Gigabyte J3455N-D3H don´t work with linuxcnc-2.7-wheezy.iso
27 Feb 2018 20:55 #106664
by MaSi1980
Hello everybody,
I'm an absolute Linux novice and get the Linuxcnc 2.7 not installed.
I've created a boot stick with different programs, but I can not boot from it.
It does not work with the live CD either.
An Ubunto boot stick works without problems ...
Can it be on the motherboard? It's a gigabyte J3455N-D3H
I chose it because it has a COM and two LAN outputs.
I would like to use the RT core to operate the mesa cards 7i76e and 7i85 with servo motor + glass scale
I found this help from cncnoob1979:
Complete How-To Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP installation or deb
Would you recommend to install the RT core with Linux Mint as a beginner?
27 Feb 2018 21:06 #106665
Replied by PCW on topic Gigabyte J3455N-D3H don´t work with linuxcnc-2.7-wheezy.iso
I would try the debian stretch test ISO:
www.linuxcnc.org/testing-stretch-rtpreempt/
I suspect that MB is too new for wheezy
27 Feb 2018 21:50 #106672
by MaSi1980
Replied by MaSi1980 on topic Gigabyte J3455N-D3H don´t work with linuxcnc-2.7-wheezy.iso
Thank you
04 Mar 2018 08:13 #106894
by MaSi1980
It works with the testing-stretch
Thank you!!!
Thank you!!!
07 Apr 2019 21:03 #130451
by ississ
Replied by ississ on topic Gigabyte J3455N-D3H don´t work with linuxcnc-2.7-wheezy.iso
@MaSi1980 can you share your experience with J3455N-D3H ?
What kind of latency you got with testing-stretch ?
08 Apr 2019 12:40 #130500
by pl7i92
Replied by pl7i92 on topic Gigabyte J3455N-D3H don´t work with linuxcnc-2.7-wheezy.iso
if you dont mind can <you update the WIKI Hardware BASE
