Initial installation question
11 Apr 2018 22:19 #108845
Replied by andypugh on topic Initial installation question
Incidentally, I will say that I admire your tenacity with this problem.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
11 Apr 2018 22:20 #108846
by InMyDarkestHour
Replied by InMyDarkestHour on topic Initial installation question
As you mentioned in another thread, please limit the number of threads on the same topic to avoid confusion, you are using a Byte3 pressing F7 during bootup should bring up a boot menu.
11 Apr 2018 22:21 - 11 Apr 2018 22:22 #108847
by dbanks
Replied by dbanks on topic Initial installation question
I tried that and got stuck at the patch. I'll try that update now. I have all the files downloaded to the machine from trying that method. Do I run a wget function?
Last edit: 11 Apr 2018 22:22 by dbanks.
- InMyDarkestHour
- User is blocked
11 Apr 2018 22:22 #108848
by InMyDarkestHour
What patch ?
11 Apr 2018 22:24 #108849
by dbanks
Haha thank you. There is a bit of a determination at this.
11 Apr 2018 22:25 - 11 Apr 2018 22:28 #108850
by dbanks
Ran that patch, ran the update. the CD linux-4.9.47 line now says there's no such file or directory. It didn't before. I then skipped that step and did EVERYTHING under it and got stuck at dpkg-checkbuilddeps. ran an error. Everything from that area of code is saying there isn't a file or directory now. Do I have to restart?
Last edit: 11 Apr 2018 22:28 by dbanks.
11 Apr 2018 22:30 #108851
by dbanks
Okay well ./configure uspace worked after a sudo apt-get update. However dpkg still says no file or directory.
11 Apr 2018 22:34 #108853
You don't need to compile linuxCNC. Once you have a preempt-rt kernel than LinuxCNC just becomes like any other bit of software.
What kernel ar you now running? (what does uname -a show?)
11 Apr 2018 22:47 #108856
by dbanks
I don't know how to get to the next step. I've already installed all the files, how do I run it?! haha This question makes me feel weak as a human being. What does "any other bit of software" mean?
I have 4.13.0=38 generic, booting 4.9.47 like I thought I needed results in a kernel panic unable to mount root fs error at grub select. I've tried the options AskUbuntu has to fix that, and none of those work.
Thanks so much for the time you've put into these responses!
- Thank you received: 5972
11 Apr 2018 23:17 #108857
Replied by tommylight on topic Initial installation question
As mentioned above, do not start multiple threads with this same subject ( there are already 3 started by you ) to avoid confusion.
Back on topic:
Go into BIOS and disable EVERYTHING that has "EFI" or "UEFI" written,
Get 1 or 2 USB sticks and use as follows:
>>>>on one USB stick download and write the Wheezy or Stretch image, insert it on the computer and boot from it, choose to boot as a live system ( does not change or write anything to your existing hard drive) or Install, if Install then install it on the existing hard drive or insert the USB number 2 and install on it.
Advise to boot as Live so you can check if it boots properly and install only after confirming it works.
You can also remove the hard drive and insert it on another computer, install Linuxcnc ( wheezy or stretch ) and put it back on the original computer.
Your persistence will prevail for sure, but please do read carefully the instructions.
Back on topic:
