Re-install LCNC
- allenwg2005
- Topic Author
- Thank you received: 4
20 May 2018 01:10 #110914
by allenwg2005
Re-install LCNC was created by allenwg2005
I had to re-install LCNC on my machine.
I copied all the files in the LinuxCNC folder before doing so (Hal, ini, tool table ect).
I have it all set-up and opening, but, it's running under "LinuxCNC-HAL-SIM-AXIS" and I can't recall how to bring it up with my ini and hal files, I did this years ago with no problem, I just don't remember how to do it now.
Could someone save me a bunch of time and share how to address this?
Thanks in advance
Thanks in advance
- InMyDarkestHour
- User is blocked
- Thank you received: 111
20 May 2018 02:11 #110918
by InMyDarkestHour
- allenwg2005
- Topic Author
20 May 2018 21:45 #110935
by allenwg2005
Replied by allenwg2005 on topic Re-install LCNC
I've been reading and trying to sort this all day, most of my problem I think is I did this in the past and now I don't understand why it's such a problem. (I guess I'm getting old).
I have started the Configuration Selector and it has my .ini in the header, I click OK and I get the log below.
Can someone point me in the correct direction please.
Thanks in advance.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.13
Machine configuration directory is '/home/allen/linuxcnc/configs/Router'
Machine configuration file is 'Router.ini.expanded'
INIFILE=/home/allen/linuxcnc/configs/Router/Router.ini.expanded
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=11149
Debug file information:
couldn't read file "LIB:xhc-hb04.tcl": no such file or directory
while executing
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
11149
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cf590000 (usable)
[ 0.000000] BIOS-e820: 00000000cf590000 - 00000000cf5e3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cf5e3000 - 00000000cf5f0000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cf5f0000 - 00000000cf600000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. Vostro 200/0CU409, BIOS 1.0.3 07/12/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcf590 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CAFFF write-protect
[ 0.000000] CB000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 100000000 mask FF0000000 write-back
[ 0.000000] 1 base 000000000 mask F80000000 write-back
[ 0.000000] 2 base 080000000 mask FC0000000 write-back
[ 0.000000] 3 base 0C0000000 mask FF0000000 write-back
[ 0.000000] 4 base 0CF700000 mask FFFF00000 uncachable
[ 0.000000] 5 base 0CF800000 mask FFF800000 uncachable
[ 0.000000] 6 base 0CF600000 mask FFFF00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf600000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00f3e30] f3e30
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36528000 - 3728c000
[ 0.000000] ACPI: RSDP 000f96c0 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT cf5e3080 00054 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP cf5e7200 000F4 (v03 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT cf5e3200 03FFC (v01 DELL AWRDACPI 00001000 MSFT 03000000)
[ 0.000000] ACPI: FACS cf590000 00040
[ 0.000000] ACPI: HPET cf5e73c0 00038 (v01 DELL FX09 42302E31 AWRD 00000098)
[ 0.000000] ACPI: MCFG cf5e7400 0003C (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: SLIC cf5e7440 00176 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DMY2 cf5e75c0 00080 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC cf5e7300 00084 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2429MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cf590
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000cf590
[ 0.000000] On node 0 totalpages: 849182
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b38200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4860 pages used for memmap
[ 0.000000] HighMem zone: 617110 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at cf600000 (gap: cf600000:10a00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 842546
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=100f21bf-db51-49d3-b79f-e113983e3fa8 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 6794240 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cf590)
[ 0.000000] Memory: 3342812k/3397184k available (3495k kernel code, 53916k reserved, 1237k data, 416k init, 2487880k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1596.019 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 3192.03 BogoMIPS (lpj=6384076)
[ 0.004009] pid_max: default: 32768 minimum: 301
[ 0.004079] Security Framework initialized
[ 0.004087] AppArmor: AppArmor disabled by boot time parameter
[ 0.004115] Mount-cache hash table entries: 512
[ 0.004443] Initializing cgroup subsys cpuacct
[ 0.004448] Initializing cgroup subsys memory
[ 0.004460] Initializing cgroup subsys devices
[ 0.004465] Initializing cgroup subsys freezer
[ 0.004468] Initializing cgroup subsys net_cls
[ 0.004471] Initializing cgroup subsys blkio
[ 0.004481] Initializing cgroup subsys perf_event
[ 0.004526] mce: CPU supports 6 MCE banks
[ 0.004536] CPU0: Thermal monitoring enabled (TM2)
[ 0.004613] SMP alternatives: switching to UP code
[ 0.010005] ACPI: Core revision 20120320
[ 0.016072] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016445] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.056343] CPU0: Intel(R) Celeron(R) CPU 420 @ 1.60GHz stepping 01
[ 0.060003] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.060003] ... version: 2
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 2
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 000000007fffffff
[ 0.060003] ... fixed-purpose events: 3
[ 0.060003] ... event mask: 0000000700000003
[ 0.068125] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.068196] Brought up 1 CPUs
[ 0.068200] Total of 1 processors activated (3192.03 BogoMIPS).
[ 0.068795] devtmpfs: initialized
[ 0.069205] PM: Registering ACPI NVS region [mem 0xcf590000-0xcf5e2fff] (339968 bytes)
[ 0.069384] dummy:
[ 0.069471] NET: Registered protocol family 16
[ 0.069696] ACPI: bus type pci registered
[ 0.069786] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.069792] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.069795] PCI: Using MMCONFIG for extended config space
[ 0.069798] PCI: Using configuration type 1 for base access
[ 0.070754] bio: create slab <bio-0> at 0
[ 0.070890] ACPI: Added _OSI(Module Device)
[ 0.070894] ACPI: Added _OSI(Processor Device)
[ 0.070898] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.070902] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.072594] ACPI: EC: Look up EC in DSDT
[ 0.079902] ACPI: Interpreter enabled
[ 0.079917] ACPI: (supports S0 S3 S4 S5)
[ 0.079960] ACPI: Using IOAPIC for interrupt routing
[ 0.087170] ACPI: No dock devices found.
[ 0.087180] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.087290] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.087439] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.087444] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.087448] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.087452] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.087456] pci_root PNP0A08:00: host bridge window [mem 0xcf600000-0xfebfffff] (ignored)
[ 0.087461] PCI: root bus 00: using default resources
[ 0.087526] PCI host bridge to bus 0000:00
[ 0.087531] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.087535] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.087552] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000
[ 0.087615] pci 0000:00:01.0: [8086:29c1] type 01 class 0x060400
[ 0.087664] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.087690] pci 0000:00:02.0: [8086:29c2] type 00 class 0x030000
[ 0.087706] pci 0000:00:02.0: reg 10: [mem 0xfdf00000-0xfdf7ffff]
[ 0.087715] pci 0000:00:02.0: reg 14: [io 0xff00-0xff07]
[ 0.087724] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
[ 0.087733] pci 0000:00:02.0: reg 1c: [mem 0xfdb00000-0xfdbfffff]
[ 0.087815] pci 0000:00:19.0: [8086:10c0] type 00 class 0x020000
[ 0.087838] pci 0000:00:19.0: reg 10: [mem 0xfdfc0000-0xfdfdffff]
[ 0.087850] pci 0000:00:19.0: reg 14: [mem 0xfdfff000-0xfdffffff]
[ 0.087861] pci 0000:00:19.0: reg 18: [io 0xfe00-0xfe1f]
[ 0.087924] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.087951] pci 0000:00:1a.0: [8086:2937] type 00 class 0x0c0300
[ 0.088022] pci 0000:00:1a.0: reg 20: [io 0xfd00-0xfd1f]
[ 0.088079] pci 0000:00:1a.1: [8086:2938] type 00 class 0x0c0300
[ 0.088132] pci 0000:00:1a.1: reg 20: [io 0xfc00-0xfc1f]
[ 0.088188] pci 0000:00:1a.2: [8086:2939] type 00 class 0x0c0300
[ 0.088241] pci 0000:00:1a.2: reg 20: [io 0xfb00-0xfb1f]
[ 0.088307] pci 0000:00:1a.7: [8086:293c] type 00 class 0x0c0320
[ 0.088333] pci 0000:00:1a.7: reg 10: [mem 0xfdffe000-0xfdffe3ff]
[ 0.088422] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.088457] pci 0000:00:1b.0: [8086:293e] type 00 class 0x040300
[ 0.088477] pci 0000:00:1b.0: reg 10: [mem 0xfdff4000-0xfdff7fff 64bit]
[ 0.088546] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.088575] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
[ 0.088628] pci 0000:00:1d.0: reg 20: [io 0xfa00-0xfa1f]
[ 0.088685] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
[ 0.088738] pci 0000:00:1d.1: reg 20: [io 0xf900-0xf91f]
[ 0.088793] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
[ 0.088846] pci 0000:00:1d.2: reg 20: [io 0xf800-0xf81f]
[ 0.088913] pci 0000:00:1d.7: [8086:293a] type 00 class 0x0c0320
[ 0.088939] pci 0000:00:1d.7: reg 10: [mem 0xfdffd000-0xfdffd3ff]
[ 0.089029] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.089056] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.089128] pci 0000:00:1f.0: [8086:2916] type 00 class 0x060100
[ 0.089225] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0800 (mask 003f)
[ 0.089230] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 003f)
[ 0.089275] pci 0000:00:1f.2: [8086:2920] type 00 class 0x01018f
[ 0.089295] pci 0000:00:1f.2: reg 10: [io 0xf700-0xf707]
[ 0.089306] pci 0000:00:1f.2: reg 14: [io 0xf600-0xf603]
[ 0.089317] pci 0000:00:1f.2: reg 18: [io 0xf500-0xf507]
[ 0.089327] pci 0000:00:1f.2: reg 1c: [io 0xf400-0xf403]
[ 0.089338] pci 0000:00:1f.2: reg 20: [io 0xf300-0xf30f]
[ 0.089349] pci 0000:00:1f.2: reg 24: [io 0xf200-0xf20f]
[ 0.089398] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500
[ 0.089418] pci 0000:00:1f.3: reg 10: [mem 0xfdffc000-0xfdffc0ff 64bit]
[ 0.089445] pci 0000:00:1f.3: reg 20: [io 0x0500-0x051f]
[ 0.089486] pci 0000:00:1f.5: [8086:2926] type 00 class 0x010185
[ 0.089507] pci 0000:00:1f.5: reg 10: [io 0xf000-0xf007]
[ 0.089518] pci 0000:00:1f.5: reg 14: [io 0xef00-0xef03]
[ 0.089529] pci 0000:00:1f.5: reg 18: [io 0xee00-0xee07]
[ 0.089539] pci 0000:00:1f.5: reg 1c: [io 0xed00-0xed03]
[ 0.089550] pci 0000:00:1f.5: reg 20: [io 0xec00-0xec0f]
[ 0.089561] pci 0000:00:1f.5: reg 24: [io 0xeb00-0xeb0f]
[ 0.089642] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.089647] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
[ 0.089652] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.089659] pci 0000:00:01.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.089697] pci 0000:02:00.0: [5372:6872] type 00 class 0x078000
[ 0.089714] pci 0000:02:00.0: reg 10: [io 0xdf00-0xdf07]
[ 0.089727] pci 0000:02:00.0: reg 14: [io 0xde00-0xde07]
[ 0.089740] pci 0000:02:00.0: reg 18: [io 0xdd00-0xdd07]
[ 0.089753] pci 0000:02:00.0: reg 1c: [io 0xdc00-0xdc07]
[ 0.089765] pci 0000:02:00.0: reg 20: [io 0xdb00-0xdb07]
[ 0.089778] pci 0000:02:00.0: reg 24: [io 0xda00-0xda0f]
[ 0.089813] pci 0000:02:01.0: [9710:9865] type 00 class 0x070103
[ 0.089835] pci 0000:02:01.0: reg 10: [io 0xd900-0xd907]
[ 0.089848] pci 0000:02:01.0: reg 14: [io 0xd800-0xd807]
[ 0.089861] pci 0000:02:01.0: reg 18: [mem 0xfddff000-0xfddfffff]
[ 0.089884] pci 0000:02:01.0: reg 20: [mem 0xfddfe000-0xfddfefff]
[ 0.089928] pci 0000:02:01.0: PME# supported from D0 D3cold
[ 0.089955] pci 0000:02:01.2: [9710:9865] type 00 class 0x070103
[ 0.089977] pci 0000:02:01.2: reg 10: [io 0xd700-0xd707]
[ 0.089990] pci 0000:02:01.2: reg 14: [io 0xd600-0xd607]
[ 0.090003] pci 0000:02:01.2: reg 18: [mem 0xfddfd000-0xfddfdfff]
[ 0.090026] pci 0000:02:01.2: reg 20: [mem 0xfddfc000-0xfddfcfff]
[ 0.090070] pci 0000:02:01.2: PME# supported from D0 D3cold
[ 0.090133] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.090139] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.090145] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.090153] pci 0000:00:1e.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.090157] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.090161] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.090175] pci_bus 0000:00: on NUMA node 0
[ 0.090180] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.090581] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.090812] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.113570] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.113665] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.113759] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 7 9 10 11 12 14 15)
[ 0.113851] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.113942] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.114034] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *9 10 11 12 14 15)
[ 0.114126] ACPI: PCI Interrupt Link [LNK0] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.114217] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.114362] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.114381] vgaarb: loaded
[ 0.114384] vgaarb: bridge control possible 0000:00:02.0
[ 0.114433] PCI: Using ACPI for IRQ routing
[ 0.121778] PCI: pci_cache_line_size set to 64 bytes
[ 0.121878] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[ 0.121883] reserve RAM buffer: 00000000cf590000 - 00000000cfffffff
[ 0.122103] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.122114] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.124032] Switching to clocksource hpet
[ 0.124123] pnp: PnP ACPI init
[ 0.124143] ACPI: bus type pnp registered
[ 0.124287] pnp 00:00: [bus 00-ff]
[ 0.124293] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.124297] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.124301] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.124305] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.124308] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.124312] pnp 00:00: [mem 0xcf600000-0xfebfffff window]
[ 0.124392] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.124524] pnp 00:01: [io 0x0010-0x001f]
[ 0.124528] pnp 00:01: [io 0x0022-0x003f]
[ 0.124531] pnp 00:01: [io 0x0044-0x005f]
[ 0.124535] pnp 00:01: [io 0x0060]
[ 0.124538] pnp 00:01: [io 0x0064]
[ 0.124541] pnp 00:01: [io 0x0062-0x0063]
[ 0.124544] pnp 00:01: [io 0x0065-0x006f]
[ 0.124548] pnp 00:01: [io 0x0074-0x007f]
[ 0.124554] pnp 00:01: [io 0x0091-0x0093]
[ 0.124557] pnp 00:01: [io 0x00a2-0x00bf]
[ 0.124560] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.124564] pnp 00:01: [io 0x04d0-0x04d1]
[ 0.124567] pnp 00:01: [io 0x0800-0x087f]
[ 0.124570] pnp 00:01: [io 0x0290-0x0297]
[ 0.124574] pnp 00:01: [io 0x0880-0x088f]
[ 0.124670] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.124675] system 00:01: [io 0x0800-0x087f] has been reserved
[ 0.124679] system 00:01: [io 0x0290-0x0297] has been reserved
[ 0.124683] system 00:01: [io 0x0880-0x088f] has been reserved
[ 0.124688] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.124712] pnp 00:02: [dma 4]
[ 0.124716] pnp 00:02: [io 0x0000-0x000f]
[ 0.124719] pnp 00:02: [io 0x0080-0x0090]
[ 0.124722] pnp 00:02: [io 0x0094-0x009f]
[ 0.124726] pnp 00:02: [io 0x00c0-0x00df]
[ 0.124768] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.124867] pnp 00:03: [irq 0 disabled]
[ 0.124881] pnp 00:03: [irq 8]
[ 0.124885] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 0.124935] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.124992] pnp 00:04: [io 0x0070-0x0073]
[ 0.125038] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.125058] pnp 00:05: [io 0x0061]
[ 0.125100] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.125118] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.125126] pnp 00:06: [irq 13]
[ 0.125172] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.125416] pnp 00:07: [io 0x03f0-0x03f5]
[ 0.125420] pnp 00:07: [io 0x03f7]
[ 0.125428] pnp 00:07: [irq 6]
[ 0.125431] pnp 00:07: [dma 2]
[ 0.125499] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.125615] pnp 00:08: [io 0x0400-0x04bf]
[ 0.125692] system 00:08: [io 0x0400-0x04bf] has been reserved
[ 0.125697] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.125737] pnp 00:09: [mem 0xffb80000-0xffbfffff]
[ 0.125790] pnp 00:09: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.126185] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.126276] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.126282] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.126431] pnp 00:0b: [mem 0x000f0000-0x000fffff]
[ 0.126435] pnp 00:0b: [mem 0xcf600000-0xcf6fffff]
[ 0.126439] pnp 00:0b: [mem 0xfed00000-0xfed000ff]
[ 0.126443] pnp 00:0b: [mem 0xcf590000-0xcf5fffff]
[ 0.126446] pnp 00:0b: [mem 0x00000000-0x0009ffff]
[ 0.126449] pnp 00:0b: [mem 0x00100000-0xcf58ffff]
[ 0.126453] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[ 0.126456] pnp 00:0b: [mem 0xfed14000-0xfed1dfff]
[ 0.126460] pnp 00:0b: [mem 0xfed20000-0xfed9ffff]
[ 0.126463] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[ 0.126466] pnp 00:0b: [mem 0xffb00000-0xffb7ffff]
[ 0.126470] pnp 00:0b: [mem 0xfff00000-0xffffffff]
[ 0.126473] pnp 00:0b: [mem 0x000e0000-0x000effff]
[ 0.126580] system 00:0b: [mem 0x000f0000-0x000fffff] could not be reserved
[ 0.126586] system 00:0b: [mem 0xcf600000-0xcf6fffff] could not be reserved
[ 0.126591] system 00:0b: [mem 0xfed00000-0xfed000ff] has been reserved
[ 0.126596] system 00:0b: [mem 0xcf590000-0xcf5fffff] could not be reserved
[ 0.126600] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.126605] system 00:0b: [mem 0x00100000-0xcf58ffff] could not be reserved
[ 0.126610] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.126614] system 00:0b: [mem 0xfed14000-0xfed1dfff] has been reserved
[ 0.126619] system 00:0b: [mem 0xfed20000-0xfed9ffff] has been reserved
[ 0.126624] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.126628] system 00:0b: [mem 0xffb00000-0xffb7ffff] has been reserved
[ 0.126633] system 00:0b: [mem 0xfff00000-0xffffffff] has been reserved
[ 0.126644] system 00:0b: [mem 0x000e0000-0x000effff] has been reserved
[ 0.126650] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.126666] pnp: PnP ACPI: found 12 devices
[ 0.126668] ACPI: ACPI bus type pnp unregistered
[ 0.126674] PnPBIOS: Disabled by ACPI PNP
[ 0.163758] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.163764] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
[ 0.163771] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.163776] pci 0000:00:01.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.163784] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.163789] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.163796] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.163801] pci 0000:00:1e.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.163839] pci 0000:00:1e.0: setting latency timer to 64
[ 0.163845] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.163849] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.163853] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff]
[ 0.163856] pci_bus 0000:01: resource 1 [mem 0xfde00000-0xfdefffff]
[ 0.163860] pci_bus 0000:01: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.163864] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.163868] pci_bus 0000:02: resource 1 [mem 0xfdd00000-0xfddfffff]
[ 0.163872] pci_bus 0000:02: resource 2 [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.163875] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.163879] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.163977] NET: Registered protocol family 2
[ 0.164093] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.164364] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.165013] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.165379] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.165384] TCP: reno registered
[ 0.165391] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.165406] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.165565] NET: Registered protocol family 1
[ 0.165596] pci 0000:00:02.0: Boot video device
[ 0.165863] PCI: CLS mismatch (64 != 32), using 64 bytes
[ 0.165942] Unpacking initramfs...
