Trouble getting 2.3.0 to run
19 May 2009 08:27 #308
by alex_joni
Replied by alex_joni on topic Re:Trouble getting 2.3.0 to run
acondit wrote:
The important error is in there (just at the end):
[drm:drm_lock_take] *ERROR* 3 holds heavyweight lock
It seems that 3D operation locks your X-server. (maybe Ctrl-Alt-backspace will save you from completely rebooting the next time).
Try running glxgears or some similar 3D app, which should prove that it's not AXIS related.
I would probably attempt to switch video drivers.
Regards,
Alex
OK, I guess you can only attach one file to a message.
so here is the other:
Regards,
Alex
19 May 2009 15:38 #310
by acondit
Replied by acondit on topic Re:Trouble getting 2.3.0 to run
alex_joni wrote:
Alex (and John),
Thanks, I changed drivers and it is now working. I changed to the vesa driver (even though the vesa driver wouldn't work on my other box).
For me the suggestion to try tkemc identified the problem as relating to "axis" as opposed to "emc2" or "rtai". I was not suggesting that the problem was in "axis" itself because I knew that it worked but rather how my system functioned with it under 8.04 versus 6.06. That change (using tkemc instead of axis) fairly clearly pointed to a video problem. I was afraid that meant finding yet another video card, but happily just changing the driver solved the problem.
Alex, I saw the lock message but didn't know what it was telling me.
Thanks again to both of you.
Alan
Regards,
Alex
Alex (and John),
Alan
Time to create page: 0.162 seconds
