Ubuntu Xenial LTS Repository
- Thank you received: 5974
01 Oct 2018 20:14 #118317
Replied by tommylight on topic Ubuntu Xenial LTS Repository
Linux dc7800 4.18.7-rt5 #1 SMP PREEMPT RT <<<<That is an HP !<
01 Oct 2018 20:48 #118318
Replied by PCW on topic Ubuntu Xenial LTS Repository
Yeah Ive had especially good luck with the Elite 8300s (I5 2900 MHz) with Preempt-RT
They run Ethernet at 4KHz easily (once you turn off the Intel Ethernet spyware by disabling AMT in the BIOS setup)
- irakandjii
01 Oct 2018 21:00 #118319
by irakandjii
Replied by irakandjii on topic Ubuntu Xenial LTS Repository
lol … Yes I am trying to get PREEMPT RT into my release...
I just cannot figure out how to do it yet... but getting closer
and yes the existing is 4:15.0-34-generic, mine is now 4.15.0-37 because an upgrade worked but no preempt yet
22 Nov 2018 20:33 #121235
by ulflieger
Replied by ulflieger on topic Ubuntu Xenial LTS Repository
Thanks for this one, much appreciated and in usage for my machine in combination with Xubuntu 16.04.
But for now I've got a problem with the pendant XHC-HB04L (wireless, 18-buttons): Trying to compile the used commandline tool is functional, but using this under Axis is not possible and when I quit LinuxCNC I get the following error message (tried out with my local terminal):
Perhaps this is connected with the used version of libusb under Xenial? Anyone got an idea?
xhc-hb04: connection lost, cleaning up
libusb: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
libusb: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
*** Error in `xhc-hb04': free(): corrupted unsorted chunks: 0x0000000001767910 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7f120bef17e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x8037a)[0x7f120befa37a]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f120befe53c]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(+0xb365)[0x7f120c465365]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_unref_device+0x77)[0x7f120c45e967]
/lib/x86_64-linux-gnu/libusb-1.0.so.0(libusb_exit+0x23c)[0x7f120c45ffac]
xhc-hb04[0x4023bf]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f120be9a830]
xhc-hb04[0x402419]
======= Memory map: ========
00400000-00405000 r-xp 00000000 08:04 2363135 /usr/bin/xhc-hb04
00604000-00605000 r--p 00004000 08:04 2363135 /usr/bin/xhc-hb04
00605000-00606000 rw-p 00005000 08:04 2363135 /usr/bin/xhc-hb04
00606000-00608000 rw-p 00000000 00:00 0
0172f000-0177e000 rw-p 00000000 00:00 0 [heap]
7f1204000000-7f1204021000 rw-p 00000000 00:00 0
7f1204021000-7f1208000000 ---p 00000000 00:00 0
7f120b254000-7f120b255000 ---p 00000000 00:00 0
7f120b255000-7f120ba55000 rw-p 00000000 00:00 0
7f120ba55000-7f120ba6d000 r-xp 00000000 08:04 3281678 /lib/x86_64-linux-gnu/libpthread-2.23.so
7f120ba6d000-7f120bc6c000 ---p 00018000 08:04 3281678 /lib/x86_64-linux-gnu/libpthread-2.23.so
7f120bc6c000-7f120bc6d000 r--p 00017000 08:04 3281678 /lib/x86_64-linux-gnu/libpthread-2.23.so
7f120bc6d000-7f120bc6e000 rw-p 00018000 08:04 3281678 /lib/x86_64-linux-gnu/libpthread-2.23.so
7f120bc6e000-7f120bc72000 rw-p 00000000 00:00 0
7f120bc72000-7f120bc79000 r-xp 00000000 08:04 3281686 /lib/x86_64-linux-gnu/librt-2.23.so
7f120bc79000-7f120be78000 ---p 00007000 08:04 3281686 /lib/x86_64-linux-gnu/librt-2.23.so
7f120be78000-7f120be79000 r--p 00006000 08:04 3281686 /lib/x86_64-linux-gnu/librt-2.23.so
7f120be79000-7f120be7a000 rw-p 00007000 08:04 3281686 /lib/x86_64-linux-gnu/librt-2.23.so
7f120be7a000-7f120c03a000 r-xp 00000000 08:04 3281532 /lib/x86_64-linux-gnu/libc-2.23.so
7f120c03a000-7f120c23a000 ---p 001c0000 08:04 3281532 /lib/x86_64-linux-gnu/libc-2.23.so