[ 0.582425] Freeing initrd memory: 13712k freed
[ 0.590091] audit: initializing netlink socket (disabled)
[ 0.590117] type=2000 audit(1526848389.584:1): initialized
[ 0.607030] highmem bounce pool size: 64 pages
[ 0.607038] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.607236] VFS: Disk quotas dquot_6.5.2
[ 0.607271] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.607379] msgmni has been set to 1696
[ 0.607602] alg: No test for stdrng (krng)
[ 0.607643] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.607648] io scheduler noop registered
[ 0.607651] io scheduler deadline registered
[ 0.607671] io scheduler cfq registered (default)
[ 0.607859] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.607886] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.607890] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.608536] GHES: HEST is not enabled!
[ 0.608556] isapnp: Scanning for PnP cards...
[ 0.961752] isapnp: No Plug & Play device found
[ 0.961826] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.962477] Linux agpgart interface v0.103
[ 0.962617] agpgart-intel 0000:00:00.0: Intel G33 Chipset
[ 0.962711] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 0.962865] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 0.962991] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 0.963183] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.963601] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.963650] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.963778] mousedev: PS/2 mouse device common for all mice
[ 0.963845] rtc_cmos 00:04: RTC can wake from S4
[ 0.963988] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.964044] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 0.964249] TCP: cubic registered
[ 0.964305] NET: Registered protocol family 10
[ 0.964638] Mobile IPv6
[ 0.964644] NET: Registered protocol family 17
[ 0.964652] Registering the dns_resolver key type
[ 0.964745] Using IPI No-Shortcut mode
[ 0.964889] PM: Hibernation image not present or could not be loaded.
[ 0.964906] registered taskstats version 1
[ 0.965402] rtc_cmos 00:04: setting system clock to 2018-05-20 20:33:10 UTC (1526848390)
[ 0.965529] Freeing unused kernel memory: 416k freed
[ 0.965753] Write protecting the kernel text: 3496k
[ 0.965778] Write protecting the kernel read-only data: 984k
[ 0.992134] udevd[45]: starting version 175
[ 1.042941] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 1.042946] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 1.043005] e1000e 0000:00:19.0: setting latency timer to 64
[ 1.043085] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.047655] ACPI: Fan [FAN] (on)
[ 1.055579] usbcore: registered new interface driver usbfs
[ 1.055619] usbcore: registered new interface driver hub
[ 1.090145] usbcore: registered new device driver usb
[ 1.090823] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.099880] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.168664] FDC 0 is a post-1991 82077
[ 1.191729] SCSI subsystem initialized
[ 1.214274] libata version 3.00 loaded.
[ 1.220546] microcode: CPU0 sig=0x10661, pf=0x1, revision=0x32
[ 1.276014] microcode: CPU0 updated to revision 0x43, date = 2010-10-04
[ 1.276491] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.312101] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:1a:a0:8c:24:a8
[ 1.312108] e1000e 0000:00:19.0: eth0: Intel(R) PRO/10/100 Network Connection
[ 1.312131] e1000e 0000:00:19.0: eth0: MAC: 7, PHY: 7, PBA No: FFFFFF-0FF
[ 1.312204] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 1.312210] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 1.312250] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.312287] ehci_hcd 0000:00:1a.7: debug port 1
[ 1.317594] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 1.317631] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfdffe000
[ 1.328019] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.328080] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.328084] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.328088] usb usb1: Product: EHCI Host Controller
[ 1.328091] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.328095] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.329523] hub 1-0:1.0: USB hub found
[ 1.329537] hub 1-0:1.0: 6 ports detected
[ 1.329709] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.329715] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.329730] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 1.329780] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000fd00
[ 1.329831] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.329835] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.329839] usb usb2: Product: UHCI Host Controller
[ 1.329842] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.329846] usb usb2: SerialNumber: 0000:00:1a.0
[ 1.330020] hub 2-0:1.0: USB hub found
[ 1.330028] hub 2-0:1.0: 2 ports detected
[ 1.330308] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 1.330314] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.330329] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 3
[ 1.330379] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000fc00
[ 1.330431] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.330435] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.330439] usb usb3: Product: UHCI Host Controller
[ 1.330442] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.330445] usb usb3: SerialNumber: 0000:00:1a.1
[ 1.330617] hub 3-0:1.0: USB hub found
[ 1.330625] hub 3-0:1.0: 2 ports detected
[ 1.332047] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 1.332053] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 1.332071] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 4
[ 1.332254] uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000fb00
[ 1.332672] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.332683] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.332693] usb usb4: Product: UHCI Host Controller
[ 1.332703] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.332713] usb usb4: SerialNumber: 0000:00:1a.2
[ 1.336253] hub 4-0:1.0: USB hub found
[ 1.336307] hub 4-0:1.0: 2 ports detected
[ 1.340193] ata_piix 0000:00:1f.2: version 2.13
[ 1.340336] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.340853] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.343566] scsi0 : ata_piix
[ 1.345565] scsi1 : ata_piix
[ 1.346713] ata1: SATA max UDMA/133 cmd 0xf700 ctl 0xf600 bmdma 0xf300 irq 19
[ 1.346723] ata2: SATA max UDMA/133 cmd 0xf500 ctl 0xf400 bmdma 0xf308 irq 19
[ 1.347052] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.347059] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.347083] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 1.347116] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.350998] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.351035] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfdffd000
[ 1.360017] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.360054] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.360058] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.360062] usb usb5: Product: EHCI Host Controller
[ 1.360065] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.360069] usb usb5: SerialNumber: 0000:00:1d.7
[ 1.361458] hub 5-0:1.0: USB hub found
[ 1.361472] hub 5-0:1.0: 6 ports detected
[ 1.361639] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.361645] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.361658] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 1.361690] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fa00
[ 1.361742] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.361746] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.361750] usb usb6: Product: UHCI Host Controller
[ 1.361753] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.361756] usb usb6: SerialNumber: 0000:00:1d.0
[ 1.361929] hub 6-0:1.0: USB hub found
[ 1.361940] hub 6-0:1.0: 2 ports detected
[ 1.362955] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.362962] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.362978] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 1.363015] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000f900
[ 1.363068] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.363072] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.363076] usb usb7: Product: UHCI Host Controller
[ 1.363079] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.363083] usb usb7: SerialNumber: 0000:00:1d.1
[ 1.363653] hub 7-0:1.0: USB hub found
[ 1.363662] hub 7-0:1.0: 2 ports detected
[ 1.365104] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.365110] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.365130] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 1.365164] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000f800
[ 1.365219] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.365224] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.365227] usb usb8: Product: UHCI Host Controller
[ 1.365231] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.365234] usb usb8: SerialNumber: 0000:00:1d.2
[ 1.365420] hub 8-0:1.0: USB hub found
[ 1.365428] hub 8-0:1.0: 2 ports detected
[ 1.366894] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.366956] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.372194] scsi2 : ata_piix
[ 1.376454] scsi3 : ata_piix
[ 1.376980] ata3: SATA max UDMA/133 cmd 0xf000 ctl 0xef00 bmdma 0xec00 irq 19
[ 1.376987] ata4: SATA max UDMA/133 cmd 0xee00 ctl 0xed00 bmdma 0xec08 irq 19
[ 1.600018] Refined TSC clocksource calibration: 1595.999 MHz.
[ 1.600026] Switching to clocksource tsc
[ 1.707050] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.717884] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.000015] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 2.140071] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.140084] ata1.01: SATA link down (SStatus 0 SControl 300)
[ 2.144064] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.144079] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 2.144091] ata2.01: link offline, clearing class 3 to NONE
[ 2.168125] ata2.00: ATAPI: PHILIPS DVD-ROM DROM6316, ODFN01, max UDMA/100
[ 2.168432] usb 3-1: New USB device found, idVendor=0461, idProduct=4d15
[ 2.168436] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.168440] usb 3-1: Product: USB Optical Mouse
[ 2.192123] ata1.00: ATA-7: ST3808110AS, 3.ADJ, max UDMA/133
[ 2.192129] ata1.00: 156250000 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.200252] ata2.00: configured for UDMA/100
[ 2.267070] ata1.00: configured for UDMA/133
[ 2.267229] scsi 0:0:0:0: Direct-Access ATA ST3808110AS 3.AD PQ: 0 ANSI: 5
[ 2.267825] scsi 1:0:0:0: CD-ROM PHILIPS DVD-ROM DROM6316 ODFN PQ: 0 ANSI: 5
[ 2.290971] sd 0:0:0:0: [sda] 156250000 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 2.291062] sd 0:0:0:0: [sda] Write Protect is off
[ 2.291067] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.291105] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.297072] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.1/usb3/3-1/3-1:1.0/input/input0
[ 2.297360] generic-usb 0003:0461:4D15.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.1-1/input0
[ 2.297458] usbcore: registered new interface driver usbhid
[ 2.297462] usbhid: USB HID core driver
[ 2.330207] sda: sda1 sda2 < sda5 >
[ 2.330720] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.334622] sr0: scsi3-mmc drive: 0x/48x cd/rw xa/form2 cdda tray
[ 2.334629] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.335386] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.349730] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.350558] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.408027] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 2.588433] usb 3-2: New USB device found, idVendor=04f2, idProduct=0841
[ 2.588439] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.588443] usb 3-2: Product: HP USB Multimedia Keyboard
[ 2.588446] usb 3-2: Manufacturer: CHICONY
[ 2.607115] input: CHICONY HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.1/usb3/3-2/3-2:1.0/input/input1
[ 2.607203] generic-usb 0003:04F2:0841.0002: input,hidraw1: USB HID v1.11 Keyboard [CHICONY HP USB Multimedia Keyboard] on usb-0000:00:1a.1-2/input0
[ 2.632748] input: CHICONY HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.1/usb3/3-2/3-2:1.1/input/input2
[ 2.632900] generic-usb 0003:04F2:0841.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [CHICONY HP USB Multimedia Keyboard] on usb-0000:00:1a.1-2/input1
[ 2.872018] usb 4-2: new full-speed USB device number 2 using uhci_hcd
[ 3.025469] usb 4-2: New USB device found, idVendor=10ce, idProduct=eb70
[ 3.025474] usb 4-2: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 3.025478] usb 4-2: Manufacturer: KTURT.LTD
[ 3.033682] generic-usb 0003:10CE:EB70.0004: hiddev0,hidraw3: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:1a.2-2/input0
[ 7.729932] PM: Starting manual resume from disk
[ 7.729939] PM: Hibernation image partition 8:5 present
[ 7.729941] PM: Looking for hibernation image.
[ 7.761199] PM: Image not found (code -22)
[ 7.761203] PM: Hibernation image not present or could not be loaded.
[ 7.815957] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.704485] udevd[350]: starting version 175
[ 10.179334] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 10.179344] ACPI: Power Button [PWRB]
[ 10.179451] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 10.179457] ACPI: Power Button [PWRF]
[ 10.258661] [drm] Initialized drm 1.1.0 20060810
[ 10.336531] iTCO_vendor_support: vendor-support=0
[ 10.337578] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 10.337697] iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0460)
[ 10.337784] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.372871] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 10.632118] i915 0000:00:02.0: setting latency timer to 64
[ 10.671442] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 10.671447] [drm] Driver supports precise vblank timestamp query.
[ 10.671501] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 10.688019] [drm] initialized overlay support
[ 10.697570] coretemp coretemp.0: Using relative temperature scale!
[ 10.738370] fbcon: inteldrmfb (fb0) is primary device
[ 10.785755] Console: switching to colour frame buffer device 200x56
[ 10.793624] fb0: inteldrmfb frame buffer device
[ 10.793628] drm: registered panic notifier
[ 10.793645] No ACPI video bus found
[ 10.794136] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.986848] PCI parallel port detected: 14f2:0121, I/O at 0xd900(0x0), IRQ 16
[ 10.986872] parport0: PC-style at 0xd900, irq 16 [PCSPP,TRISTATE,EPP]
[ 11.084203] PCI parallel port detected: 14f2:0121, I/O at 0xd700(0x0), IRQ 18
[ 11.084230] parport1: PC-style at 0xd700, irq 18 [PCSPP,TRISTATE,EPP]
[ 11.098800] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 11.107401] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 11.107668] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 11.107921] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 11.108213] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 11.108467] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 11.108716] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 11.108971] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 11.109224] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 13.053919] Adding 3211260k swap on /dev/sda5. Priority:-1 extents:1 across:3211260k
[ 13.078144] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.345984] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.487556] loop: module loaded
[ 15.422108] RPC: Registered named UNIX socket transport module.
[ 15.422113] RPC: Registered udp transport module.
[ 15.422116] RPC: Registered tcp transport module.
[ 15.422119] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.456341] FS-Cache: Loaded
[ 15.500579] NFS: Registering the id_resolver key type
[ 15.500610] FS-Cache: Netfs 'nfs' registered for caching
[ 15.508285] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 17.748149] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 19.483440] Bluetooth: Core ver 2.16
[ 19.483845] NET: Registered protocol family 31
[ 19.483850] Bluetooth: HCI device and connection manager initialized
[ 19.483854] Bluetooth: HCI socket layer initialized
[ 19.483857] Bluetooth: L2CAP socket layer initialized
[ 19.483867] Bluetooth: SCO socket layer initialized
[ 19.510399] Bluetooth: RFCOMM TTY layer initialized
[ 19.510408] Bluetooth: RFCOMM socket layer initialized
[ 19.510411] Bluetooth: RFCOMM ver 1.11
[ 19.577670] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.577675] Bluetooth: BNEP filters: protocol multicast
[ 19.792412] lp0: using parport0 (interrupt-driven).
[ 19.793526] lp1: using parport1 (interrupt-driven).
[ 19.897074] ppdev: user-space parallel port driver
[ 22.490594] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 25.593843] e1000e 0000:00:19.0: eth0: MAC Wakeup cause - Link Status Change
[ 27.268770] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 27.268778] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 27.268948] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 37.640008] eth0: no IPv6 routers present
[ 143.010972] I-pipe: head domain RTAI registered.
