Problem install LinuxCNC noteboook Lenovo E460
18 Mar 2017 16:36 #89858
by Asiva
Replied by Asiva on topic Problem install LinuxCNC noteboook Lenovo E460
cncnoob1979
Can you help me fix the problem?
Attachment not found
18 Mar 2017 16:41 #89859
by Asiva
18 Mar 2017 16:55 #89860
by Asiva
Everything do as in Post 1 .
Get success folders with files home/ LinuxCNC- dev / debian/
but get error in the step
dpkg-checkbuilddeps
dpkg-checkbuilddeps
- Thank you received: 5928
18 Mar 2017 17:36 #89862
Replied by tommylight on topic Problem install LinuxCNC noteboook Lenovo E460
You are in the wrong directory.
You need to be in
/linuxcnc-dev/debian/ run ./configure
And then check dependencies in linuxcnc-dev
You need to be in
- cncnoob1979
- Thank you received: 75
18 Mar 2017 22:24 #89869
by cncnoob1979
Replied by cncnoob1979 on topic Problem install LinuxCNC noteboook Lenovo E460
For your error you need to enable the source code repositories and then
sudo apt-get update
sudo apt-get update
- cncnoob1979
21 Mar 2017 17:06 #90017
by cncnoob1979
Did this fix your issue?
21 Mar 2017 17:20 #90019
He probably did as after a success people forget to write back, i know i did when i registered .
Time to create page: 0.144 seconds