7f120c23a000-7f120c23e000 r--p 001c0000 08:04 3281532 /lib/x86_64-linux-gnu/libc-2.23.so
7f120c23e000-7f120c240000 rw-p 001c4000 08:04 3281532 /lib/x86_64-linux-gnu/libc-2.23.so
7f120c240000-7f120c244000 rw-p 00000000 00:00 0
7f120c244000-7f120c25a000 r-xp 00000000 08:04 3281570 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f120c25a000-7f120c459000 ---p 00016000 08:04 3281570 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f120c459000-7f120c45a000 rw-p 00015000 08:04 3281570 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f120c45a000-7f120c471000 r-xp 00000000 08:04 3281712 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f120c471000-7f120c670000 ---p 00017000 08:04 3281712 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f120c670000-7f120c671000 r--p 00016000 08:04 3281712 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f120c671000-7f120c672000 rw-p 00017000 08:04 3281712 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7f120c672000-7f120c7e4000 r-xp 00000000 08:04 2369293 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f120c7e4000-7f120c9e4000 ---p 00172000 08:04 2369293 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f120c9e4000-7f120c9ee000 r--p 00172000 08:04 2369293 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f120c9ee000-7f120c9f0000 rw-p 0017c000 08:04 2369293 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21
7f120c9f0000-7f120c9f4000 rw-p 00000000 00:00 0
7f120c9f4000-7f120cafc000 r-xp 00000000 08:04 3281602 /lib/x86_64-linux-gnu/libm-2.23.so
7f120cafc000-7f120ccfb000 ---p 00108000 08:04 3281602 /lib/x86_64-linux-gnu/libm-2.23.so
7f120ccfb000-7f120ccfc000 r--p 00107000 08:04 3281602 /lib/x86_64-linux-gnu/libm-2.23.so
7f120ccfc000-7f120ccfd000 rw-p 00108000 08:04 3281602 /lib/x86_64-linux-gnu/libm-2.23.so
7f120ccfd000-7f120cd00000 r-xp 00000000 08:04 2361781 /usr/lib/liblinuxcncini.so.0
7f120cd00000-7f120cf00000 ---p 00003000 08:04 2361781 /usr/lib/liblinuxcncini.so.0
7f120cf00000-7f120cf01000 r--p 00003000 08:04 2361781 /usr/lib/liblinuxcncini.so.0
7f120cf01000-7f120cf02000 rw-p 00004000 08:04 2361781 /usr/lib/liblinuxcncini.so.0
7f120cf02000-7f120cf0b000 r-xp 00000000 08:04 2361782 /usr/lib/liblinuxcnchal.so.0
7f120cf0b000-7f120d10a000 ---p 00009000 08:04 2361782 /usr/lib/liblinuxcnchal.so.0
7f120d10a000-7f120d10b000 r--p 00008000 08:04 2361782 /usr/lib/liblinuxcnchal.so.0
7f120d10b000-7f120d10c000 rw-p 00009000 08:04 2361782 /usr/lib/liblinuxcnchal.so.0
7f120d10c000-7f120d132000 r-xp 00000000 08:04 3281504 /lib/x86_64-linux-gnu/ld-2.23.so
7f120d2a6000-7f120d2f1000 rw-s 00000000 00:05 2424851 /SYSV48414c32 (deleted)
7f120d2f1000-7f120d2f5000 rw-p 00000000 00:00 0
7f120d2f5000-7f120d313000 r-xp 00000000 08:04 3276896 /lib/x86_64-linux-gnu/libudev.so.1.6.4
7f120d313000-7f120d314000 r--p 0001d000 08:04 3276896 /lib/x86_64-linux-gnu/libudev.so.1.6.4
7f120d314000-7f120d315000 rw-p 0001e000 08:04 3276896 /lib/x86_64-linux-gnu/libudev.so.1.6.4
7f120d315000-7f120d319000 rw-p 00000000 00:00 0
7f120d32f000-7f120d330000 rw-p 00000000 00:00 0
7f120d330000-7f120d331000 rw-s 00000000 00:05 2359314 /SYSV48484c34 (deleted)
7f120d331000-7f120d332000 r--p 00025000 08:04 3281504 /lib/x86_64-linux-gnu/ld-2.23.so
7f120d332000-7f120d333000 rw-p 00026000 08:04 3281504 /lib/x86_64-linux-gnu/ld-2.23.so
7f120d333000-7f120d334000 rw-p 00000000 00:00 0
7ffc6c2b0000-7ffc6c2d2000 rw-p 00000000 00:00 0 [stack]
7ffc6c3da000-7ffc6c3dd000 r--p 00000000 00:00 0 [vvar]
7ffc6c3dd000-7ffc6c3df000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
Note: Using POSIX realtime