[ 143.010982] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 143.010991] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 143.010996] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 143.011000] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 143.011005] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 10595750
[ 143.067391] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 143.067448] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 143.067455] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 143.067460] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 143.067463] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 143.091498] RTAI[math]: loaded.
[ 153.790592] RTAI[math]: unloaded.
[ 153.794044] SCHED releases registered named ALIEN PEDV$D
[ 153.802819] RTAI[malloc]: unloaded.
[ 153.900014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 153.902813] I-pipe: head domain RTAI unregistered.
[ 153.902827] RTAI[hal]: unmounted.
[ 216.603014] I-pipe: head domain RTAI registered.
[ 216.603025] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 216.603034] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 216.603039] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 216.603043] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 216.603048] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12405000
[ 216.618706] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 216.618768] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 216.618774] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 216.618779] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 216.618782] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 216.636430] RTAI[math]: loaded.
[ 239.785191] RTAI[math]: unloaded.
[ 239.788626] SCHED releases registered named ALIEN PEDV$D
[ 239.798503] RTAI[malloc]: unloaded.
[ 239.896056] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 239.899613] I-pipe: head domain RTAI unregistered.
[ 239.899626] RTAI[hal]: unmounted.
[ 301.052653] I-pipe: head domain RTAI registered.
[ 301.052663] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 301.052672] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 301.052677] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 301.052681] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 301.052686] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12401250
[ 301.068103] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 301.068165] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 301.068171] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 301.068176] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 301.068180] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 301.081452] RTAI[math]: loaded.
[ 731.116439] RTAI[math]: unloaded.
[ 731.119597] SCHED releases registered named ALIEN PEDV$D
[ 731.128502] RTAI[malloc]: unloaded.
[ 731.228020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 731.230796] I-pipe: head domain RTAI unregistered.
[ 731.230811] RTAI[hal]: unmounted.
[ 815.964698] I-pipe: head domain RTAI registered.
[ 815.964707] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 815.964716] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 815.964721] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 815.964726] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 815.964730] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12402000
[ 815.977752] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 815.977812] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 815.977818] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 815.977823] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 815.977827] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 815.992716] RTAI[math]: loaded.
[ 826.291753] RTAI[math]: unloaded.
[ 826.295189] SCHED releases registered named ALIEN PEDV$D
[ 826.306435] RTAI[malloc]: unloaded.
[ 826.404028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 826.407243] I-pipe: head domain RTAI unregistered.
[ 826.407258] RTAI[hal]: unmounted.
[ 882.060026] usb 5-2: new high-speed USB device number 2 using ehci_hcd
[ 882.194270] usb 5-2: New USB device found, idVendor=0930, idProduct=6545
[ 882.194275] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 882.194280] usb 5-2: Product: TransMemory
[ 882.194283] usb 5-2: Manufacturer: TOSHIBA
[ 882.194286] usb 5-2: SerialNumber: 001D92AF7F805B8A0A06010C
[ 882.263533] Initializing USB Mass Storage driver...
[ 882.263694] scsi4 : usb-storage 5-2:1.0
[ 882.264368] usbcore: registered new interface driver usb-storage
[ 882.264373] USB Mass Storage support registered.
[ 883.260802] scsi 4:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[ 883.265479] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 885.446542] sd 4:0:0:0: [sdb] 3966976 512-byte logical blocks: (2.03 GB/1.89 GiB)
[ 885.447030] sd 4:0:0:0: [sdb] Write Protect is off
[ 885.447035] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 885.447529] sd 4:0:0:0: [sdb] No Caching mode page present
[ 885.447534] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 885.451407] sd 4:0:0:0: [sdb] No Caching mode page present
[ 885.451414] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 885.497527] sdb:
[ 885.501677] sd 4:0:0:0: [sdb] No Caching mode page present
[ 885.501684] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 885.501690] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 887.098946] FAT-fs (sdb): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 952.532989] I-pipe: head domain RTAI registered.
[ 952.533000] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 952.533008] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 952.533013] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 952.533018] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 952.533022] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12372500
[ 952.546713] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 952.546775] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 952.546781] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 952.546786] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 952.546790] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 952.565045] RTAI[math]: loaded.
[ 953.134344] RTAI[math]: unloaded.
[ 953.137783] SCHED releases registered named ALIEN PEDV$D
[ 953.146524] RTAI[malloc]: unloaded.
[ 953.244017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 953.246819] I-pipe: head domain RTAI unregistered.
[ 953.246833] RTAI[hal]: unmounted.
[ 978.965062] I-pipe: head domain RTAI registered.
[ 978.965072] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 978.965081] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 978.965086] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 978.965090] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 978.965095] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12367250
[ 978.978711] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 978.978773] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 978.978779] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 978.978784] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 978.978788] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 978.996694] RTAI[math]: loaded.
[ 979.567972] RTAI[math]: unloaded.
[ 979.571430] SCHED releases registered named ALIEN PEDV$D
[ 979.579856] RTAI[malloc]: unloaded.
[ 979.676016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 979.678840] I-pipe: head domain RTAI unregistered.
[ 979.678853] RTAI[hal]: unmounted.
[ 1003.670525] I-pipe: head domain RTAI registered.
[ 1003.670535] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1003.670544] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1003.670549] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1003.670553] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1003.670558] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12403000
[ 1003.685872] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1003.685932] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1003.685938] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1003.685943] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1003.685946] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1003.702443] RTAI[math]: loaded.
[ 1004.284742] RTAI[math]: unloaded.
[ 1004.287930] SCHED releases registered named ALIEN PEDV$D
[ 1004.296707] RTAI[malloc]: unloaded.
[ 1004.396016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1004.398827] I-pipe: head domain RTAI unregistered.
[ 1004.398841] RTAI[hal]: unmounted.
[ 1116.777804] I-pipe: head domain RTAI registered.
[ 1116.777814] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1116.777823] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1116.777828] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1116.777833] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1116.777837] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12372000
[ 1116.791680] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1116.791739] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1116.791746] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1116.791751] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1116.791754] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1116.805452] RTAI[math]: loaded.
[ 1117.377776] RTAI[math]: unloaded.
[ 1117.381238] SCHED releases registered named ALIEN PEDV$D
[ 1117.390126] RTAI[malloc]: unloaded.
[ 1117.488019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1117.490801] I-pipe: head domain RTAI unregistered.
[ 1117.490815] RTAI[hal]: unmounted.
[ 1129.333423] I-pipe: head domain RTAI registered.
[ 1129.333433] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1129.333442] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1129.333447] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1129.333452] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1129.333456] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12374500
[ 1129.347577] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1129.347636] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1129.347642] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1129.347647] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1129.347650] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1129.365627] RTAI[math]: loaded.
[ 1129.978639] RTAI[math]: unloaded.
[ 1129.982092] SCHED releases registered named ALIEN PEDV$D
[ 1129.993122] RTAI[malloc]: unloaded.
[ 1130.092026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1130.095212] I-pipe: head domain RTAI unregistered.
[ 1130.095225] RTAI[hal]: unmounted.
[ 1172.205627] sdb: detected capacity change from 2031091712 to 0
[ 1175.693481] I-pipe: head domain RTAI registered.
[ 1175.693491] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1175.693500] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1175.693506] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1175.693510] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1175.693514] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12376250
[ 1175.708160] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1175.708217] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1175.708223] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1175.708228] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1175.708232] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1175.729412] RTAI[math]: loaded.
[ 1176.334007] RTAI[math]: unloaded.
[ 1176.337505] SCHED releases registered named ALIEN PEDV$D
[ 1176.346446] RTAI[malloc]: unloaded.
[ 1176.444017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1176.447238] I-pipe: head domain RTAI unregistered.
[ 1176.447252] RTAI[hal]: unmounted.
[ 1283.997193] usb 5-2: USB disconnect, device number 2
[ 1285.364018] usb 5-2: new high-speed USB device number 3 using ehci_hcd
[ 1285.498285] usb 5-2: New USB device found, idVendor=0930, idProduct=6545
[ 1285.498290] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1285.498295] usb 5-2: Product: TransMemory
[ 1285.498298] usb 5-2: Manufacturer: TOSHIBA
[ 1285.498301] usb 5-2: SerialNumber: 001D92AF7F805B8A0A06010C
[ 1285.499287] scsi5 : usb-storage 5-2:1.0
[ 1286.496812] scsi 5:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[ 1286.501493] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 1288.701805] sd 5:0:0:0: [sdb] 3966976 512-byte logical blocks: (2.03 GB/1.89 GiB)
[ 1288.702294] sd 5:0:0:0: [sdb] Write Protect is off
[ 1288.702299] sd 5:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 1288.702793] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1288.702798] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1288.706796] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1288.706803] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1288.753541] sdb:
[ 1288.757566] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1288.757574] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1288.757580] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 1302.797218] FAT-fs (sdb): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 1322.496724] sdb: detected capacity change from 2031091712 to 0
[ 1362.779422] I-pipe: head domain RTAI registered.
[ 1362.779433] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1362.779442] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1362.779448] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1362.779452] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1362.779457] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12402750
[ 1362.792990] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1362.793051] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1362.793057] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1362.793062] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1362.793065] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1362.807150] RTAI[math]: loaded.
[ 1363.005981] config string '0xd900 out 0xd700 out'
[ 1364.056620] RTAI[math]: unloaded.
[ 1364.059813] SCHED releases registered named ALIEN PEDV$D
[ 1364.068678] RTAI[malloc]: unloaded.
[ 1364.168038] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1364.170863] I-pipe: head domain RTAI unregistered.
[ 1364.170876] RTAI[hal]: unmounted.
[ 1378.179589] I-pipe: head domain RTAI registered.
[ 1378.179599] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1378.179607] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1378.179613] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1378.179617] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1378.179621] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12400000
[ 1378.193375] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1378.193436] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1378.193443] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1378.193448] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1378.193451] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1378.207241] RTAI[math]: loaded.
[ 1378.388028] config string '0xd900 out 0xd700 out'
[ 1379.217653] RTAI[math]: unloaded.
[ 1379.221141] SCHED releases registered named ALIEN PEDV$D
[ 1379.230235] RTAI[malloc]: unloaded.
[ 1379.328014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1379.330872] I-pipe: head domain RTAI unregistered.
[ 1379.330885] RTAI[hal]: unmounted.
[ 1390.461292] I-pipe: head domain RTAI registered.
[ 1390.461302] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1390.461311] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1390.461316] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1390.461320] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1390.461325] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12376500
[ 1390.475020] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1390.475079] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1390.475085] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1390.475090] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1390.475094] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1390.493069] RTAI[math]: loaded.
[ 1390.668027] config string '0xd900 out 0xd700 out'
[ 1391.671835] RTAI[math]: unloaded.
[ 1391.675228] SCHED releases registered named ALIEN PEDV$D
[ 1391.685104] RTAI[malloc]: unloaded.
[ 1391.784019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1391.786877] I-pipe: head domain RTAI unregistered.
[ 1391.786890] RTAI[hal]: unmounted.
[ 1433.476266] I-pipe: head domain RTAI registered.
[ 1433.476275] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1433.476283] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1433.476288] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1433.476293] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1433.476298] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12407250
[ 1433.490976] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1433.491036] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1433.491042] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1433.491047] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1433.491051] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1433.510485] RTAI[math]: loaded.
[ 1434.099761] RTAI[math]: unloaded.
[ 1434.103181] SCHED releases registered named ALIEN PEDV$D
[ 1434.111511] RTAI[malloc]: unloaded.
[ 1434.208026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1434.211221] I-pipe: head domain RTAI unregistered.
[ 1434.211235] RTAI[hal]: unmounted.
[ 1461.793228] I-pipe: head domain RTAI registered.
[ 1461.793237] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1461.793246] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1461.793252] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1461.793256] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1461.793260] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12374750
[ 1461.806696] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1461.806755] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1461.806761] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1461.806766] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1461.806770] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1461.824699] RTAI[math]: loaded.
[ 1462.000014] config string '0xd900 out 0xd700 out'
[ 1463.023695] RTAI[math]: unloaded.
[ 1463.027065] SCHED releases registered named ALIEN PEDV$D
[ 1463.035744] RTAI[malloc]: unloaded.
[ 1463.132384] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1463.135603] I-pipe: head domain RTAI unregistered.
[ 1463.135617] RTAI[hal]: unmounted.
[ 1489.972955] I-pipe: head domain RTAI registered.
[ 1489.972965] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1489.972974] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1489.972979] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1489.972983] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1489.972988] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12373250
[ 1489.986519] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1489.986578] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1489.986584] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1489.986589] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1489.986593] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1490.004447] RTAI[math]: loaded.
[ 1490.564176] RTAI[math]: unloaded.
[ 1490.567398] SCHED releases registered named ALIEN PEDV$D
[ 1490.576359] RTAI[malloc]: unloaded.
[ 1490.676016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1490.678834] I-pipe: head domain RTAI unregistered.
[ 1490.678848] RTAI[hal]: unmounted.
[ 1781.495605] I-pipe: head domain RTAI registered.
[ 1781.495615] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1781.495624] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1781.495629] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1781.495633] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1781.495638] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12404000
[ 1781.509242] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1781.509303] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1781.509309] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1781.509314] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1781.509318] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1781.522956] RTAI[math]: loaded.
[ 1781.700015] config string '0xd900 out 0xd700 out'
[ 1782.702220] spurious APIC interrupt on CPU#0, should never happen.
[ 1782.708838] RTAI[math]: unloaded.
[ 1782.712230] SCHED releases registered named ALIEN PEDV$D
[ 1782.720405] RTAI[malloc]: unloaded.
[ 1782.820016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1782.822843] I-pipe: head domain RTAI unregistered.
[ 1782.822856] RTAI[hal]: unmounted.
[ 3004.614328] I-pipe: head domain RTAI registered.
[ 3004.614338] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3004.614347] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3004.614352] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3004.614357] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3004.614361] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12386000
[ 3004.628208] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3004.628267] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3004.628273] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3004.628278] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3004.628281] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3004.641347] RTAI[math]: loaded.
[ 3005.212850] RTAI[math]: unloaded.
[ 3005.216286] SCHED releases registered named ALIEN PEDV$D
[ 3005.225209] RTAI[malloc]: unloaded.
[ 3005.324019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3005.326834] I-pipe: head domain RTAI unregistered.
[ 3005.326848] RTAI[hal]: unmounted.
[ 3025.292651] I-pipe: head domain RTAI registered.
[ 3025.292661] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3025.292670] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3025.292675] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3025.292680] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3025.292684] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12404250
[ 3025.306304] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3025.306367] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3025.306373] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3025.306378] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3025.306382] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3025.324763] RTAI[math]: loaded.
[ 3025.870590] RTAI[math]: unloaded.
[ 3025.874044] SCHED releases registered named ALIEN PEDV$D
[ 3025.882933] RTAI[malloc]: unloaded.
[ 3025.980018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3025.982845] I-pipe: head domain RTAI unregistered.
[ 3025.982859] RTAI[hal]: unmounted.
[ 3069.761781] I-pipe: head domain RTAI registered.
[ 3069.761791] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3069.761800] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3069.761805] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3069.761809] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3069.761814] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12374250
[ 3069.775560] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3069.775621] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3069.775628] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3069.775633] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3069.775636] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3069.789375] RTAI[math]: loaded.
[ 3106.814326] RTAI[math]: unloaded.
[ 3106.818402] SCHED releases registered named ALIEN PEDV$D
[ 3106.828191] RTAI[malloc]: unloaded.
[ 3106.928027] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3106.931882] I-pipe: head domain RTAI unregistered.
[ 3106.931896] RTAI[hal]: unmounted.
[ 3120.463582] I-pipe: head domain RTAI registered.
[ 3120.463592] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3120.463602] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3120.463607] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3120.463611] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3120.463616] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12401250
[ 3120.477222] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3120.477281] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3120.477287] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3120.477292] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3120.477296] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3120.491329] RTAI[math]: loaded.
[ 3120.668017] config string '0xd900 out 0xd700 out'
[ 3121.667872] RTAI[math]: unloaded.
[ 3121.671272] SCHED releases registered named ALIEN PEDV$D
[ 3121.680319] RTAI[malloc]: unloaded.
[ 3121.780015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3121.782818] I-pipe: head domain RTAI unregistered.
[ 3121.782832] RTAI[hal]: unmounted.
[ 3338.490698] I-pipe: head domain RTAI registered.
[ 3338.490709] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3338.490718] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3338.490723] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3338.490727] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3338.490732] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12399500
[ 3338.504617] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3338.504677] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3338.504684] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3338.504689] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3338.504692] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3338.518395] RTAI[math]: loaded.
[ 3349.104586] RTAI[math]: unloaded.
[ 3349.108642] SCHED releases registered named ALIEN PEDV$D
[ 3349.118407] RTAI[malloc]: unloaded.
[ 3349.216028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3349.219219] I-pipe: head domain RTAI unregistered.
[ 3349.219232] RTAI[hal]: unmounted.
