Ubuntu 16.04.4 and LinuxCNC 2.7
05 Apr 2018 22:27 #108466
by dbanks
Ubuntu 16.04.4 and LinuxCNC 2.7 was created by dbanks
New to Linux as a whole, but I'm having a bunch of trouble with this set up. I've installed Ubuntu 16.04.4, and I've tried a range of different ways to install 2.7. LiveUSB, in terminal, LiveCD, creating a bootable USB on windows, etc. and have had success with none of them. Is there something fundamental I'm missing here? I've followed the tutorial on their website trying the options to no avail.
When I followed their tutorial here:http://linuxcnc.org/docs/2.7/html/getting-started/getting-linuxcnc.html
I was able to load it into the USB and then after it was loaded, it stopped showing up in the boot menu. I've tried two USBs, running into the same issue. Any help with this would be a godsend at this point. Thanks in advance!
- Thank you received: 5972
28 Apr 2018 21:28 #109770
Replied by tommylight on topic Ubuntu 16.04.4 and LinuxCNC 2.7
Follow the tutorial for Linux mint 18.1 on this forum, works always.
Did you get to install Ubuntu 16.04 or not ?
- InMyDarkestHour
- User is blocked
- Thank you received: 111
28 Apr 2018 23:23 - 28 Apr 2018 23:37 #109783
by InMyDarkestHour
Replied by InMyDarkestHour on topic Ubuntu 16.04.4 and LinuxCNC 2.7
1. Install Mint
2. Read this forum.linuxcnc.org/9-installing-linuxcnc...deb?start=420#109002
3. Ask Mr G if he still has the files available
Debian/Ubuntu/Mint usually require a initrd to boot with, that's why you get the unable to mount root filesystem error. The code to access the hardware for the disks is not built into the kernel. Installing the RT kernel via a deb will fix this issue.
4. (said tongue in cheek) Tell the boss man he bought dodgy hardware and to get something else, a lot of guys have had success with NUC.
Last edit: 28 Apr 2018 23:37 by InMyDarkestHour.
Time to create page: 0.061 seconds
