after upgrade to 2.7 i got this error
19 Mar 2018 20:28 #107562
by talatiah
after upgrade to 2.7 i got this error was created by talatiah
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.12
Machine configuration directory is '/home/probotix/linuxcnc/configs/5AXIS_TEST'
Machine configuration file is '5AXIS_TEST.ini'
INIFILE=/home/probotix/linuxcnc/configs/5AXIS_TEST/5AXIS_TEST.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./5AXIS_TEST.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=2094
Debug file information:
./5AXIS_TEST.hal:7: Can't find module 'probe_parport' in /usr/realtime-2.6.32-122-rtai/modules/linuxcnc
2094
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 874.762243] I-pipe: Domain RTAI registered.
[ 874.762258] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 874.762265] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 874.762354] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 874.762360] PIPELINE layers:
[ 874.762367] eeea9e20 9ac15d93 RTAI 200
[ 874.762373] c085cb20 0 Linux 100
[ 874.809513] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 874.810179] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 874.810193] RTAI[sched]: hard timer type/freq = APIC/6238270(Hz); default timing: periodic; linear timed lists.
[ 874.810202] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 998106000 hz.
[ 874.810209] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 874.810348] RTAI[usi]: enabled.
[ 874.899820] RTAI[math]: loaded.
[ 878.031418] RTAI[math]: unloaded.
[ 878.084968] SCHED releases registered named ALIEN RTGLBH
[ 878.116578] RTAI[malloc]: unloaded.
[ 878.216038] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 878.221288] I-pipe: Domain RTAI unregistered.
[ 878.221391] RTAI[hal]: unmounted.
thank you.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.12
TASK=milltask
HALUI=halui
DISPLAY=axis
2094
thank you.
- Thank you received: 1370
19 Mar 2018 21:16 #107566
Replied by Todd Zuercher on topic after upgrade to 2.7 i got this error
All of the modifications you need to make to your config when upgrading from 2.6 to 2.7 are located here.
linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
Your problem is specifically here.
linuxcnc.org/docs/html/getting-started/u....html#_parallel_port
You need to comment out or delete the line"loadrt probe_parport" in your hal file.
19 Mar 2018 22:27 #107573
by talatiah
Replied by talatiah on topic after upgrade to 2.7 i got this error
even i did the steps it's still not work. also i have question about comment out is that mean uncomment by remove #?
thank you
thank you
19 Mar 2018 22:46 #107575
by Clive S
# this is commented out ie not used
this is un-commented ie this line will be used
Replied by Clive S on topic after upgrade to 2.7 i got this error
thank you
Time to create page: 0.064 seconds