[ 3390.243822] usb 5-2: USB disconnect, device number 3
[ 3391.932019] usb 5-2: new high-speed USB device number 4 using ehci_hcd
[ 3392.065920] usb 5-2: New USB device found, idVendor=0930, idProduct=6545
[ 3392.065926] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3392.065931] usb 5-2: Product: TransMemory
[ 3392.065934] usb 5-2: Manufacturer: TOSHIBA
[ 3392.065937] usb 5-2: SerialNumber: 001D92AF7F805B8A0A06010C
[ 3392.066933] scsi6 : usb-storage 5-2:1.0
[ 3393.064830] scsi 6:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[ 3393.069462] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 3393.860064] sd 6:0:0:0: [sdb] 3966976 512-byte logical blocks: (2.03 GB/1.89 GiB)
[ 3393.860553] sd 6:0:0:0: [sdb] Write Protect is off
[ 3393.860558] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 3393.861052] sd 6:0:0:0: [sdb] No Caching mode page present
[ 3393.861057] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3393.864700] sd 6:0:0:0: [sdb] No Caching mode page present
[ 3393.864708] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3393.911677] sdb:
[ 3393.915568] sd 6:0:0:0: [sdb] No Caching mode page present
[ 3393.915576] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3393.915581] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 3396.669094] FAT-fs (sdb): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 3463.711386] I-pipe: head domain RTAI registered.
[ 3463.711396] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3463.711405] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3463.711410] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3463.711415] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3463.711419] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12403750
[ 3463.725111] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3463.725171] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3463.725177] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3463.725182] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3463.725186] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3463.739117] RTAI[math]: loaded.
[ 3482.119182] RTAI[math]: unloaded.
[ 3482.123418] SCHED releases registered named ALIEN PEDV$D
[ 3482.132291] RTAI[malloc]: unloaded.
[ 3482.232028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3482.235238] I-pipe: head domain RTAI unregistered.
[ 3482.235252] RTAI[hal]: unmounted.
[ 3549.473084] I-pipe: head domain RTAI registered.
[ 3549.473202] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3549.473212] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3549.473218] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3549.473222] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3549.473227] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 9022750
[ 3549.487731] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3549.487793] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3549.487799] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3549.487804] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3549.487807] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3549.501436] RTAI[math]: loaded.
[ 3557.880844] RTAI[math]: unloaded.
[ 3557.884894] SCHED releases registered named ALIEN PEDV$D
[ 3557.894730] RTAI[malloc]: unloaded.
[ 3557.992027] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3557.995885] I-pipe: head domain RTAI unregistered.
[ 3557.995899] RTAI[hal]: unmounted.
[ 3569.572579] I-pipe: head domain RTAI registered.
[ 3569.572589] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3569.572598] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3569.572603] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3569.572607] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3569.572612] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12405000
[ 3569.586301] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3569.586359] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3569.586366] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3569.586371] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3569.586374] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3569.604913] RTAI[math]: loaded.
[ 3569.780028] config string '0xd900 out 0xd700 out'
[ 3570.604107] RTAI[math]: unloaded.
[ 3570.607326] SCHED releases registered named ALIEN PEDV$D
[ 3570.616182] RTAI[malloc]: unloaded.
[ 3570.716020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3570.718813] I-pipe: head domain RTAI unregistered.
[ 3570.718827] RTAI[hal]: unmounted.
[ 3655.986537] I-pipe: head domain RTAI registered.
[ 3655.986547] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3655.986556] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3655.986561] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3655.986565] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3655.986570] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12399000
[ 3656.000264] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3656.000324] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3656.000331] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3656.000336] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3656.000339] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3656.015094] RTAI[math]: loaded.
[ 3656.192017] config string '0xd900 out 0xd700 out'
[ 3657.187073] RTAI[math]: unloaded.
[ 3657.190503] SCHED releases registered named ALIEN PEDV$D
[ 3657.199199] RTAI[malloc]: unloaded.
[ 3657.296018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3657.298788] I-pipe: head domain RTAI unregistered.
[ 3657.298802] RTAI[hal]: unmounted.
[ 3922.280797] I-pipe: head domain RTAI registered.
[ 3922.280807] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3922.280816] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3922.280822] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3922.280826] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3922.280830] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12408250
[ 3922.294690] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3922.294754] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3922.294761] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3922.294766] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3922.294769] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3922.313019] RTAI[math]: loaded.
[ 3922.488015] config string '0xd900 out 0xd700 out'
[ 3923.704535] RTAI[math]: unloaded.
[ 3923.716123] SCHED releases registered named ALIEN PEDV$D
[ 3923.725591] RTAI[malloc]: unloaded.
[ 3923.824022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3923.827226] I-pipe: head domain RTAI unregistered.
[ 3923.827239] RTAI[hal]: unmounted.
[ 4026.894636] I-pipe: head domain RTAI registered.
[ 4026.894646] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4026.894655] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4026.894660] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 4026.894664] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4026.894669] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12397000
[ 4026.908827] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4026.908888] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4026.908894] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 4026.908899] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 4026.908903] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4026.922816] RTAI[math]: loaded.
[ 4027.100014] config string '0xd900 out 0xd700 out'
[ 4028.428295] RTAI[math]: unloaded.
[ 4028.438459] SCHED releases registered named ALIEN PEDV$D
[ 4028.450396] RTAI[malloc]: unloaded.
[ 4028.548020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4028.551345] I-pipe: head domain RTAI unregistered.
[ 4028.551360] RTAI[hal]: unmounted.
I have started the Configuration Selector and it has my .ini in the header, I click OK and I get the log below.
Can someone point me in the correct direction please.
Thanks in advance.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.13
Machine configuration directory is '/home/allen/linuxcnc/configs/Router'
Machine configuration file is 'Router.ini.expanded'
INIFILE=/home/allen/linuxcnc/configs/Router/Router.ini.expanded
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=11149
Debug file information:
couldn't read file "LIB:xhc-hb04.tcl": no such file or directory
while executing
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
11149
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cf590000 (usable)
[ 0.000000] BIOS-e820: 00000000cf590000 - 00000000cf5e3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cf5e3000 - 00000000cf5f0000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cf5f0000 - 00000000cf600000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. Vostro 200/0CU409, BIOS 1.0.3 07/12/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcf590 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CAFFF write-protect
[ 0.000000] CB000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 100000000 mask FF0000000 write-back
[ 0.000000] 1 base 000000000 mask F80000000 write-back
[ 0.000000] 2 base 080000000 mask FC0000000 write-back
[ 0.000000] 3 base 0C0000000 mask FF0000000 write-back
[ 0.000000] 4 base 0CF700000 mask FFFF00000 uncachable
[ 0.000000] 5 base 0CF800000 mask FFF800000 uncachable
[ 0.000000] 6 base 0CF600000 mask FFFF00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf600000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00f3e30] f3e30
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36528000 - 3728c000
[ 0.000000] ACPI: RSDP 000f96c0 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT cf5e3080 00054 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP cf5e7200 000F4 (v03 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT cf5e3200 03FFC (v01 DELL AWRDACPI 00001000 MSFT 03000000)
[ 0.000000] ACPI: FACS cf590000 00040
[ 0.000000] ACPI: HPET cf5e73c0 00038 (v01 DELL FX09 42302E31 AWRD 00000098)
[ 0.000000] ACPI: MCFG cf5e7400 0003C (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: SLIC cf5e7440 00176 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DMY2 cf5e75c0 00080 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC cf5e7300 00084 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2429MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cf590
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000cf590
[ 0.000000] On node 0 totalpages: 849182
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b38200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4860 pages used for memmap
[ 0.000000] HighMem zone: 617110 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at cf600000 (gap: cf600000:10a00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 842546
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=100f21bf-db51-49d3-b79f-e113983e3fa8 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 6794240 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cf590)
[ 0.000000] Memory: 3342812k/3397184k available (3495k kernel code, 53916k reserved, 1237k data, 416k init, 2487880k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1596.019 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 3192.03 BogoMIPS (lpj=6384076)
[ 0.004009] pid_max: default: 32768 minimum: 301
[ 0.004079] Security Framework initialized
[ 0.004087] AppArmor: AppArmor disabled by boot time parameter
[ 0.004115] Mount-cache hash table entries: 512
[ 0.004443] Initializing cgroup subsys cpuacct
[ 0.004448] Initializing cgroup subsys memory
[ 0.004460] Initializing cgroup subsys devices
[ 0.004465] Initializing cgroup subsys freezer
[ 0.004468] Initializing cgroup subsys net_cls
[ 0.004471] Initializing cgroup subsys blkio
[ 0.004481] Initializing cgroup subsys perf_event
[ 0.004526] mce: CPU supports 6 MCE banks
[ 0.004536] CPU0: Thermal monitoring enabled (TM2)
[ 0.004613] SMP alternatives: switching to UP code
[ 0.010005] ACPI: Core revision 20120320
[ 0.016072] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016445] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.056343] CPU0: Intel(R) Celeron(R) CPU 420 @ 1.60GHz stepping 01
[ 0.060003] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.060003] ... version: 2
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 2
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 000000007fffffff
[ 0.060003] ... fixed-purpose events: 3
[ 0.060003] ... event mask: 0000000700000003
[ 0.068125] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.068196] Brought up 1 CPUs
[ 0.068200] Total of 1 processors activated (3192.03 BogoMIPS).
[ 0.068795] devtmpfs: initialized
[ 0.069205] PM: Registering ACPI NVS region [mem 0xcf590000-0xcf5e2fff] (339968 bytes)
[ 0.069384] dummy:
[ 0.069471] NET: Registered protocol family 16
[ 0.069696] ACPI: bus type pci registered
[ 0.069786] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.069792] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.069795] PCI: Using MMCONFIG for extended config space
[ 0.069798] PCI: Using configuration type 1 for base access
[ 0.070754] bio: create slab <bio-0> at 0
[ 0.070890] ACPI: Added _OSI(Module Device)
[ 0.070894] ACPI: Added _OSI(Processor Device)
[ 0.070898] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.070902] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.072594] ACPI: EC: Look up EC in DSDT
[ 0.079902] ACPI: Interpreter enabled
[ 0.079917] ACPI: (supports S0 S3 S4 S5)
[ 0.079960] ACPI: Using IOAPIC for interrupt routing
[ 0.087170] ACPI: No dock devices found.
[ 0.087180] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.087290] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.087439] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.087444] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.087448] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.087452] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.087456] pci_root PNP0A08:00: host bridge window [mem 0xcf600000-0xfebfffff] (ignored)
[ 0.087461] PCI: root bus 00: using default resources
[ 0.087526] PCI host bridge to bus 0000:00
[ 0.087531] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.087535] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.087552] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000
[ 0.087615] pci 0000:00:01.0: [8086:29c1] type 01 class 0x060400
[ 0.087664] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.087690] pci 0000:00:02.0: [8086:29c2] type 00 class 0x030000
[ 0.087706] pci 0000:00:02.0: reg 10: [mem 0xfdf00000-0xfdf7ffff]
[ 0.087715] pci 0000:00:02.0: reg 14: [io 0xff00-0xff07]
[ 0.087724] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
[ 0.087733] pci 0000:00:02.0: reg 1c: [mem 0xfdb00000-0xfdbfffff]
[ 0.087815] pci 0000:00:19.0: [8086:10c0] type 00 class 0x020000
[ 0.087838] pci 0000:00:19.0: reg 10: [mem 0xfdfc0000-0xfdfdffff]
[ 0.087850] pci 0000:00:19.0: reg 14: [mem 0xfdfff000-0xfdffffff]
[ 0.087861] pci 0000:00:19.0: reg 18: [io 0xfe00-0xfe1f]
[ 0.087924] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.087951] pci 0000:00:1a.0: [8086:2937] type 00 class 0x0c0300
[ 0.088022] pci 0000:00:1a.0: reg 20: [io 0xfd00-0xfd1f]
[ 0.088079] pci 0000:00:1a.1: [8086:2938] type 00 class 0x0c0300
[ 0.088132] pci 0000:00:1a.1: reg 20: [io 0xfc00-0xfc1f]
[ 0.088188] pci 0000:00:1a.2: [8086:2939] type 00 class 0x0c0300
[ 0.088241] pci 0000:00:1a.2: reg 20: [io 0xfb00-0xfb1f]
[ 0.088307] pci 0000:00:1a.7: [8086:293c] type 00 class 0x0c0320
[ 0.088333] pci 0000:00:1a.7: reg 10: [mem 0xfdffe000-0xfdffe3ff]
[ 0.088422] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.088457] pci 0000:00:1b.0: [8086:293e] type 00 class 0x040300
[ 0.088477] pci 0000:00:1b.0: reg 10: [mem 0xfdff4000-0xfdff7fff 64bit]
[ 0.088546] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.088575] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
[ 0.088628] pci 0000:00:1d.0: reg 20: [io 0xfa00-0xfa1f]
[ 0.088685] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
[ 0.088738] pci 0000:00:1d.1: reg 20: [io 0xf900-0xf91f]
[ 0.088793] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
[ 0.088846] pci 0000:00:1d.2: reg 20: [io 0xf800-0xf81f]
[ 0.088913] pci 0000:00:1d.7: [8086:293a] type 00 class 0x0c0320
[ 0.088939] pci 0000:00:1d.7: reg 10: [mem 0xfdffd000-0xfdffd3ff]
[ 0.089029] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.089056] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.089128] pci 0000:00:1f.0: [8086:2916] type 00 class 0x060100
[ 0.089225] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0800 (mask 003f)
[ 0.089230] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 003f)
[ 0.089275] pci 0000:00:1f.2: [8086:2920] type 00 class 0x01018f
[ 0.089295] pci 0000:00:1f.2: reg 10: [io 0xf700-0xf707]
[ 0.089306] pci 0000:00:1f.2: reg 14: [io 0xf600-0xf603]
[ 0.089317] pci 0000:00:1f.2: reg 18: [io 0xf500-0xf507]
[ 0.089327] pci 0000:00:1f.2: reg 1c: [io 0xf400-0xf403]
[ 0.089338] pci 0000:00:1f.2: reg 20: [io 0xf300-0xf30f]
[ 0.089349] pci 0000:00:1f.2: reg 24: [io 0xf200-0xf20f]
[ 0.089398] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500
[ 0.089418] pci 0000:00:1f.3: reg 10: [mem 0xfdffc000-0xfdffc0ff 64bit]
[ 0.089445] pci 0000:00:1f.3: reg 20: [io 0x0500-0x051f]
[ 0.089486] pci 0000:00:1f.5: [8086:2926] type 00 class 0x010185
[ 0.089507] pci 0000:00:1f.5: reg 10: [io 0xf000-0xf007]
[ 0.089518] pci 0000:00:1f.5: reg 14: [io 0xef00-0xef03]
[ 0.089529] pci 0000:00:1f.5: reg 18: [io 0xee00-0xee07]
[ 0.089539] pci 0000:00:1f.5: reg 1c: [io 0xed00-0xed03]
[ 0.089550] pci 0000:00:1f.5: reg 20: [io 0xec00-0xec0f]
[ 0.089561] pci 0000:00:1f.5: reg 24: [io 0xeb00-0xeb0f]
[ 0.089642] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.089647] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
[ 0.089652] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.089659] pci 0000:00:01.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.089697] pci 0000:02:00.0: [5372:6872] type 00 class 0x078000
[ 0.089714] pci 0000:02:00.0: reg 10: [io 0xdf00-0xdf07]
[ 0.089727] pci 0000:02:00.0: reg 14: [io 0xde00-0xde07]
[ 0.089740] pci 0000:02:00.0: reg 18: [io 0xdd00-0xdd07]
[ 0.089753] pci 0000:02:00.0: reg 1c: [io 0xdc00-0xdc07]
[ 0.089765] pci 0000:02:00.0: reg 20: [io 0xdb00-0xdb07]
[ 0.089778] pci 0000:02:00.0: reg 24: [io 0xda00-0xda0f]
[ 0.089813] pci 0000:02:01.0: [9710:9865] type 00 class 0x070103
[ 0.089835] pci 0000:02:01.0: reg 10: [io 0xd900-0xd907]
[ 0.089848] pci 0000:02:01.0: reg 14: [io 0xd800-0xd807]
[ 0.089861] pci 0000:02:01.0: reg 18: [mem 0xfddff000-0xfddfffff]
[ 0.089884] pci 0000:02:01.0: reg 20: [mem 0xfddfe000-0xfddfefff]
[ 0.089928] pci 0000:02:01.0: PME# supported from D0 D3cold
[ 0.089955] pci 0000:02:01.2: [9710:9865] type 00 class 0x070103
[ 0.089977] pci 0000:02:01.2: reg 10: [io 0xd700-0xd707]
[ 0.089990] pci 0000:02:01.2: reg 14: [io 0xd600-0xd607]
[ 0.090003] pci 0000:02:01.2: reg 18: [mem 0xfddfd000-0xfddfdfff]
[ 0.090026] pci 0000:02:01.2: reg 20: [mem 0xfddfc000-0xfddfcfff]
[ 0.090070] pci 0000:02:01.2: PME# supported from D0 D3cold
[ 0.090133] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.090139] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.090145] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.090153] pci 0000:00:1e.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.090157] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.090161] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.090175] pci_bus 0000:00: on NUMA node 0
[ 0.090180] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.090581] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.090812] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.113570] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.113665] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.113759] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 7 9 10 11 12 14 15)
[ 0.113851] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.113942] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.114034] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *9 10 11 12 14 15)
[ 0.114126] ACPI: PCI Interrupt Link [LNK0] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.114217] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.114362] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.114381] vgaarb: loaded
