Upgrade from 2.7.8 to 2.8 Pre (Dev) and then to 2.8 Release
06 Apr 2017 11:50 #90967
by cts1085
I am currently running 2.7.8 and i setup a sandbox with 2.8 pre to see if some issues i am having are resolved and they are!
My question: What challenges will I run into if i take this upgrade path?
Start with 2.7.8 release - change distro references to 2.8 pre and update (making appropriate .inii/.hal changes
run for a while
change distro to 2.8 release once released
Does this make sense? is it appropriate?
Thanks for heads-up on any gotcha's...
run for a while
- Thank you received: 5926
06 Apr 2017 13:31 #90969
Replied by tommylight on topic Upgrade from 2.7.8 to 2.8 Pre (Dev) and then to 2.8 Release
If you are using debian wheezy iso from download section, that is all you have to do and it works without issues as far as i can tell, done it several times. The hal and ini rarely need to be modified as there is already a script that will change the entries for joit/axis automaticly.
06 Apr 2017 14:22 #90970
by cts1085
Replied by cts1085 on topic Upgrade from 2.7.8 to 2.8 Pre (Dev) and then to 2.8 Release
ok - i agree that works well from 2.7.8 to 2.8 (dev)
so what you are indicating is that when 2.8 is released (2.8.0 or 2.8.1) then changing the distro back should be all i need to do?
06 Apr 2017 14:37 #90971
Not the distro, just the entries in sources list, same thing you did to go from 2.7 to 2.8,
06 Apr 2017 14:44 #90972
by cts1085
Perfect - so the expectation would be that once 2.8 is released we update the sources and keep on trucking.
Awesome - sounds like I am hopping on the dev train!
06 Apr 2017 15:58 #90973
Usualy that is all it takes.
Welcome on board.
Welcome on board.
Time to create page: 0.173 seconds
