Install CD Freezing Before Boot
- InfinityMax
24 Jun 2010 00:52 #3202
by InfinityMax
Install CD Freezing Before Boot was created by InfinityMax
This is kind of an odd problem, and I'm a little embarrassed to be asking. This shouldn't be hard, but I have very little experience with Linux, and I'm not sure what's happening with the computer I'm attempting to use to run EMC.
I've burned the image file to a CD, and it's definitely burned as an image, not a file. I've even checked the CD on my main computer, and I can see all the files and the cool little Ubuntu logo.
But when I put the disc into the dedicated computer, it posts, and then it loads to a black screen with the following white letters across the top:
ISOLINUX 3.53 Debian-2007-12-11 Copyright (c) 1994-2007 H. Peter Anvin
And then it stays there. Nothing more happens.
Here are some fixes I have tried:
* I burned the CD with Windows XP. That one did the one-line/black screen thing, so I tried it with Nero. Same. Then I tried it with Infrarecorder. Same results.
* I booted through the boot menu, manually choosing the CD. Same thing.
* I turned off Fast Boot in the BIOS, and got the same results... but slower.
Of course, maybe this is what's supposed to happen. Maybe I just need to walk away from it for a couple hours and let it do whatever it wants to do. But I don't know, because this is as far as I can get.
Sorry to crash the party just to complain. Any help would rule.
24 Jun 2010 01:22 #3203
by BigJohnT
Replied by BigJohnT on topic Re:Install CD Freezing Before Boot
Older motherboard or newer motherboard?
8.04 LiveCD?
I've had to download the 8.04.4 Ubuntu CD and install that on a newer motherboard then install EMC.
Older hardware you might need to use the 6.06 LiveCD.
8.04 LiveCD?
- InfinityMax
25 Jun 2010 01:51 - 25 Jun 2010 03:44 #3205
by InfinityMax
Replied by InfinityMax on topic Re:Install CD Freezing Before Boot
It's a fairly old Dell. I'm mostly using it because it has a parallel port, and my new one doesn't.
I'll give 6.06 a shot. Knock on wood. Thanks for the help.
UPDATE: That was it. The 6.06 booted right up. Thank you!
Last edit: 25 Jun 2010 03:44 by InfinityMax.
25 Jun 2010 11:47 #3206
by BigJohnT
Glad you got it working. Now the fun begins...
Time to create page: 0.107 seconds