[ 0.114384] vgaarb: bridge control possible 0000:00:02.0
[ 0.114433] PCI: Using ACPI for IRQ routing
[ 0.121778] PCI: pci_cache_line_size set to 64 bytes
[ 0.121878] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[ 0.121883] reserve RAM buffer: 00000000cf590000 - 00000000cfffffff
[ 0.122103] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.122114] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.124032] Switching to clocksource hpet
[ 0.124123] pnp: PnP ACPI init
[ 0.124143] ACPI: bus type pnp registered
[ 0.124287] pnp 00:00: [bus 00-ff]
[ 0.124293] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.124297] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.124301] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.124305] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.124308] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.124312] pnp 00:00: [mem 0xcf600000-0xfebfffff window]
[ 0.124392] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.124524] pnp 00:01: [io 0x0010-0x001f]
[ 0.124528] pnp 00:01: [io 0x0022-0x003f]
[ 0.124531] pnp 00:01: [io 0x0044-0x005f]
[ 0.124535] pnp 00:01: [io 0x0060]
[ 0.124538] pnp 00:01: [io 0x0064]
[ 0.124541] pnp 00:01: [io 0x0062-0x0063]
[ 0.124544] pnp 00:01: [io 0x0065-0x006f]
[ 0.124548] pnp 00:01: [io 0x0074-0x007f]
[ 0.124554] pnp 00:01: [io 0x0091-0x0093]
[ 0.124557] pnp 00:01: [io 0x00a2-0x00bf]
[ 0.124560] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.124564] pnp 00:01: [io 0x04d0-0x04d1]
[ 0.124567] pnp 00:01: [io 0x0800-0x087f]
[ 0.124570] pnp 00:01: [io 0x0290-0x0297]
[ 0.124574] pnp 00:01: [io 0x0880-0x088f]
[ 0.124670] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.124675] system 00:01: [io 0x0800-0x087f] has been reserved
[ 0.124679] system 00:01: [io 0x0290-0x0297] has been reserved
[ 0.124683] system 00:01: [io 0x0880-0x088f] has been reserved
[ 0.124688] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.124712] pnp 00:02: [dma 4]
[ 0.124716] pnp 00:02: [io 0x0000-0x000f]
[ 0.124719] pnp 00:02: [io 0x0080-0x0090]
[ 0.124722] pnp 00:02: [io 0x0094-0x009f]
[ 0.124726] pnp 00:02: [io 0x00c0-0x00df]
[ 0.124768] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.124867] pnp 00:03: [irq 0 disabled]
[ 0.124881] pnp 00:03: [irq 8]
[ 0.124885] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 0.124935] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.124992] pnp 00:04: [io 0x0070-0x0073]
[ 0.125038] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.125058] pnp 00:05: [io 0x0061]
[ 0.125100] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.125118] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.125126] pnp 00:06: [irq 13]
[ 0.125172] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.125416] pnp 00:07: [io 0x03f0-0x03f5]
[ 0.125420] pnp 00:07: [io 0x03f7]
[ 0.125428] pnp 00:07: [irq 6]
[ 0.125431] pnp 00:07: [dma 2]
[ 0.125499] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.125615] pnp 00:08: [io 0x0400-0x04bf]
[ 0.125692] system 00:08: [io 0x0400-0x04bf] has been reserved
[ 0.125697] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.125737] pnp 00:09: [mem 0xffb80000-0xffbfffff]
[ 0.125790] pnp 00:09: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.126185] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.126276] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.126282] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.126431] pnp 00:0b: [mem 0x000f0000-0x000fffff]
[ 0.126435] pnp 00:0b: [mem 0xcf600000-0xcf6fffff]
[ 0.126439] pnp 00:0b: [mem 0xfed00000-0xfed000ff]
[ 0.126443] pnp 00:0b: [mem 0xcf590000-0xcf5fffff]
[ 0.126446] pnp 00:0b: [mem 0x00000000-0x0009ffff]
[ 0.126449] pnp 00:0b: [mem 0x00100000-0xcf58ffff]
[ 0.126453] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[ 0.126456] pnp 00:0b: [mem 0xfed14000-0xfed1dfff]
[ 0.126460] pnp 00:0b: [mem 0xfed20000-0xfed9ffff]
[ 0.126463] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[ 0.126466] pnp 00:0b: [mem 0xffb00000-0xffb7ffff]
[ 0.126470] pnp 00:0b: [mem 0xfff00000-0xffffffff]
[ 0.126473] pnp 00:0b: [mem 0x000e0000-0x000effff]
[ 0.126580] system 00:0b: [mem 0x000f0000-0x000fffff] could not be reserved
[ 0.126586] system 00:0b: [mem 0xcf600000-0xcf6fffff] could not be reserved
[ 0.126591] system 00:0b: [mem 0xfed00000-0xfed000ff] has been reserved
[ 0.126596] system 00:0b: [mem 0xcf590000-0xcf5fffff] could not be reserved
[ 0.126600] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.126605] system 00:0b: [mem 0x00100000-0xcf58ffff] could not be reserved
[ 0.126610] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.126614] system 00:0b: [mem 0xfed14000-0xfed1dfff] has been reserved
[ 0.126619] system 00:0b: [mem 0xfed20000-0xfed9ffff] has been reserved
[ 0.126624] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.126628] system 00:0b: [mem 0xffb00000-0xffb7ffff] has been reserved
[ 0.126633] system 00:0b: [mem 0xfff00000-0xffffffff] has been reserved
[ 0.126644] system 00:0b: [mem 0x000e0000-0x000effff] has been reserved
[ 0.126650] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.126666] pnp: PnP ACPI: found 12 devices
[ 0.126668] ACPI: ACPI bus type pnp unregistered
[ 0.126674] PnPBIOS: Disabled by ACPI PNP
[ 0.163758] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.163764] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
[ 0.163771] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.163776] pci 0000:00:01.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.163784] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.163789] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.163796] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.163801] pci 0000:00:1e.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.163839] pci 0000:00:1e.0: setting latency timer to 64
[ 0.163845] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.163849] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.163853] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff]
[ 0.163856] pci_bus 0000:01: resource 1 [mem 0xfde00000-0xfdefffff]
[ 0.163860] pci_bus 0000:01: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.163864] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.163868] pci_bus 0000:02: resource 1 [mem 0xfdd00000-0xfddfffff]
[ 0.163872] pci_bus 0000:02: resource 2 [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.163875] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.163879] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.163977] NET: Registered protocol family 2
[ 0.164093] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.164364] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.165013] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.165379] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.165384] TCP: reno registered
[ 0.165391] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.165406] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.165565] NET: Registered protocol family 1
[ 0.165596] pci 0000:00:02.0: Boot video device
[ 0.165863] PCI: CLS mismatch (64 != 32), using 64 bytes
[ 0.165942] Unpacking initramfs...
[ 0.582425] Freeing initrd memory: 13712k freed
[ 0.590091] audit: initializing netlink socket (disabled)
[ 0.590117] type=2000 audit(1526848389.584:1): initialized
[ 0.607030] highmem bounce pool size: 64 pages
[ 0.607038] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.607236] VFS: Disk quotas dquot_6.5.2
[ 0.607271] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.607379] msgmni has been set to 1696
[ 0.607602] alg: No test for stdrng (krng)
[ 0.607643] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.607648] io scheduler noop registered
[ 0.607651] io scheduler deadline registered
[ 0.607671] io scheduler cfq registered (default)
[ 0.607859] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.607886] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.607890] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.608536] GHES: HEST is not enabled!
[ 0.608556] isapnp: Scanning for PnP cards...
[ 0.961752] isapnp: No Plug & Play device found
[ 0.961826] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.962477] Linux agpgart interface v0.103
[ 0.962617] agpgart-intel 0000:00:00.0: Intel G33 Chipset
[ 0.962711] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 0.962865] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 0.962991] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 0.963183] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.963601] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.963650] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.963778] mousedev: PS/2 mouse device common for all mice
[ 0.963845] rtc_cmos 00:04: RTC can wake from S4
[ 0.963988] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.964044] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 0.964249] TCP: cubic registered
[ 0.964305] NET: Registered protocol family 10
[ 0.964638] Mobile IPv6
[ 0.964644] NET: Registered protocol family 17
[ 0.964652] Registering the dns_resolver key type
[ 0.964745] Using IPI No-Shortcut mode
[ 0.964889] PM: Hibernation image not present or could not be loaded.
[ 0.964906] registered taskstats version 1
[ 0.965402] rtc_cmos 00:04: setting system clock to 2018-05-20 20:33:10 UTC (1526848390)
[ 0.965529] Freeing unused kernel memory: 416k freed
[ 0.965753] Write protecting the kernel text: 3496k
[ 0.965778] Write protecting the kernel read-only data: 984k
[ 0.992134] udevd[45]: starting version 175
[ 1.042941] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 1.042946] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 1.043005] e1000e 0000:00:19.0: setting latency timer to 64
[ 1.043085] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.047655] ACPI: Fan [FAN] (on)
[ 1.055579] usbcore: registered new interface driver usbfs
[ 1.055619] usbcore: registered new interface driver hub
[ 1.090145] usbcore: registered new device driver usb
[ 1.090823] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.099880] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.168664] FDC 0 is a post-1991 82077
[ 1.191729] SCSI subsystem initialized
[ 1.214274] libata version 3.00 loaded.
[ 1.220546] microcode: CPU0 sig=0x10661, pf=0x1, revision=0x32
[ 1.276014] microcode: CPU0 updated to revision 0x43, date = 2010-10-04
[ 1.276491] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.312101] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:1a:a0:8c:24:a8
[ 1.312108] e1000e 0000:00:19.0: eth0: Intel(R) PRO/10/100 Network Connection
[ 1.312131] e1000e 0000:00:19.0: eth0: MAC: 7, PHY: 7, PBA No: FFFFFF-0FF
[ 1.312204] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 1.312210] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 1.312250] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.312287] ehci_hcd 0000:00:1a.7: debug port 1
[ 1.317594] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 1.317631] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfdffe000
[ 1.328019] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.328080] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.328084] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.328088] usb usb1: Product: EHCI Host Controller
[ 1.328091] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.328095] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.329523] hub 1-0:1.0: USB hub found
[ 1.329537] hub 1-0:1.0: 6 ports detected
[ 1.329709] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.329715] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.329730] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 1.329780] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000fd00
[ 1.329831] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.329835] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.329839] usb usb2: Product: UHCI Host Controller
[ 1.329842] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.329846] usb usb2: SerialNumber: 0000:00:1a.0
[ 1.330020] hub 2-0:1.0: USB hub found
[ 1.330028] hub 2-0:1.0: 2 ports detected
[ 1.330308] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 1.330314] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.330329] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 3
[ 1.330379] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000fc00
[ 1.330431] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.330435] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.330439] usb usb3: Product: UHCI Host Controller
[ 1.330442] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.330445] usb usb3: SerialNumber: 0000:00:1a.1
[ 1.330617] hub 3-0:1.0: USB hub found
[ 1.330625] hub 3-0:1.0: 2 ports detected
[ 1.332047] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 1.332053] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 1.332071] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 4
[ 1.332254] uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000fb00
[ 1.332672] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.332683] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.332693] usb usb4: Product: UHCI Host Controller
[ 1.332703] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.332713] usb usb4: SerialNumber: 0000:00:1a.2
[ 1.336253] hub 4-0:1.0: USB hub found
[ 1.336307] hub 4-0:1.0: 2 ports detected
[ 1.340193] ata_piix 0000:00:1f.2: version 2.13
[ 1.340336] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.340853] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.343566] scsi0 : ata_piix
[ 1.345565] scsi1 : ata_piix
[ 1.346713] ata1: SATA max UDMA/133 cmd 0xf700 ctl 0xf600 bmdma 0xf300 irq 19
[ 1.346723] ata2: SATA max UDMA/133 cmd 0xf500 ctl 0xf400 bmdma 0xf308 irq 19
[ 1.347052] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.347059] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.347083] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 1.347116] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.350998] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.351035] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfdffd000
[ 1.360017] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.360054] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.360058] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.360062] usb usb5: Product: EHCI Host Controller
[ 1.360065] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.360069] usb usb5: SerialNumber: 0000:00:1d.7
[ 1.361458] hub 5-0:1.0: USB hub found
[ 1.361472] hub 5-0:1.0: 6 ports detected
[ 1.361639] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.361645] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.361658] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 1.361690] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fa00
[ 1.361742] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.361746] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.361750] usb usb6: Product: UHCI Host Controller
[ 1.361753] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.361756] usb usb6: SerialNumber: 0000:00:1d.0
[ 1.361929] hub 6-0:1.0: USB hub found
[ 1.361940] hub 6-0:1.0: 2 ports detected
[ 1.362955] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.362962] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.362978] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 1.363015] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000f900
[ 1.363068] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.363072] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.363076] usb usb7: Product: UHCI Host Controller
[ 1.363079] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.363083] usb usb7: SerialNumber: 0000:00:1d.1
[ 1.363653] hub 7-0:1.0: USB hub found
[ 1.363662] hub 7-0:1.0: 2 ports detected
[ 1.365104] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.365110] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.365130] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 1.365164] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000f800
[ 1.365219] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.365224] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.365227] usb usb8: Product: UHCI Host Controller
[ 1.365231] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.365234] usb usb8: SerialNumber: 0000:00:1d.2
[ 1.365420] hub 8-0:1.0: USB hub found
[ 1.365428] hub 8-0:1.0: 2 ports detected
[ 1.366894] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.366956] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.372194] scsi2 : ata_piix
[ 1.376454] scsi3 : ata_piix
[ 1.376980] ata3: SATA max UDMA/133 cmd 0xf000 ctl 0xef00 bmdma 0xec00 irq 19
[ 1.376987] ata4: SATA max UDMA/133 cmd 0xee00 ctl 0xed00 bmdma 0xec08 irq 19
[ 1.600018] Refined TSC clocksource calibration: 1595.999 MHz.
[ 1.600026] Switching to clocksource tsc
[ 1.707050] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.717884] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.000015] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 2.140071] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.140084] ata1.01: SATA link down (SStatus 0 SControl 300)
[ 2.144064] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.144079] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 2.144091] ata2.01: link offline, clearing class 3 to NONE
[ 2.168125] ata2.00: ATAPI: PHILIPS DVD-ROM DROM6316, ODFN01, max UDMA/100
[ 2.168432] usb 3-1: New USB device found, idVendor=0461, idProduct=4d15
[ 2.168436] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.168440] usb 3-1: Product: USB Optical Mouse
[ 2.192123] ata1.00: ATA-7: ST3808110AS, 3.ADJ, max UDMA/133
[ 2.192129] ata1.00: 156250000 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.200252] ata2.00: configured for UDMA/100
[ 2.267070] ata1.00: configured for UDMA/133
[ 2.267229] scsi 0:0:0:0: Direct-Access ATA ST3808110AS 3.AD PQ: 0 ANSI: 5
[ 2.267825] scsi 1:0:0:0: CD-ROM PHILIPS DVD-ROM DROM6316 ODFN PQ: 0 ANSI: 5
[ 2.290971] sd 0:0:0:0: [sda] 156250000 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 2.291062] sd 0:0:0:0: [sda] Write Protect is off
[ 2.291067] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.291105] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.297072] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.1/usb3/3-1/3-1:1.0/input/input0
[ 2.297360] generic-usb 0003:0461:4D15.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.1-1/input0
[ 2.297458] usbcore: registered new interface driver usbhid
[ 2.297462] usbhid: USB HID core driver
[ 2.330207] sda: sda1 sda2 < sda5 >
[ 2.330720] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.334622] sr0: scsi3-mmc drive: 0x/48x cd/rw xa/form2 cdda tray
[ 2.334629] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.335386] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.349730] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.350558] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.408027] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 2.588433] usb 3-2: New USB device found, idVendor=04f2, idProduct=0841
[ 2.588439] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.588443] usb 3-2: Product: HP USB Multimedia Keyboard
[ 2.588446] usb 3-2: Manufacturer: CHICONY
[ 2.607115] input: CHICONY HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.1/usb3/3-2/3-2:1.0/input/input1
[ 2.607203] generic-usb 0003:04F2:0841.0002: input,hidraw1: USB HID v1.11 Keyboard [CHICONY HP USB Multimedia Keyboard] on usb-0000:00:1a.1-2/input0
[ 2.632748] input: CHICONY HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.1/usb3/3-2/3-2:1.1/input/input2
[ 2.632900] generic-usb 0003:04F2:0841.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [CHICONY HP USB Multimedia Keyboard] on usb-0000:00:1a.1-2/input1
[ 2.872018] usb 4-2: new full-speed USB device number 2 using uhci_hcd
[ 3.025469] usb 4-2: New USB device found, idVendor=10ce, idProduct=eb70
[ 3.025474] usb 4-2: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 3.025478] usb 4-2: Manufacturer: KTURT.LTD
[ 3.033682] generic-usb 0003:10CE:EB70.0004: hiddev0,hidraw3: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:1a.2-2/input0
[ 7.729932] PM: Starting manual resume from disk
[ 7.729939] PM: Hibernation image partition 8:5 present
[ 7.729941] PM: Looking for hibernation image.
