs=11, HWalign=64, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
[ 29.467572] Calibrating delay using timer specific routine.. 5628.08 BogoMIPS (lpj=11256171)
[ 29.467587] Security Framework initialized
[ 29.467590] SELinux: Disabled at boot.
[ 29.467597] AppArmor: AppArmor initialized
[ 29.467600] Failure registering capabilities with primary security module.
[ 29.467604] Mount-cache hash table entries: 512
[ 29.467665] CPU: After generic identify, caps: 178bfbff efd3fbff 00000000 00000000 00802009 00000000 000037ff 00000000
[ 29.467670] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 29.467671] CPU: L2 Cache: 1024K (64 bytes/line)
[ 29.467673] CPU: After all inits, caps: 178bfbff efd3fbff 00000000 00000510 00802001 00000000 000037ff 00000000
[ 29.467679] Compat vDSO mapped to ffffe000.
[ 29.467684] CPU: AMD Athlon(tm) II X2 240 Processor stepping 02
[ 29.467687] Checking 'hlt' instruction... OK.
[ 29.483670] Freeing SMP alternatives: 0k freed
[ 29.483768] net_namespace: 64 bytes
[ 29.483999] NET: Registered protocol family 16
[ 29.484081] EISA bus registered
[ 29.484808] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=4
[ 29.484810] PCI: Using configuration type 1
[ 29.484811] Setting up standard PCI resources
[ 29.489521] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 29.489618] PCI: Probing PCI hardware
[ 29.489622] PCI: Probing PCI hardware (bus 00)
[ 29.490088] PCI: Transparent bridge - 0000:00:04.0
[ 29.490826] PCI: Using IRQ router default [10de/03e0] at 0000:00:01.0
[ 29.503658] AppArmor: AppArmor Filesystem Enabled
[ 29.503851] PCI: Bridge: 0000:00:04.0
[ 29.503852] IO window: disabled.
[ 29.503855] MEM window: disabled.
[ 29.503856] PREFETCH window: disabled.
[ 29.503859] PCI: Bridge: 0000:00:09.0
[ 29.503860] IO window: d000-dfff
[ 29.503862] MEM window: dc000000-dfefffff
[ 29.503864] PREFETCH window: c0000000-cfffffff
[ 29.503866] PCI: Bridge: 0000:00:0b.0
[ 29.503867] IO window: e000-efff
[ 29.503869] MEM window: dff00000-dfffffff
[ 29.503871] PREFETCH window: disabled.
[ 29.503872] PCI: Bridge: 0000:00:0c.0
[ 29.503873] IO window: disabled.
[ 29.503875] MEM window: disabled.
[ 29.503876] PREFETCH window: disabled.
[ 29.503883] PCI: Setting latency timer of device 0000:00:04.0 to 64
[ 29.503888] PCI: Setting latency timer of device 0000:00:09.0 to 64
[ 29.503893] PCI: Setting latency timer of device 0000:00:0b.0 to 64
[ 29.503898] PCI: Setting latency timer of device 0000:00:0c.0 to 64
[ 29.503904] NET: Registered protocol family 2
[ 29.507579] Time: tsc clocksource has been installed.
[ 29.539622] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 29.539759] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 29.540142] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[ 29.540269] TCP: Hash tables configured (established 131072 bind 65536)
[ 29.540271] TCP reno registered
[ 29.551670] checking if image is initramfs... it is
[ 29.918956] Freeing initrd memory: 6851k freed
[ 29.919184] audit: initializing netlink socket (disabled)
[ 29.919192] audit(1272047567.532:1): initialized
[ 29.919287] highmem bounce pool size: 64 pages
[ 29.920067] VFS: Disk quotas dquot_6.5.1
[ 29.920081] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 29.920138] io scheduler noop registered
[ 29.920139] io scheduler anticipatory registered
[ 29.920140] io scheduler deadline registered
[ 29.920146] io scheduler cfq registered (default)
[ 29.951568] Boot video device is 0000:02:00.0
[ 29.951655] PCI: Setting latency timer of device 0000:00:09.0 to 64
[ 29.951671] assign_interrupt_mode Found MSI capability
[ 29.951673] Allocate Port Service[0000:00:09.0:pcie00]
[ 29.951707] PCI: Setting latency timer of device 0000:00:0b.0 to 64
[ 29.951723] assign_interrupt_mode Found MSI capability
[ 29.951725] Allocate Port Service[0000:00:0b.0:pcie00]
[ 29.951756] PCI: Setting latency timer of device 0000:00:0c.0 to 64
[ 29.951772] assign_interrupt_mode Found MSI capability
[ 29.951774] Allocate Port Service[0000:00:0c.0:pcie00]
[ 29.951846] isapnp: Scanning for PnP cards...
