installing Debian 7 on a uefi only system (chuwi hibox)
16 Apr 2017 19:26 #91471
by trilobyte
installing Debian 7 on a uefi only system (chuwi hibox) was created by trilobyte
i bought a miniPC (Chuwi HiBox)
www.gearbest.com/tv-box-mini-pc/pp_590406.html
this would be a very interesting comuter for a cnc machine. smal, complete with all what i need for driving the 7i76e, but:
this is a new pice and the "bios" is working with EFI only.
out of the box came this little computer with different partitions. a dual boot menue was installed to choose between android 5 and windwos 10.
i made a bootable usb flash drive (using win32DiskImager) with Linuxmint 18.1
i installed mint (setup used the whole internal flash drive)
after that i tryed to install an older linux version. since i formated the internal flash drive of the chuwi hibox, the "bios" doesn't see the internal disks anymore.
next problem: if i try to install debian 7 then i have the problem that i can only choose the usb flash drive to install linux. the internal disk is not available.
i download the android and win images and installed the system as it was bevor my actions.
i see now in the "bios" the internal partitons an i can choose them to boot, but i'm still not able to choose the internal 64GB disk to install debian 7 on it.
what can i doo to solve this problem?
i was not able to compile linuxcnc and the requiered kernel. this is the reason why i try to install debian 7 with the preemtive kernel.
peter
peter
- Thank you received: 5951
16 Apr 2017 21:02 #91476
Replied by tommylight on topic installing Debian 7 on a uefi only system (chuwi hibox)
I think i read somewhere here that debian wheezy and preempt kernel do not work properly, but i never tested it.
That is not important in your case as debian wheezy will not work on UEFI boot, and there is the issue of latency, i can not find anyone here on the forum that has actually used it.
If all else fails, you can install and run Linux from a usb drive easily, it will take longer to boot but not by much, and if you have a fast USB3 drive it be will very fast. Just install as usual, you will need 2 USB drives, one for the Linux Mint and the other used as a hard drive.
16 Apr 2017 21:22 #91477
Replied by PCW on topic installing Debian 7 on a uefi only system (chuwi hibox)
Debian Wheezy runs fine with a Preempt-RT kernel (I have a LinuxCNC test station with > 1 year uptime
running our Ethernet cards with this combination)
However, 32 bit Debian 7 with its included ancient kernel is likely to have endless problems on such new hardware
I would start with 64 bit Mint 17.3 (or 18.1 if 17.3 does not work) and add the latest 64 bit Preempt-RT kernel (4.9.20-rt16)
Note that it will be slow going compiling a new kernel on that hardware
16 Apr 2017 22:03 #91479
by grump
Replied by grump on topic installing Debian 7 on a uefi only system (chuwi hibox)
I am using Debian stretch LXDE-core, kernel-image 4.9.0-1-amd64 with no issues.
I posted about it here forum.linuxcnc.org/9-installing-linuxcnc...-just-playing-around
download version2 and have fun.
16 Apr 2017 22:27 #91482
Thank you, Peter.
I was sure i read something about it i just could not recall what exactly.Debian Wheezy runs fine with a Preempt-RT kernel (I have a LinuxCNC test station with > 1 year uptime
Thank you, Peter.
16 Apr 2017 23:13 #91485
It may be the the stock Wheezy Preempt-RT kernel has issues,
but building an up-to-date Preempt-RT kernel is easy (and my Wheezy test system is running 4.1.xx)
16 Apr 2017 23:22 #91486
I have most computers on Mint 17.2 and 18.1, last night i did a Lubuntu install on a IBM T42 laptop, works quite nicely, had Ubuntu 10.04 on it.
17 Apr 2017 20:43 - 17 Apr 2017 20:46 #91541
by trilobyte
Replied by trilobyte on topic installing Debian 7 on a uefi only system (chuwi hibox)
i've done some tests. i think i have two problems.
1. I can install debian 7 or the actual live linuxcnc live image. in this case i'm able to get the 7i76e running with the preemtive kernel.
2. i can install mint 18.1 -> this is no problem to install on the HiBox. But if i try to go true the tutorial "Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb" at one point during the operations the computer freezes an i have do do a hard reset. this is at the moment not an option. i tryed this procedure on another machine and it worked.
Problem with debian 7: i can boot with the debian setup because there is an EFI in the Image. but if i boot this image, i can't install linux on the internal disk. during debian 7 setup i can't see this 64GB drive.
i think it can work with an live image. but these deb 7 live images don't have an EFI in the Image and i'm not able to boot with these images!
i suspect that it is possible to install on the internal disk if i can boot the live image and start the setup from this running system
hmm... any proposals?
is it possible to install debian 7 from a running live linuxmint 18.1?
Last edit: 17 Apr 2017 20:46 by trilobyte.
17 Apr 2017 21:14 #91546
Where exactly does the linuxCNC install on Mint18.1 fail?
18 Apr 2017 21:05 #91599
by trilobyte
Time to create page: 0.195 seconds