[ 7.761199] PM: Image not found (code -22)
[ 7.761203] PM: Hibernation image not present or could not be loaded.
[ 7.815957] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.704485] udevd[350]: starting version 175
[ 10.179334] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 10.179344] ACPI: Power Button [PWRB]
[ 10.179451] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 10.179457] ACPI: Power Button [PWRF]
[ 10.258661] [drm] Initialized drm 1.1.0 20060810
[ 10.336531] iTCO_vendor_support: vendor-support=0
[ 10.337578] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 10.337697] iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0460)
[ 10.337784] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.372871] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 10.632118] i915 0000:00:02.0: setting latency timer to 64
[ 10.671442] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 10.671447] [drm] Driver supports precise vblank timestamp query.
[ 10.671501] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 10.688019] [drm] initialized overlay support
[ 10.697570] coretemp coretemp.0: Using relative temperature scale!
[ 10.738370] fbcon: inteldrmfb (fb0) is primary device
[ 10.785755] Console: switching to colour frame buffer device 200x56
[ 10.793624] fb0: inteldrmfb frame buffer device
[ 10.793628] drm: registered panic notifier
[ 10.793645] No ACPI video bus found
[ 10.794136] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.986848] PCI parallel port detected: 14f2:0121, I/O at 0xd900(0x0), IRQ 16
[ 10.986872] parport0: PC-style at 0xd900, irq 16 [PCSPP,TRISTATE,EPP]
[ 11.084203] PCI parallel port detected: 14f2:0121, I/O at 0xd700(0x0), IRQ 18
[ 11.084230] parport1: PC-style at 0xd700, irq 18 [PCSPP,TRISTATE,EPP]
[ 11.098800] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 11.107401] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 11.107668] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 11.107921] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 11.108213] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 11.108467] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 11.108716] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 11.108971] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 11.109224] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 13.053919] Adding 3211260k swap on /dev/sda5. Priority:-1 extents:1 across:3211260k
[ 13.078144] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.345984] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.487556] loop: module loaded
[ 15.422108] RPC: Registered named UNIX socket transport module.
[ 15.422113] RPC: Registered udp transport module.
[ 15.422116] RPC: Registered tcp transport module.
[ 15.422119] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.456341] FS-Cache: Loaded
[ 15.500579] NFS: Registering the id_resolver key type
[ 15.500610] FS-Cache: Netfs 'nfs' registered for caching
[ 15.508285] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 17.748149] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 19.483440] Bluetooth: Core ver 2.16
[ 19.483845] NET: Registered protocol family 31
[ 19.483850] Bluetooth: HCI device and connection manager initialized
[ 19.483854] Bluetooth: HCI socket layer initialized
[ 19.483857] Bluetooth: L2CAP socket layer initialized
[ 19.483867] Bluetooth: SCO socket layer initialized
[ 19.510399] Bluetooth: RFCOMM TTY layer initialized
[ 19.510408] Bluetooth: RFCOMM socket layer initialized
[ 19.510411] Bluetooth: RFCOMM ver 1.11
[ 19.577670] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.577675] Bluetooth: BNEP filters: protocol multicast
[ 19.792412] lp0: using parport0 (interrupt-driven).
[ 19.793526] lp1: using parport1 (interrupt-driven).
[ 19.897074] ppdev: user-space parallel port driver
[ 22.490594] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 25.593843] e1000e 0000:00:19.0: eth0: MAC Wakeup cause - Link Status Change
[ 27.268770] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 27.268778] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 27.268948] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 37.640008] eth0: no IPv6 routers present
[ 143.010972] I-pipe: head domain RTAI registered.
[ 143.010982] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 143.010991] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 143.010996] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 143.011000] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 143.011005] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 10595750
[ 143.067391] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 143.067448] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 143.067455] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 143.067460] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 143.067463] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 143.091498] RTAI[math]: loaded.
[ 153.790592] RTAI[math]: unloaded.
[ 153.794044] SCHED releases registered named ALIEN PEDV$D
[ 153.802819] RTAI[malloc]: unloaded.
[ 153.900014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 153.902813] I-pipe: head domain RTAI unregistered.
[ 153.902827] RTAI[hal]: unmounted.
[ 216.603014] I-pipe: head domain RTAI registered.
[ 216.603025] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 216.603034] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 216.603039] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 216.603043] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 216.603048] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12405000
[ 216.618706] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 216.618768] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 216.618774] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 216.618779] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 216.618782] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 216.636430] RTAI[math]: loaded.
[ 239.785191] RTAI[math]: unloaded.
[ 239.788626] SCHED releases registered named ALIEN PEDV$D
[ 239.798503] RTAI[malloc]: unloaded.
[ 239.896056] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 239.899613] I-pipe: head domain RTAI unregistered.
[ 239.899626] RTAI[hal]: unmounted.
[ 301.052653] I-pipe: head domain RTAI registered.
[ 301.052663] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 301.052672] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 301.052677] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 301.052681] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 301.052686] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12401250
[ 301.068103] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 301.068165] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 301.068171] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 301.068176] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 301.068180] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 301.081452] RTAI[math]: loaded.
[ 731.116439] RTAI[math]: unloaded.
[ 731.119597] SCHED releases registered named ALIEN PEDV$D
[ 731.128502] RTAI[malloc]: unloaded.
[ 731.228020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 731.230796] I-pipe: head domain RTAI unregistered.
[ 731.230811] RTAI[hal]: unmounted.
[ 815.964698] I-pipe: head domain RTAI registered.
[ 815.964707] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 815.964716] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 815.964721] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 815.964726] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 815.964730] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12402000
[ 815.977752] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 815.977812] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 815.977818] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 815.977823] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 815.977827] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 815.992716] RTAI[math]: loaded.
[ 826.291753] RTAI[math]: unloaded.
[ 826.295189] SCHED releases registered named ALIEN PEDV$D
[ 826.306435] RTAI[malloc]: unloaded.
[ 826.404028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 826.407243] I-pipe: head domain RTAI unregistered.
[ 826.407258] RTAI[hal]: unmounted.
[ 882.060026] usb 5-2: new high-speed USB device number 2 using ehci_hcd
[ 882.194270] usb 5-2: New USB device found, idVendor=0930, idProduct=6545
[ 882.194275] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 882.194280] usb 5-2: Product: TransMemory
[ 882.194283] usb 5-2: Manufacturer: TOSHIBA
[ 882.194286] usb 5-2: SerialNumber: 001D92AF7F805B8A0A06010C
[ 882.263533] Initializing USB Mass Storage driver...
[ 882.263694] scsi4 : usb-storage 5-2:1.0
[ 882.264368] usbcore: registered new interface driver usb-storage
[ 882.264373] USB Mass Storage support registered.
[ 883.260802] scsi 4:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[ 883.265479] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 885.446542] sd 4:0:0:0: [sdb] 3966976 512-byte logical blocks: (2.03 GB/1.89 GiB)
[ 885.447030] sd 4:0:0:0: [sdb] Write Protect is off
[ 885.447035] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 885.447529] sd 4:0:0:0: [sdb] No Caching mode page present
[ 885.447534] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 885.451407] sd 4:0:0:0: [sdb] No Caching mode page present
[ 885.451414] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 885.497527] sdb:
[ 885.501677] sd 4:0:0:0: [sdb] No Caching mode page present
[ 885.501684] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 885.501690] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 887.098946] FAT-fs (sdb): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 952.532989] I-pipe: head domain RTAI registered.
[ 952.533000] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 952.533008] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 952.533013] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 952.533018] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 952.533022] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12372500
[ 952.546713] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 952.546775] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 952.546781] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 952.546786] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 952.546790] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 952.565045] RTAI[math]: loaded.
[ 953.134344] RTAI[math]: unloaded.
[ 953.137783] SCHED releases registered named ALIEN PEDV$D
[ 953.146524] RTAI[malloc]: unloaded.
[ 953.244017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 953.246819] I-pipe: head domain RTAI unregistered.
[ 953.246833] RTAI[hal]: unmounted.
[ 978.965062] I-pipe: head domain RTAI registered.
[ 978.965072] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 978.965081] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 978.965086] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 978.965090] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 978.965095] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12367250
[ 978.978711] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 978.978773] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 978.978779] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 978.978784] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 978.978788] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 978.996694] RTAI[math]: loaded.
[ 979.567972] RTAI[math]: unloaded.
[ 979.571430] SCHED releases registered named ALIEN PEDV$D
[ 979.579856] RTAI[malloc]: unloaded.
[ 979.676016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 979.678840] I-pipe: head domain RTAI unregistered.
[ 979.678853] RTAI[hal]: unmounted.
[ 1003.670525] I-pipe: head domain RTAI registered.
[ 1003.670535] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1003.670544] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1003.670549] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1003.670553] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1003.670558] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12403000
[ 1003.685872] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1003.685932] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1003.685938] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1003.685943] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1003.685946] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1003.702443] RTAI[math]: loaded.
[ 1004.284742] RTAI[math]: unloaded.
[ 1004.287930] SCHED releases registered named ALIEN PEDV$D
[ 1004.296707] RTAI[malloc]: unloaded.
[ 1004.396016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1004.398827] I-pipe: head domain RTAI unregistered.
[ 1004.398841] RTAI[hal]: unmounted.
[ 1116.777804] I-pipe: head domain RTAI registered.
[ 1116.777814] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1116.777823] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1116.777828] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1116.777833] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1116.777837] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12372000
[ 1116.791680] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1116.791739] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1116.791746] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1116.791751] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1116.791754] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1116.805452] RTAI[math]: loaded.
[ 1117.377776] RTAI[math]: unloaded.
[ 1117.381238] SCHED releases registered named ALIEN PEDV$D
[ 1117.390126] RTAI[malloc]: unloaded.
[ 1117.488019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1117.490801] I-pipe: head domain RTAI unregistered.
[ 1117.490815] RTAI[hal]: unmounted.
[ 1129.333423] I-pipe: head domain RTAI registered.
[ 1129.333433] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1129.333442] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1129.333447] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1129.333452] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1129.333456] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12374500
[ 1129.347577] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1129.347636] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1129.347642] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1129.347647] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1129.347650] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1129.365627] RTAI[math]: loaded.
[ 1129.978639] RTAI[math]: unloaded.
[ 1129.982092] SCHED releases registered named ALIEN PEDV$D
[ 1129.993122] RTAI[malloc]: unloaded.
[ 1130.092026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1130.095212] I-pipe: head domain RTAI unregistered.
[ 1130.095225] RTAI[hal]: unmounted.
[ 1172.205627] sdb: detected capacity change from 2031091712 to 0
[ 1175.693481] I-pipe: head domain RTAI registered.
[ 1175.693491] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1175.693500] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1175.693506] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1175.693510] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1175.693514] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12376250
[ 1175.708160] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1175.708217] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1175.708223] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1175.708228] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1175.708232] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1175.729412] RTAI[math]: loaded.
[ 1176.334007] RTAI[math]: unloaded.
[ 1176.337505] SCHED releases registered named ALIEN PEDV$D
[ 1176.346446] RTAI[malloc]: unloaded.
[ 1176.444017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1176.447238] I-pipe: head domain RTAI unregistered.
[ 1176.447252] RTAI[hal]: unmounted.
[ 1283.997193] usb 5-2: USB disconnect, device number 2
[ 1285.364018] usb 5-2: new high-speed USB device number 3 using ehci_hcd
[ 1285.498285] usb 5-2: New USB device found, idVendor=0930, idProduct=6545
[ 1285.498290] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1285.498295] usb 5-2: Product: TransMemory
[ 1285.498298] usb 5-2: Manufacturer: TOSHIBA
[ 1285.498301] usb 5-2: SerialNumber: 001D92AF7F805B8A0A06010C
[ 1285.499287] scsi5 : usb-storage 5-2:1.0
[ 1286.496812] scsi 5:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[ 1286.501493] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 1288.701805] sd 5:0:0:0: [sdb] 3966976 512-byte logical blocks: (2.03 GB/1.89 GiB)
[ 1288.702294] sd 5:0:0:0: [sdb] Write Protect is off
[ 1288.702299] sd 5:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 1288.702793] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1288.702798] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1288.706796] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1288.706803] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1288.753541] sdb:
[ 1288.757566] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1288.757574] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1288.757580] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 1302.797218] FAT-fs (sdb): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 1322.496724] sdb: detected capacity change from 2031091712 to 0
[ 1362.779422] I-pipe: head domain RTAI registered.
[ 1362.779433] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1362.779442] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1362.779448] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1362.779452] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1362.779457] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12402750
[ 1362.792990] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1362.793051] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1362.793057] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1362.793062] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1362.793065] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1362.807150] RTAI[math]: loaded.
[ 1363.005981] config string '0xd900 out 0xd700 out'
[ 1364.056620] RTAI[math]: unloaded.
[ 1364.059813] SCHED releases registered named ALIEN PEDV$D
[ 1364.068678] RTAI[malloc]: unloaded.
[ 1364.168038] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1364.170863] I-pipe: head domain RTAI unregistered.
[ 1364.170876] RTAI[hal]: unmounted.
[ 1378.179589] I-pipe: head domain RTAI registered.
[ 1378.179599] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1378.179607] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1378.179613] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1378.179617] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1378.179621] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12400000
[ 1378.193375] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1378.193436] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1378.193443] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1378.193448] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1378.193451] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1378.207241] RTAI[math]: loaded.
[ 1378.388028] config string '0xd900 out 0xd700 out'
[ 1379.217653] RTAI[math]: unloaded.
[ 1379.221141] SCHED releases registered named ALIEN PEDV$D
[ 1379.230235] RTAI[malloc]: unloaded.
[ 1379.328014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1379.330872] I-pipe: head domain RTAI unregistered.
[ 1379.330885] RTAI[hal]: unmounted.
[ 1390.461292] I-pipe: head domain RTAI registered.
[ 1390.461302] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1390.461311] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1390.461316] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1390.461320] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1390.461325] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12376500
[ 1390.475020] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1390.475079] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1390.475085] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1390.475090] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1390.475094] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1390.493069] RTAI[math]: loaded.
[ 1390.668027] config string '0xd900 out 0xd700 out'
[ 1391.671835] RTAI[math]: unloaded.
[ 1391.675228] SCHED releases registered named ALIEN PEDV$D
[ 1391.685104] RTAI[malloc]: unloaded.
[ 1391.784019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1391.786877] I-pipe: head domain RTAI unregistered.
[ 1391.786890] RTAI[hal]: unmounted.
[ 1433.476266] I-pipe: head domain RTAI registered.
[ 1433.476275] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1433.476283] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1433.476288] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1433.476293] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1433.476298] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12407250
[ 1433.490976] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1433.491036] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1433.491042] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1433.491047] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1433.491051] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1433.510485] RTAI[math]: loaded.
[ 1434.099761] RTAI[math]: unloaded.
[ 1434.103181] SCHED releases registered named ALIEN PEDV$D
[ 1434.111511] RTAI[malloc]: unloaded.
[ 1434.208026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1434.211221] I-pipe: head domain RTAI unregistered.
[ 1434.211235] RTAI[hal]: unmounted.
[ 1461.793228] I-pipe: head domain RTAI registered.
[ 1461.793237] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1461.793246] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1461.793252] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1461.793256] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1461.793260] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12374750
[ 1461.806696] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1461.806755] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1461.806761] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1461.806766] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1461.806770] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1461.824699] RTAI[math]: loaded.
[ 1462.000014] config string '0xd900 out 0xd700 out'
[ 1463.023695] RTAI[math]: unloaded.
[ 1463.027065] SCHED releases registered named ALIEN PEDV$D
[ 1463.035744] RTAI[malloc]: unloaded.
[ 1463.132384] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1463.135603] I-pipe: head domain RTAI unregistered.
[ 1463.135617] RTAI[hal]: unmounted.
[ 1489.972955] I-pipe: head domain RTAI registered.
[ 1489.972965] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1489.972974] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1489.972979] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1489.972983] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1489.972988] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12373250
[ 1489.986519] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1489.986578] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1489.986584] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1489.986589] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1489.986593] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1490.004447] RTAI[math]: loaded.
[ 1490.564176] RTAI[math]: unloaded.
[ 1490.567398] SCHED releases registered named ALIEN PEDV$D
[ 1490.576359] RTAI[malloc]: unloaded.
[ 1490.676016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1490.678834] I-pipe: head domain RTAI unregistered.
[ 1490.678848] RTAI[hal]: unmounted.