[ 30.304705] isapnp: No Plug & Play device found
[ 30.317449] Real Time Clock Driver v1.12ac
[ 30.317452] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 30.317541] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 30.318011] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 30.318054] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 30.318108] PNP: No PS/2 controller found. Probing ports directly.
[ 30.318407] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 30.318410] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 30.319952] mice: PS/2 mouse device common for all mice
[ 30.320015] EISA: Probing bus 0 at eisa.0
[ 30.329060] EISA: slot 4 : @@@0000 detected (disabled).
[ 30.329086] EISA: Detected 1 card.
[ 30.329133] NET: Registered protocol family 1
[ 30.329141] Using IPI Shortcut mode
[ 30.329206] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 30.329207] EDD information not available.
[ 30.329255] Freeing unused kernel memory: 228k freed
[ 31.143459] Clocksource tsc unstable (delta = 144037932 ns)
[ 31.147454] Time: pit clocksource has been installed.
[ 31.462400] fuse init (API version 7.9)
[ 31.576598] usbcore: registered new interface driver usbfs
[ 31.576612] usbcore: registered new interface driver hub
[ 31.576642] usbcore: registered new device driver usb
[ 31.577040] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 31.577064] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 31.577066] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 31.577207] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
[ 31.577217] ohci_hcd 0000:00:02.0: irq 7, io mem 0xdbf7f000
[ 31.594613] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 31.594617] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 31.610827] SCSI subsystem initialized
[ 31.630100] libata version 3.00 loaded.
[ 31.633486] usb usb1: configuration #1 chosen from 1 choice
[ 31.633499] hub 1-0:1.0: USB hub found
[ 31.633504] hub 1-0:1.0: 10 ports detected
[ 31.735525] PCI: Setting latency timer of device 0000:00:02.1 to 64
[ 31.735528] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 31.735543] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
[ 31.735561] ehci_hcd 0000:00:02.1: debug port 1
[ 31.735564] PCI: cache line size of 64 is not supported by device 0000:00:02.1
[ 31.735570] ehci_hcd 0000:00:02.1: irq 10, io mem 0xdbf7ec00
[ 31.747398] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 31.747465] usb usb2: configuration #1 chosen from 1 choice
[ 31.747477] hub 2-0:1.0: USB hub found
[ 31.747480] hub 2-0:1.0: 10 ports detected
[ 31.851485] NFORCE-MCP61: IDE controller (0x10de:0x03ec rev 0xa2) at PCI slot 0000:00:06.0
[ 31.851498] NFORCE-MCP61: not 100% native mode: will probe irqs later
[ 31.851503] NFORCE-MCP61: 0000:00:06.0 (rev a2) UDMA133 controller
[ 31.851508] ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
[ 31.851512] NFORCE-MCP61: IDE port disabled
[ 31.851515] Probing IDE interface ide0...
[ 32.391367] usb 2-2: new high speed USB device using ehci_hcd and address 2
[ 32.524800] usb 2-2: configuration #1 chosen from 1 choice
[ 32.525362] hub 2-2:1.0: USB hub found
[ 32.525609] hub 2-2:1.0: 4 ports detected
[ 32.867331] usb 2-5: new high speed USB device using ehci_hcd and address 3
[ 33.001235] usb 2-5: configuration #1 chosen from 1 choice
[ 33.183360] usbcore: registered new interface driver libusual
[ 33.185672] Initializing USB Mass Storage driver...
[ 33.259382] hda: PIONEER DVD-RW DVR-104, ATAPI CD/DVD-ROM drive
[ 33.259400] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 35.145708] hda: UDMA/33 mode selected
[ 35.147705] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 35.147823] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.61.
[ 35.147836] PCI: Setting latency timer of device 0000:00:07.0 to 64
[ 35.303122] usb 1-6: new low speed USB device using ohci_hcd and address 2
[ 35.470968] usb 1-6: configuration #1 chosen from 1 choice
[ 35.667427] forcedeth 0000:00:07.0: ifname eth0, PHY OUI 0x20 @ 1, addr 40:61:86:05:af:9e
[ 35.667431] forcedeth 0000:00:07.0: highdma pwrctl mgmt timirq lnktim msi desc-v3
[ 35.669206] sata_nv 0000:00:08.0: version 3.5
[ 35.669232] PCI: Setting latency timer of device 0000:00:08.0 to 64
[ 35.670671] scsi0 : sata_nv
[ 35.671205] scsi1 : sata_nv
[ 35.671219] ata1: SATA max UDMA/133 cmd 0xc400 ctl 0xc080 bmdma 0xb880 irq 10
[ 35.671222] ata2: SATA max UDMA/133 cmd 0xc000 ctl 0xbc00 bmdma 0xb888 irq 10
[ 35.675438] usb 2-2.2: new low speed USB device using ehci_hcd and address 5
[ 35.772599] usb 2-2.2: configuration #1 chosen from 1 choice
[ 35.971396] usb 2-2.3: new low speed USB device using ehci_hcd and address 6
[ 36.073058] usb 2-2.3: configuration #1 chosen from 1 choice
[ 36.085047] scsi2 : SCSI emulation for USB Mass Storage devices
[ 36.085559] usbcore: registered new interface driver usb-storage
[ 36.085562] USB Mass Storage support registered.
