Can't install Debian Stretch Live i386
- Cornflakes
25 Apr 2018 09:39 - 25 Apr 2018 11:23 #109584
by Cornflakes
Can't install Debian Stretch Live i386 was created by Cornflakes
Hi
I can`t install Debian Stretch i386 from www.linuxcnc.org/testing-stretch-rtpreempt/
All menu items dosn`t work
Wrong files names are in any cases
Last edit: 25 Apr 2018 11:23 by Cornflakes.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
25 Apr 2018 23:36 #109622
by InMyDarkestHour
Replied by InMyDarkestHour on topic Can't install Debian Stretch Live i386
Really need a bit more of a description of the steps you have taken and the problems you are getting.
Basically from writing the boot device (checking md5sum) then on to booting.
- Cornflakes
26 Apr 2018 14:21 #109656
by Cornflakes
Replied by Cornflakes on topic Can't install Debian Stretch Live i386
File names in Grub.cfg:
menuentry "Debian GNU/Linux Live (kernel 4.9.0-5-rt-686-pae)" {
linux /live/vmlinuz-4.9.0-5-rt-686-pae boot=live components persistence "${loopback}"
initrd /live/initrd.img-4.9.0-5-rt-686-pae
But there are files in folder LIVE:
VMLINUZ_4_9.0_5_RT_686_PAE
INITRD_IMG_4_9.0_5_RT_686_PAE
In result any menuentry dont work
26 Apr 2018 15:55 #109663
Replied by PCW on topic Can't install Debian Stretch Live i386
Are you saying that just the i386 version doesn't not work?
The 64 bit images work for me with no real issues (live and installed)
- Cornflakes
28 Apr 2018 13:37 #109760
by Cornflakes
Problem solved!
I made boot flash drive by UltraISO (Windows 10)
UltraISO changed some file names
I used Rufus
Everything works well now!
Thanks!
I used Rufus
Thanks!
- InMyDarkestHour
- User is blocked
28 Apr 2018 23:10 #109782
by InMyDarkestHour
W32DiskImage is the foolproof utility. Maybe a mention of that should be included in the docs.
02 May 2018 21:48 #110059
That's just crazy. I am impressed that you found the problem and fixed it.
Replied by andypugh on topic Can't install Debian Stretch Live i386
Problem solved!
Time to create page: 0.244 seconds