[ 1781.495605] I-pipe: head domain RTAI registered.
[ 1781.495615] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1781.495624] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1781.495629] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 1781.495633] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1781.495638] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12404000
[ 1781.509242] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1781.509303] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1781.509309] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 1781.509314] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 1781.509318] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1781.522956] RTAI[math]: loaded.
[ 1781.700015] config string '0xd900 out 0xd700 out'
[ 1782.702220] spurious APIC interrupt on CPU#0, should never happen.
[ 1782.708838] RTAI[math]: unloaded.
[ 1782.712230] SCHED releases registered named ALIEN PEDV$D
[ 1782.720405] RTAI[malloc]: unloaded.
[ 1782.820016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1782.822843] I-pipe: head domain RTAI unregistered.
[ 1782.822856] RTAI[hal]: unmounted.
[ 3004.614328] I-pipe: head domain RTAI registered.
[ 3004.614338] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3004.614347] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3004.614352] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3004.614357] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3004.614361] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12386000
[ 3004.628208] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3004.628267] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3004.628273] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3004.628278] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3004.628281] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3004.641347] RTAI[math]: loaded.
[ 3005.212850] RTAI[math]: unloaded.
[ 3005.216286] SCHED releases registered named ALIEN PEDV$D
[ 3005.225209] RTAI[malloc]: unloaded.
[ 3005.324019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3005.326834] I-pipe: head domain RTAI unregistered.
[ 3005.326848] RTAI[hal]: unmounted.
[ 3025.292651] I-pipe: head domain RTAI registered.
[ 3025.292661] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3025.292670] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3025.292675] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3025.292680] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3025.292684] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12404250
[ 3025.306304] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3025.306367] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3025.306373] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3025.306378] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3025.306382] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3025.324763] RTAI[math]: loaded.
[ 3025.870590] RTAI[math]: unloaded.
[ 3025.874044] SCHED releases registered named ALIEN PEDV$D
[ 3025.882933] RTAI[malloc]: unloaded.
[ 3025.980018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3025.982845] I-pipe: head domain RTAI unregistered.
[ 3025.982859] RTAI[hal]: unmounted.
[ 3069.761781] I-pipe: head domain RTAI registered.
[ 3069.761791] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3069.761800] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3069.761805] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3069.761809] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3069.761814] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12374250
[ 3069.775560] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3069.775621] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3069.775628] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3069.775633] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3069.775636] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3069.789375] RTAI[math]: loaded.
[ 3106.814326] RTAI[math]: unloaded.
[ 3106.818402] SCHED releases registered named ALIEN PEDV$D
[ 3106.828191] RTAI[malloc]: unloaded.
[ 3106.928027] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3106.931882] I-pipe: head domain RTAI unregistered.
[ 3106.931896] RTAI[hal]: unmounted.
[ 3120.463582] I-pipe: head domain RTAI registered.
[ 3120.463592] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3120.463602] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3120.463607] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3120.463611] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3120.463616] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12401250
[ 3120.477222] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3120.477281] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3120.477287] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3120.477292] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3120.477296] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3120.491329] RTAI[math]: loaded.
[ 3120.668017] config string '0xd900 out 0xd700 out'
[ 3121.667872] RTAI[math]: unloaded.
[ 3121.671272] SCHED releases registered named ALIEN PEDV$D
[ 3121.680319] RTAI[malloc]: unloaded.
[ 3121.780015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3121.782818] I-pipe: head domain RTAI unregistered.
[ 3121.782832] RTAI[hal]: unmounted.
[ 3338.490698] I-pipe: head domain RTAI registered.
[ 3338.490709] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3338.490718] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3338.490723] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3338.490727] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3338.490732] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12399500
[ 3338.504617] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3338.504677] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3338.504684] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3338.504689] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3338.504692] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3338.518395] RTAI[math]: loaded.
[ 3349.104586] RTAI[math]: unloaded.
[ 3349.108642] SCHED releases registered named ALIEN PEDV$D
[ 3349.118407] RTAI[malloc]: unloaded.
[ 3349.216028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3349.219219] I-pipe: head domain RTAI unregistered.
[ 3349.219232] RTAI[hal]: unmounted.
[ 3390.243822] usb 5-2: USB disconnect, device number 3
[ 3391.932019] usb 5-2: new high-speed USB device number 4 using ehci_hcd
[ 3392.065920] usb 5-2: New USB device found, idVendor=0930, idProduct=6545
[ 3392.065926] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3392.065931] usb 5-2: Product: TransMemory
[ 3392.065934] usb 5-2: Manufacturer: TOSHIBA
[ 3392.065937] usb 5-2: SerialNumber: 001D92AF7F805B8A0A06010C
[ 3392.066933] scsi6 : usb-storage 5-2:1.0
[ 3393.064830] scsi 6:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[ 3393.069462] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 3393.860064] sd 6:0:0:0: [sdb] 3966976 512-byte logical blocks: (2.03 GB/1.89 GiB)
[ 3393.860553] sd 6:0:0:0: [sdb] Write Protect is off
[ 3393.860558] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 3393.861052] sd 6:0:0:0: [sdb] No Caching mode page present
[ 3393.861057] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3393.864700] sd 6:0:0:0: [sdb] No Caching mode page present
[ 3393.864708] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3393.911677] sdb:
[ 3393.915568] sd 6:0:0:0: [sdb] No Caching mode page present
[ 3393.915576] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3393.915581] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 3396.669094] FAT-fs (sdb): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 3463.711386] I-pipe: head domain RTAI registered.
[ 3463.711396] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3463.711405] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3463.711410] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3463.711415] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3463.711419] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12403750
[ 3463.725111] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3463.725171] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3463.725177] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3463.725182] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3463.725186] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3463.739117] RTAI[math]: loaded.
[ 3482.119182] RTAI[math]: unloaded.
[ 3482.123418] SCHED releases registered named ALIEN PEDV$D
[ 3482.132291] RTAI[malloc]: unloaded.
[ 3482.232028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3482.235238] I-pipe: head domain RTAI unregistered.
[ 3482.235252] RTAI[hal]: unmounted.
[ 3549.473084] I-pipe: head domain RTAI registered.
[ 3549.473202] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3549.473212] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3549.473218] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3549.473222] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3549.473227] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 9022750
[ 3549.487731] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3549.487793] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3549.487799] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3549.487804] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3549.487807] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3549.501436] RTAI[math]: loaded.
[ 3557.880844] RTAI[math]: unloaded.
[ 3557.884894] SCHED releases registered named ALIEN PEDV$D
[ 3557.894730] RTAI[malloc]: unloaded.
[ 3557.992027] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3557.995885] I-pipe: head domain RTAI unregistered.
[ 3557.995899] RTAI[hal]: unmounted.
[ 3569.572579] I-pipe: head domain RTAI registered.
[ 3569.572589] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3569.572598] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3569.572603] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3569.572607] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3569.572612] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12405000
[ 3569.586301] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3569.586359] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3569.586366] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3569.586371] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3569.586374] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3569.604913] RTAI[math]: loaded.
[ 3569.780028] config string '0xd900 out 0xd700 out'
[ 3570.604107] RTAI[math]: unloaded.
[ 3570.607326] SCHED releases registered named ALIEN PEDV$D
[ 3570.616182] RTAI[malloc]: unloaded.
[ 3570.716020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3570.718813] I-pipe: head domain RTAI unregistered.
[ 3570.718827] RTAI[hal]: unmounted.
[ 3655.986537] I-pipe: head domain RTAI registered.
[ 3655.986547] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3655.986556] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3655.986561] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3655.986565] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3655.986570] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12399000
[ 3656.000264] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3656.000324] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3656.000331] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3656.000336] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3656.000339] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3656.015094] RTAI[math]: loaded.
[ 3656.192017] config string '0xd900 out 0xd700 out'
[ 3657.187073] RTAI[math]: unloaded.
[ 3657.190503] SCHED releases registered named ALIEN PEDV$D
[ 3657.199199] RTAI[malloc]: unloaded.
[ 3657.296018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3657.298788] I-pipe: head domain RTAI unregistered.
[ 3657.298802] RTAI[hal]: unmounted.
[ 3922.280797] I-pipe: head domain RTAI registered.
[ 3922.280807] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3922.280816] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3922.280822] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 3922.280826] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3922.280830] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12408250
[ 3922.294690] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3922.294754] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3922.294761] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 3922.294766] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 3922.294769] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 3922.313019] RTAI[math]: loaded.
[ 3922.488015] config string '0xd900 out 0xd700 out'
[ 3923.704535] RTAI[math]: unloaded.
[ 3923.716123] SCHED releases registered named ALIEN PEDV$D
[ 3923.725591] RTAI[malloc]: unloaded.
[ 3923.824022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3923.827226] I-pipe: head domain RTAI unregistered.
[ 3923.827239] RTAI[hal]: unmounted.
[ 4026.894636] I-pipe: head domain RTAI registered.
[ 4026.894646] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4026.894655] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4026.894660] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 4026.894664] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4026.894669] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12397000
[ 4026.908827] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4026.908888] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4026.908894] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 4026.908899] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 4026.908903] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4026.922816] RTAI[math]: loaded.
[ 4027.100014] config string '0xd900 out 0xd700 out'
[ 4028.428295] RTAI[math]: unloaded.
[ 4028.438459] SCHED releases registered named ALIEN PEDV$D
[ 4028.450396] RTAI[malloc]: unloaded.
[ 4028.548020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4028.551345] I-pipe: head domain RTAI unregistered.
[ 4028.551360] RTAI[hal]: unmounted.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
21 May 2018 04:07 #110945
by InMyDarkestHour
Replied by InMyDarkestHour on topic Re-install LCNC
couldn't read file "LIB:xhc-hb04.tcl": no such file or directory
Seems to be the issue, is xhc-hb04.tcl,plus any other files that go with it in the directory that your ini is in ?
You should find a copy in
/usr/share/doc/linuxcnc/examples/sample-configs/sim/axis/xhc-hb04
- allenwg2005
- Topic Author
- Thank you received: 4
26 May 2018 18:19 - 29 May 2018 16:07 #111161
by allenwg2005
Replied by allenwg2005 on topic Re-install LCNC
I have that folder now in the same folder as my .ini, I'm not sure I moved the ball, here are the results:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.13
Machine configuration directory is '/home/allen/linuxcnc/configs/Router'
Machine configuration file is 'Router.ini.expanded'
INIFILE=/home/allen/linuxcnc/configs/Router/Router.ini.expanded
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=6587
Debug file information:
while executing
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
6587
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cf590000 (usable)
[ 0.000000] BIOS-e820: 00000000cf590000 - 00000000cf5e3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cf5e3000 - 00000000cf5f0000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cf5f0000 - 00000000cf600000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. Vostro 200/0CU409, BIOS 1.0.3 07/12/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcf590 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CAFFF write-protect
[ 0.000000] CB000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 100000000 mask FF0000000 write-back
[ 0.000000] 1 base 000000000 mask F80000000 write-back
[ 0.000000] 2 base 080000000 mask FC0000000 write-back
[ 0.000000] 3 base 0C0000000 mask FF0000000 write-back
[ 0.000000] 4 base 0CF700000 mask FFFF00000 uncachable
[ 0.000000] 5 base 0CF800000 mask FFF800000 uncachable
[ 0.000000] 6 base 0CF600000 mask FFFF00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf600000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00f3e30] f3e30
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36528000 - 3728c000
[ 0.000000] ACPI: RSDP 000f96c0 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT cf5e3080 00054 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP cf5e7200 000F4 (v03 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT cf5e3200 03FFC (v01 DELL AWRDACPI 00001000 MSFT 03000000)
[ 0.000000] ACPI: FACS cf590000 00040
[ 0.000000] ACPI: HPET cf5e73c0 00038 (v01 DELL FX09 42302E31 AWRD 00000098)
[ 0.000000] ACPI: MCFG cf5e7400 0003C (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: SLIC cf5e7440 00176 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DMY2 cf5e75c0 00080 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC cf5e7300 00084 (v01 DELL FX09 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2429MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cf590
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000cf590
[ 0.000000] On node 0 totalpages: 849182
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b38200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4860 pages used for memmap
[ 0.000000] HighMem zone: 617110 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at cf600000 (gap: cf600000:10a00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 842546
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=100f21bf-db51-49d3-b79f-e113983e3fa8 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 6794240 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cf590)
[ 0.000000] Memory: 3342812k/3397184k available (3495k kernel code, 53916k reserved, 1237k data, 416k init, 2487880k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1595.865 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 3191.73 BogoMIPS (lpj=6383460)
[ 0.004009] pid_max: default: 32768 minimum: 301
[ 0.004077] Security Framework initialized
[ 0.004085] AppArmor: AppArmor disabled by boot time parameter
[ 0.004112] Mount-cache hash table entries: 512
[ 0.004437] Initializing cgroup subsys cpuacct
[ 0.004441] Initializing cgroup subsys memory
[ 0.004454] Initializing cgroup subsys devices
[ 0.004457] Initializing cgroup subsys freezer
[ 0.004461] Initializing cgroup subsys net_cls
[ 0.004464] Initializing cgroup subsys blkio
[ 0.004475] Initializing cgroup subsys perf_event
[ 0.004520] mce: CPU supports 6 MCE banks
[ 0.004529] CPU0: Thermal monitoring enabled (TM2)
[ 0.004607] SMP alternatives: switching to UP code
[ 0.009790] ACPI: Core revision 20120320
[ 0.016074] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016448] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.056159] CPU0: Intel(R) Celeron(R) CPU 420 @ 1.60GHz stepping 01
[ 0.060003] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.060003] ... version: 2
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 2
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 000000007fffffff
[ 0.060003] ... fixed-purpose events: 3
[ 0.060003] ... event mask: 0000000700000003
[ 0.068128] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.068198] Brought up 1 CPUs
[ 0.068202] Total of 1 processors activated (3191.73 BogoMIPS).
[ 0.068800] devtmpfs: initialized
[ 0.069212] PM: Registering ACPI NVS region [mem 0xcf590000-0xcf5e2fff] (339968 bytes)
[ 0.069388] dummy:
[ 0.069474] NET: Registered protocol family 16
[ 0.069699] ACPI: bus type pci registered
[ 0.069793] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.069798] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.069801] PCI: Using MMCONFIG for extended config space
[ 0.069804] PCI: Using configuration type 1 for base access
[ 0.070759] bio: create slab <bio-0> at 0
[ 0.070895] ACPI: Added _OSI(Module Device)
[ 0.070900] ACPI: Added _OSI(Processor Device)
[ 0.070904] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.070908] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.072600] ACPI: EC: Look up EC in DSDT
[ 0.079913] ACPI: Interpreter enabled
[ 0.079928] ACPI: (supports S0 S3 S4 S5)
[ 0.079971] ACPI: Using IOAPIC for interrupt routing
[ 0.087188] ACPI: No dock devices found.