[ 36.085608] usbcore: registered new interface driver hiddev
[ 36.085633] usb-storage: device found at 3
[ 36.085634] usb-storage: waiting for device to settle before scanning
[ 36.092943] input: Primax HP Wireless Eco-Comfort Mobile Mouse as /devices/pci0000:00/0000:00:02.0/usb1/1-6/1-6:1.0/input/input1
[ 36.107103] input,hiddev96,hidraw0: USB HID v1.11 Mouse [Primax HP Wireless Eco-Comfort Mobile Mouse] on usb-0000:00:02.0-6
[ 36.109342] input: Kensington Kensington USB/PS2 Orbit as /devices/pci0000:00/0000:00:02.1/usb2/2-2/2-2.2/2-2.2:1.0/input/input2
[ 36.120229] input,hidraw1: USB HID v1.10 Mouse [Kensington Kensington USB/PS2 Orbit] on usb-0000:00:02.1-2.2
[ 36.122351] input: USB USB Keykoard as /devices/pci0000:00/0000:00:02.1/usb2/2-2/2-2.3/2-2.3:1.0/input/input3
[ 36.131086] input,hidraw2: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-0000:00:02.1-2.3
[ 36.139058] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 36.147346] ata1.00: ATA-8: ST3750528AS, CC38, max UDMA/133
[ 36.147349] ata1.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 36.163351] ata1.00: configured for UDMA/133
[ 36.631022] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 36.640363] ata2.00: ATA-7: SAMSUNG HD161GJ, 1AC01118, max UDMA7
[ 36.640366] ata2.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 36.647230] ata2.00: configured for UDMA/133
[ 36.647291] scsi 0:0:0:0: Direct-Access ATA ST3750528AS CC38 PQ: 0 ANSI: 5
[ 36.647534] scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD161GJ 1AC0 PQ: 0 ANSI: 5
[ 36.647585] PCI: Setting latency timer of device 0000:00:08.1 to 64
[ 36.647735] scsi3 : sata_nv
[ 36.647825] scsi4 : sata_nv
[ 36.647838] ata3: SATA max UDMA/133 cmd 0xb800 ctl 0xb480 bmdma 0xb000 irq 10
[ 36.647840] ata4: SATA max UDMA/133 cmd 0xb400 ctl 0xb080 bmdma 0xb008 irq 10
[ 36.960123] ata3: SATA link down (SStatus 0 SControl 300)
[ 37.278957] ata4: SATA link down (SStatus 0 SControl 300)
[ 37.296214] Driver 'sd' needs updating - please use bus_type methods
[ 37.296266] sd 0:0:0:0: [sda] 1465149168 512-byte hardware sectors (750156 MB)
[ 37.296274] sd 0:0:0:0: [sda] Write Protect is off
[ 37.296276] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 37.296284] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 37.296309] sd 0:0:0:0: [sda] 1465149168 512-byte hardware sectors (750156 MB)
[ 37.296313] sd 0:0:0:0: [sda] Write Protect is off
[ 37.296315] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 37.296321] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 37.296324] sda:<6>hda: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2000kB Cache
[ 37.303078] Uniform CD-ROM driver Revision: 3.20
[ 37.321948] sda1 sda2 sda3 < sda5 > sda4
[ 37.332873] sd 0:0:0:0: [sda] Attached SCSI disk
[ 37.332908] sd 1:0:0:0: [sdb] 312581808 512-byte hardware sectors (160042 MB)
[ 37.332914] sd 1:0:0:0: [sdb] Write Protect is off
[ 37.332916] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 37.332924] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 37.332945] sd 1:0:0:0: [sdb] 312581808 512-byte hardware sectors (160042 MB)
[ 37.332950] sd 1:0:0:0: [sdb] Write Protect is off
[ 37.332951] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 37.332958] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 37.332960] sdb: sdb1 sdb2 sdb3 sdb4 < sdb5 >
[ 37.362183] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 37.364740] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 37.364753] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 41.090831] usb-storage: device scan complete
[ 41.091194] scsi 2:0:0:0: Direct-Access Gigaware 8.02 PQ: 0 ANSI: 0 CCS
[ 41.093788] sd 2:0:0:0: [sdc] 31301631 512-byte hardware sectors (16026 MB)
[ 41.094412] sd 2:0:0:0: [sdc] Write Protect is off
[ 41.094414] sd 2:0:0:0: [sdc] Mode Sense: 45 00 00 08
[ 41.094415] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 41.096536] sd 2:0:0:0: [sdc] 31301631 512-byte hardware sectors (16026 MB)
[ 41.097160] sd 2:0:0:0: [sdc] Write Protect is off
[ 41.097162] sd 2:0:0:0: [sdc] Mode Sense: 45 00 00 08
[ 41.097163] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 41.097165] sdc: sdc1
[ 41.098302] sd 2:0:0:0: [sdc] Attached SCSI removable disk
[ 41.098322] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 46.138335] /home/juve/hardy-packages/linux-git/ubuntu-hardy/debian/build/custom-source-rtai/drivers/hid/usbhid/hid-core.c: usb_submit_urb(ctrl) failed
[ 46.138349] /home/juve/hardy-packages/linux-git/ubuntu-hardy/debian/build/custom-source-rtai/drivers/hid/usbhid/hid-core.c: timeout initializing reports
[ 46.138422] input: USB USB Keykoard as /devices/pci0000:00/0000:00:02.1/usb2/2-2/2-2.3/2-2.3:1.1/input/input4
[ 46.150249] input,hidraw3: USB HID v1.10 Device [USB USB Keykoard] on usb-0000:00:02.1-2.3
[ 46.150260] usbcore: registered new interface driver usbhid
[ 46.150263] /home/juve/hardy-packages/linux-git/ubuntu-hardy/debian/build/custom-source-rtai/drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
[ 46.243836] kjournald starting. Commit interval 5 seconds
[ 46.243846] EXT3-fs: mounted filesystem with ordered data mode.
[ 50.000745] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 50.011463] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x4d00
[ 50.011472] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x4e00
[ 50.542514] PCI: Setting latency timer of device 0000:00:05.0 to 64
[ 50.576592] hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
[ 52.312867] lp: driver loaded but no devices found
[ 52.362307] Adding 9999352k swap on /dev/sda5. Priority:-1 extents:1 across:9999352k
[ 52.883678] EXT3 FS on sdb1, internal journal
[ 53.905754] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 54.669129] ppdev: user-space parallel port driver
[ 54.750832] audit(1272061992.520:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=4465 profile="/usr/sbin/cupsd" namespace="default"
[ 55.780708] Bluetooth: Core ver 2.11
[ 55.783284] NET: Registered protocol family 31
[ 55.783287] Bluetooth: HCI device and connection manager initialized
[ 55.783289] Bluetooth: HCI socket layer initialized
[ 55.795665] Bluetooth: L2CAP ver 2.9
[ 55.795668] Bluetooth: L2CAP socket layer initialized
[ 55.807005] Bluetooth: RFCOMM socket layer initialized
[ 55.807313] Bluetooth: RFCOMM TTY layer initialized
[ 55.807315] Bluetooth: RFCOMM ver 1.8
[ 59.924121] NET: Registered protocol family 17
[ 64.810693] NET: Registered protocol family 10
[ 64.810799] lo: Disabled Privacy Extensions
[ 75.287785] eth0: no IPv6 routers present
[ 144.734008] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 144.739190] ISOFS: changing to secondary root
Debug file information:
(empty)
thanks
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=emcsh
EMC2_IOSH=iosh
EMC2 - 2.3.5
(empty)
Last edit: 23 Apr 2010 23:09 by sully0400.
24 Apr 2010 05:05 #2665
by sully0400
Replied by sully0400 on topic Re:help reading this error log
I have 2 hdd's and about 8 partitions and this I noticed (Could not find ini file '/home/cnc/emc2/configs/) in the error report. Could I need to rename or move a file?
help
help
25 Apr 2010 22:20 #2707
by andreas59
Replied by andreas59 on topic Re:help reading this error log
to see if your printer port is set up correctly use "lspci -v" and search for "parallel controller" in the output.
25 Apr 2010 22:47 #2710
by BigJohnT
Replied by BigJohnT on topic Re:help reading this error log
Did you put a space in your config name? That will make EMC not load... For long posts using something like pastebin.ca or similar or save it to a text file makes for easier reading.
30 Apr 2010 04:50 #2759
by sully0400
It was the printer port but I had to find it in windows because I can't figure out how to use things like lspci-v? terminal/package manerger? I would love to know
30 Apr 2010 11:09 #2762
by BigJohnT
Did you read the short linux section in the Getting Started Guide?
www.linuxcnc.org/docview/html//common_Linux_FAQ.html
30 Apr 2010 17:24 #2764
by sully0400
I will thanks. I'm psyched now that every thing works
Time to create page: 0.190 seconds
