Need clarification on libxenomai-dev package
27 Jun 2017 03:12 - 27 Jun 2017 03:45 #95015
by sivaraj
Need clarification on libxenomai-dev package was created by sivaraj
Does it require libxenomai-dev for a RTAI or Preempt-RT install
Though libxenomai-dev is installed does it require for a RTAI or Preempt-RT install ?
The debian/configure scripts checks presence of libxenomai-dev installation and ask to enable deb-src repositories for compiling.
It appears, with case of RT-Preempt, does not install or download any additional package from deb-src
Why it is mandatory to enable deb-src repositories
Last edit: 27 Jun 2017 03:45 by sivaraj. Reason: typo
27 Jun 2017 21:14 #95074
Replied by andypugh on topic Need clarification on libxenomai-dev package
From IRC:
andypugh: He opines that: “The debian/configure scripts checks presence of libxenomai-dev installation and ask to enable deb-src repositories for compiling."
[10:08pm] jepler: yes that's correct
[10:08pm] andypugh: OK, I will reply that this is expected
[10:09pm] jepler: if there is a libxenomai-dev binary package known to apt-cache search, THEN debian/configure has to find its associated source package
[10:10pm] jepler: .. in order to know the correct list of Debian architectures where libxenomai-dev will be available
[10:10pm] jepler: if your /etc/apt/source.list configuration has libxenomai-dev as a BINARY PACKAGE but cannot find its ASSOCIATED SOURCE PACKAGE then your debian is misconfigured
[10:11pm] jepler: hoever, this seems to happen in practice in the jessie -> stretch update, because you might have leftover information about the jessie version of libxenomai-dev, but no information about the source package because libxenomai-dev is NOT IN debian stretch
[10:11pm] jepler: or you might have it because your distro is just misconfigured to begin with, by not having deb-src lines
28 Jun 2017 01:23 #95087
Replied by rodw on topic Need clarification on libxenomai-dev package
I know I'm just a noob and you guys know a lot more about Linux than I do but I thought that Xenomai was an alternative technology to the preemptive real time kernel so is it really required where you install Preempt-RT ?
28 Jun 2017 08:47 #95097
No, but the system checks for it when compiling from source and will build to support it if it finds it.
Time to create page: 0.321 seconds
