installing Debian 7 on a uefi only system (chuwi hibox)
18 Apr 2017 21:24 #91602
Replied by PCW on topic installing Debian 7 on a uefi only system (chuwi hibox)
I would try compiling on a different system
or leave off the -j4
Does it always stop at the same compile step? (pktcdvd)
19 Apr 2017 18:03 #91662
by trilobyte
Replied by trilobyte on topic installing Debian 7 on a uefi only system (chuwi hibox)
19 Apr 2017 18:12 #91663
Does kind of look like flaky hardware or bad driver
is the system hung or just the graphics?
that is, does numlock still toggle?, can you log in on a virtual terminal?
(control-alt F1 to get virtual terminal 1 control-alt F7 to get back to X)
19 Apr 2017 18:47 #91666
by trilobyte
numlock wasn't toggling.
i started make deb-pkg without -j4
this is running at the moment. it takes a lot of time. (45min and is still running)
25 Apr 2017 15:30 - 25 Apr 2017 15:30 #92066
by trilobyte
i tried this: "or leave off the -j4"
without this -j4 it worked!
but i've a new problem. there is a hardware problem. it is like the arrow down on the keyboard is pressed all the time. it is in the uefi menue and also in linux. it is still the same problem if i disconnect the keyboard
i ordered a new board:
www.hitzestau.com/maker-board-up-squared-mit-intel-apollo-lake/
hope this is a better one
Last edit: 25 Apr 2017 15:30 by trilobyte.
27 May 2017 08:17 - 27 May 2017 08:25 #93696
by trilobyte
the up square isn't available until end of july. so i ordered an up board:
i have the same problem as with the chuwi hibox.
i can install Lubuntu 16.04
i can install Linuxmint 18.1
i can install ubilinux
but nothing debian based:
debian 7 and 8, and Linuxmint debian edition etc all these doesn't recognise the internal emmc storage!
i know there is an tread how to compile a new kernel and linuxcnc from the sources. but i prefer to download a RT kernel DEB (not available for Ubuntu 16.4, linuxmin 18.1 and ubilinux)
i found this deb: linux-image-4.9.0-0.bpo.2-rt-amd64-unsigned_4.9.18-1-bpo8+1_amd64.deb
my plan was to install jessie with RT and then use the buildbot to install linuxcnc.
i think i can not use the buildbot to install linuxcnc in linuxmint 18.1?
is there no way without debian 7 and 8 without compiling linuxcnc from the sources? i tryed this. but i get errors and warnings etc. it was running at the end. but i didn't trust this self compiled setup. i'll run big machines with this software. so i've to be shure that this works properly.
Last edit: 27 May 2017 08:25 by trilobyte.
29 May 2017 18:25 #93806
Replied by andypugh on topic installing Debian 7 on a uefi only system (chuwi hibox)
I think compiling your own LinuxCNC is the way most likely to work.
What flavour of realtime is in that kernel?
29 May 2017 18:28 #93807
by trilobyte
i think i need the preemtive RT for the Mesa 7i76e?
i already compiled the kernel for linux mint 18.1. this worked.
Time to create page: 0.169 seconds