[ 0.087198] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.087308] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.087457] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.087462] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.087466] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.087470] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.087474] pci_root PNP0A08:00: host bridge window [mem 0xcf600000-0xfebfffff] (ignored)
[ 0.087479] PCI: root bus 00: using default resources
[ 0.087545] PCI host bridge to bus 0000:00
[ 0.087550] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.087554] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.087571] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000
[ 0.087635] pci 0000:00:01.0: [8086:29c1] type 01 class 0x060400
[ 0.087684] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.087710] pci 0000:00:02.0: [8086:29c2] type 00 class 0x030000
[ 0.087726] pci 0000:00:02.0: reg 10: [mem 0xfdf00000-0xfdf7ffff]
[ 0.087735] pci 0000:00:02.0: reg 14: [io 0xff00-0xff07]
[ 0.087744] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
[ 0.087753] pci 0000:00:02.0: reg 1c: [mem 0xfdb00000-0xfdbfffff]
[ 0.087835] pci 0000:00:19.0: [8086:10c0] type 00 class 0x020000
[ 0.087858] pci 0000:00:19.0: reg 10: [mem 0xfdfc0000-0xfdfdffff]
[ 0.087870] pci 0000:00:19.0: reg 14: [mem 0xfdfff000-0xfdffffff]
[ 0.087881] pci 0000:00:19.0: reg 18: [io 0xfe00-0xfe1f]
[ 0.087944] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.087972] pci 0000:00:1a.0: [8086:2937] type 00 class 0x0c0300
[ 0.088043] pci 0000:00:1a.0: reg 20: [io 0xfd00-0xfd1f]
[ 0.088100] pci 0000:00:1a.1: [8086:2938] type 00 class 0x0c0300
[ 0.088153] pci 0000:00:1a.1: reg 20: [io 0xfc00-0xfc1f]
[ 0.088209] pci 0000:00:1a.2: [8086:2939] type 00 class 0x0c0300
[ 0.088262] pci 0000:00:1a.2: reg 20: [io 0xfb00-0xfb1f]
[ 0.088328] pci 0000:00:1a.7: [8086:293c] type 00 class 0x0c0320
[ 0.088354] pci 0000:00:1a.7: reg 10: [mem 0xfdffe000-0xfdffe3ff]
[ 0.088444] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.088478] pci 0000:00:1b.0: [8086:293e] type 00 class 0x040300
[ 0.088498] pci 0000:00:1b.0: reg 10: [mem 0xfdff4000-0xfdff7fff 64bit]
[ 0.088568] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.088596] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
[ 0.088650] pci 0000:00:1d.0: reg 20: [io 0xfa00-0xfa1f]
[ 0.088706] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
[ 0.088759] pci 0000:00:1d.1: reg 20: [io 0xf900-0xf91f]
[ 0.088814] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
[ 0.088867] pci 0000:00:1d.2: reg 20: [io 0xf800-0xf81f]
[ 0.088934] pci 0000:00:1d.7: [8086:293a] type 00 class 0x0c0320
[ 0.088960] pci 0000:00:1d.7: reg 10: [mem 0xfdffd000-0xfdffd3ff]
[ 0.089050] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.089077] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.089149] pci 0000:00:1f.0: [8086:2916] type 00 class 0x060100
[ 0.089245] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0800 (mask 003f)
[ 0.089251] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 003f)
[ 0.089296] pci 0000:00:1f.2: [8086:2920] type 00 class 0x01018f
[ 0.089316] pci 0000:00:1f.2: reg 10: [io 0xf700-0xf707]
[ 0.089327] pci 0000:00:1f.2: reg 14: [io 0xf600-0xf603]
[ 0.089338] pci 0000:00:1f.2: reg 18: [io 0xf500-0xf507]
[ 0.089349] pci 0000:00:1f.2: reg 1c: [io 0xf400-0xf403]
[ 0.089359] pci 0000:00:1f.2: reg 20: [io 0xf300-0xf30f]
[ 0.089370] pci 0000:00:1f.2: reg 24: [io 0xf200-0xf20f]
[ 0.089419] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500
[ 0.089439] pci 0000:00:1f.3: reg 10: [mem 0xfdffc000-0xfdffc0ff 64bit]
[ 0.089466] pci 0000:00:1f.3: reg 20: [io 0x0500-0x051f]
[ 0.089508] pci 0000:00:1f.5: [8086:2926] type 00 class 0x010185
[ 0.089528] pci 0000:00:1f.5: reg 10: [io 0xf000-0xf007]
[ 0.089539] pci 0000:00:1f.5: reg 14: [io 0xef00-0xef03]
[ 0.089550] pci 0000:00:1f.5: reg 18: [io 0xee00-0xee07]
[ 0.089561] pci 0000:00:1f.5: reg 1c: [io 0xed00-0xed03]
[ 0.089572] pci 0000:00:1f.5: reg 20: [io 0xec00-0xec0f]
[ 0.089583] pci 0000:00:1f.5: reg 24: [io 0xeb00-0xeb0f]
[ 0.089663] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.089668] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
[ 0.089673] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.089680] pci 0000:00:01.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.089718] pci 0000:02:00.0: [5372:6872] type 00 class 0x078000
[ 0.089736] pci 0000:02:00.0: reg 10: [io 0xdf00-0xdf07]
[ 0.089748] pci 0000:02:00.0: reg 14: [io 0xde00-0xde07]
[ 0.089761] pci 0000:02:00.0: reg 18: [io 0xdd00-0xdd07]
[ 0.089774] pci 0000:02:00.0: reg 1c: [io 0xdc00-0xdc07]
[ 0.089786] pci 0000:02:00.0: reg 20: [io 0xdb00-0xdb07]
[ 0.089799] pci 0000:02:00.0: reg 24: [io 0xda00-0xda0f]
[ 0.089834] pci 0000:02:01.0: [9710:9865] type 00 class 0x070103
[ 0.089856] pci 0000:02:01.0: reg 10: [io 0xd900-0xd907]
[ 0.089869] pci 0000:02:01.0: reg 14: [io 0xd800-0xd807]
[ 0.089882] pci 0000:02:01.0: reg 18: [mem 0xfddff000-0xfddfffff]
[ 0.089905] pci 0000:02:01.0: reg 20: [mem 0xfddfe000-0xfddfefff]
[ 0.089949] pci 0000:02:01.0: PME# supported from D0 D3cold
[ 0.089976] pci 0000:02:01.2: [9710:9865] type 00 class 0x070103
[ 0.089998] pci 0000:02:01.2: reg 10: [io 0xd700-0xd707]
[ 0.090011] pci 0000:02:01.2: reg 14: [io 0xd600-0xd607]
[ 0.090024] pci 0000:02:01.2: reg 18: [mem 0xfddfd000-0xfddfdfff]
[ 0.090047] pci 0000:02:01.2: reg 20: [mem 0xfddfc000-0xfddfcfff]
[ 0.090091] pci 0000:02:01.2: PME# supported from D0 D3cold
[ 0.090154] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.090160] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.090166] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.090174] pci 0000:00:1e.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.090178] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.090182] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.090196] pci_bus 0000:00: on NUMA node 0
[ 0.090202] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.090604] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.090835] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.113584] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.113679] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.113773] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 7 9 10 11 12 14 15)
[ 0.113864] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.113955] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.114046] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *9 10 11 12 14 15)
[ 0.114137] ACPI: PCI Interrupt Link [LNK0] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.114228] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.114375] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.114393] vgaarb: loaded
[ 0.114395] vgaarb: bridge control possible 0000:00:02.0
[ 0.114443] PCI: Using ACPI for IRQ routing
[ 0.121788] PCI: pci_cache_line_size set to 64 bytes
[ 0.121888] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[ 0.121892] reserve RAM buffer: 00000000cf590000 - 00000000cfffffff
[ 0.122115] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.122126] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.124032] Switching to clocksource hpet
[ 0.124122] pnp: PnP ACPI init
[ 0.124140] ACPI: bus type pnp registered
[ 0.124284] pnp 00:00: [bus 00-ff]
[ 0.124288] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.124292] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.124296] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.124300] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.124304] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.124307] pnp 00:00: [mem 0xcf600000-0xfebfffff window]
[ 0.124384] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.124516] pnp 00:01: [io 0x0010-0x001f]
[ 0.124520] pnp 00:01: [io 0x0022-0x003f]
[ 0.124523] pnp 00:01: [io 0x0044-0x005f]
[ 0.124527] pnp 00:01: [io 0x0060]
[ 0.124530] pnp 00:01: [io 0x0064]
[ 0.124533] pnp 00:01: [io 0x0062-0x0063]
[ 0.124536] pnp 00:01: [io 0x0065-0x006f]
[ 0.124539] pnp 00:01: [io 0x0074-0x007f]
[ 0.124546] pnp 00:01: [io 0x0091-0x0093]
[ 0.124549] pnp 00:01: [io 0x00a2-0x00bf]
[ 0.124552] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.124556] pnp 00:01: [io 0x04d0-0x04d1]
[ 0.124559] pnp 00:01: [io 0x0800-0x087f]
[ 0.124562] pnp 00:01: [io 0x0290-0x0297]
[ 0.124566] pnp 00:01: [io 0x0880-0x088f]
[ 0.124660] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.124665] system 00:01: [io 0x0800-0x087f] has been reserved
[ 0.124670] system 00:01: [io 0x0290-0x0297] has been reserved
[ 0.124674] system 00:01: [io 0x0880-0x088f] has been reserved
[ 0.124679] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.124703] pnp 00:02: [dma 4]
[ 0.124707] pnp 00:02: [io 0x0000-0x000f]
[ 0.124710] pnp 00:02: [io 0x0080-0x0090]
[ 0.124713] pnp 00:02: [io 0x0094-0x009f]
[ 0.124716] pnp 00:02: [io 0x00c0-0x00df]
[ 0.124758] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.124856] pnp 00:03: [irq 0 disabled]
[ 0.124872] pnp 00:03: [irq 8]
[ 0.124876] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 0.124926] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.124981] pnp 00:04: [io 0x0070-0x0073]
[ 0.125029] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.125046] pnp 00:05: [io 0x0061]
[ 0.125090] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.125108] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.125116] pnp 00:06: [irq 13]
[ 0.125162] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.125407] pnp 00:07: [io 0x03f0-0x03f5]
[ 0.125411] pnp 00:07: [io 0x03f7]
[ 0.125419] pnp 00:07: [irq 6]
[ 0.125422] pnp 00:07: [dma 2]
[ 0.125490] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.125606] pnp 00:08: [io 0x0400-0x04bf]
[ 0.125682] system 00:08: [io 0x0400-0x04bf] has been reserved
[ 0.125688] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.125729] pnp 00:09: [mem 0xffb80000-0xffbfffff]
[ 0.125781] pnp 00:09: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.126177] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.126270] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.126275] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.126424] pnp 00:0b: [mem 0x000f0000-0x000fffff]
[ 0.126429] pnp 00:0b: [mem 0xcf600000-0xcf6fffff]
[ 0.126433] pnp 00:0b: [mem 0xfed00000-0xfed000ff]
[ 0.126436] pnp 00:0b: [mem 0xcf590000-0xcf5fffff]
[ 0.126440] pnp 00:0b: [mem 0x00000000-0x0009ffff]
[ 0.126443] pnp 00:0b: [mem 0x00100000-0xcf58ffff]
[ 0.126446] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[ 0.126450] pnp 00:0b: [mem 0xfed14000-0xfed1dfff]
[ 0.126453] pnp 00:0b: [mem 0xfed20000-0xfed9ffff]
[ 0.126457] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[ 0.126460] pnp 00:0b: [mem 0xffb00000-0xffb7ffff]
[ 0.126463] pnp 00:0b: [mem 0xfff00000-0xffffffff]
[ 0.126467] pnp 00:0b: [mem 0x000e0000-0x000effff]
[ 0.126572] system 00:0b: [mem 0x000f0000-0x000fffff] could not be reserved
[ 0.126577] system 00:0b: [mem 0xcf600000-0xcf6fffff] could not be reserved
[ 0.126582] system 00:0b: [mem 0xfed00000-0xfed000ff] has been reserved
[ 0.126587] system 00:0b: [mem 0xcf590000-0xcf5fffff] could not be reserved
[ 0.126592] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.126596] system 00:0b: [mem 0x00100000-0xcf58ffff] could not be reserved
[ 0.126601] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.126606] system 00:0b: [mem 0xfed14000-0xfed1dfff] has been reserved
[ 0.126610] system 00:0b: [mem 0xfed20000-0xfed9ffff] has been reserved
[ 0.126615] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.126619] system 00:0b: [mem 0xffb00000-0xffb7ffff] has been reserved
[ 0.126624] system 00:0b: [mem 0xfff00000-0xffffffff] has been reserved
[ 0.126634] system 00:0b: [mem 0x000e0000-0x000effff] has been reserved
[ 0.126640] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.126656] pnp: PnP ACPI: found 12 devices
[ 0.126659] ACPI: ACPI bus type pnp unregistered
[ 0.126663] PnPBIOS: Disabled by ACPI PNP
[ 0.163752] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.163759] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
[ 0.163766] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.163771] pci 0000:00:01.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.163780] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.163784] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.163791] pci 0000:00:1e.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.163797] pci 0000:00:1e.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.163834] pci 0000:00:1e.0: setting latency timer to 64
[ 0.163840] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.163844] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.163848] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff]
[ 0.163851] pci_bus 0000:01: resource 1 [mem 0xfde00000-0xfdefffff]
[ 0.163855] pci_bus 0000:01: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.163859] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.163863] pci_bus 0000:02: resource 1 [mem 0xfdd00000-0xfddfffff]
[ 0.163866] pci_bus 0000:02: resource 2 [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.163870] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.163874] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.163975] NET: Registered protocol family 2
[ 0.164091] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.164365] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.165026] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.165404] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.165409] TCP: reno registered
[ 0.165415] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.165430] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.165592] NET: Registered protocol family 1
[ 0.165622] pci 0000:00:02.0: Boot video device
[ 0.165891] PCI: CLS mismatch (64 != 32), using 64 bytes
[ 0.165967] Unpacking initramfs...
[ 0.582421] Freeing initrd memory: 13712k freed
[ 0.590099] audit: initializing netlink socket (disabled)
[ 0.590125] type=2000 audit(1527352911.584:1): initialized
[ 0.607046] highmem bounce pool size: 64 pages
[ 0.607054] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.607255] VFS: Disk quotas dquot_6.5.2
[ 0.607291] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.607402] msgmni has been set to 1696
[ 0.607629] alg: No test for stdrng (krng)
[ 0.607670] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.607675] io scheduler noop registered
[ 0.607678] io scheduler deadline registered
[ 0.607700] io scheduler cfq registered (default)
[ 0.607892] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.607919] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.607922] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.608571] GHES: HEST is not enabled!
[ 0.608590] isapnp: Scanning for PnP cards...
[ 0.961773] isapnp: No Plug & Play device found
[ 0.961846] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.962498] Linux agpgart interface v0.103
[ 0.962638] agpgart-intel 0000:00:00.0: Intel G33 Chipset
[ 0.962730] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 0.962885] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 0.963010] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 0.963202] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.963620] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.963669] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.963798] mousedev: PS/2 mouse device common for all mice
[ 0.963866] rtc_cmos 00:04: RTC can wake from S4
[ 0.964039] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.964069] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 0.964277] TCP: cubic registered
[ 0.964333] NET: Registered protocol family 10
[ 0.964671] Mobile IPv6
[ 0.964676] NET: Registered protocol family 17
[ 0.964684] Registering the dns_resolver key type
[ 0.964772] Using IPI No-Shortcut mode
[ 0.964916] PM: Hibernation image not present or could not be loaded.
[ 0.964933] registered taskstats version 1
[ 0.965420] rtc_cmos 00:04: setting system clock to 2018-05-26 16:41:52 UTC (1527352912)
[ 0.965546] Freeing unused kernel memory: 416k freed
[ 0.965766] Write protecting the kernel text: 3496k
[ 0.965790] Write protecting the kernel read-only data: 984k
[ 0.992236] udevd[45]: starting version 175
[ 1.065249] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 1.065253] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 1.065310] e1000e 0000:00:19.0: setting latency timer to 64
[ 1.065390] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.068592] ACPI: Fan [FAN] (on)
[ 1.078709] usbcore: registered new interface driver usbfs
[ 1.078750] usbcore: registered new interface driver hub
[ 1.082163] usbcore: registered new device driver usb
[ 1.082856] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.140648] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.163827] FDC 0 is a post-1991 82077
[ 1.186218] SCSI subsystem initialized
[ 1.203599] libata version 3.00 loaded.
[ 1.207386] microcode: CPU0 sig=0x10661, pf=0x1, revision=0x32
[ 1.268960] microcode: CPU0 updated to revision 0x43, date = 2010-10-04
[ 1.269422] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.294463] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:1a:a0:8c:24:a8
[ 1.294470] e1000e 0000:00:19.0: eth0: Intel(R) PRO/10/100 Network Connection
[ 1.294492] e1000e 0000:00:19.0: eth0: MAC: 7, PHY: 7, PBA No: FFFFFF-0FF
[ 1.294562] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 1.294567] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 1.294607] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.294641] ehci_hcd 0000:00:1a.7: debug port 1
[ 1.298539] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 1.298568] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfdffe000
[ 1.308021] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.308086] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.308090] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.308094] usb usb1: Product: EHCI Host Controller
[ 1.308098] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.308101] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.309495] hub 1-0:1.0: USB hub found
[ 1.309513] hub 1-0:1.0: 6 ports detected
[ 1.309688] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.309694] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.309708] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 1.309759] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000fd00
[ 1.309815] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.309820] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.309823] usb usb2: Product: UHCI Host Controller
[ 1.309827] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.309830] usb usb2: SerialNumber: 0000:00:1a.0
[ 1.310009] hub 2-0:1.0: USB hub found
[ 1.310017] hub 2-0:1.0: 2 ports detected
[ 1.310300] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 1.310308] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.310320] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 3
[ 1.310368] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000fc00
[ 1.310417] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.310422] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.310426] usb usb3: Product: UHCI Host Controller
[ 1.310429] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.310432] usb usb3: SerialNumber: 0000:00:1a.1
[ 1.310607] hub 3-0:1.0: USB hub found
[ 1.310615] hub 3-0:1.0: 2 ports detected
[ 1.312042] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 1.312049] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 1.312075] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 4
[ 1.312272] uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000fb00
[ 1.312662] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.312673] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.312683] usb usb4: Product: UHCI Host Controller
[ 1.312693] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.312702] usb usb4: SerialNumber: 0000:00:1a.2
[ 1.316229] hub 4-0:1.0: USB hub found
[ 1.316312] hub 4-0:1.0: 2 ports detected
[ 1.320192] ata_piix 0000:00:1f.2: version 2.13
[ 1.320349] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.320882] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.323575] scsi0 : ata_piix
[ 1.325577] scsi1 : ata_piix
[ 1.326722] ata1: SATA max UDMA/133 cmd 0xf700 ctl 0xf600 bmdma 0xf300 irq 19
[ 1.326731] ata2: SATA max UDMA/133 cmd 0xf500 ctl 0xf400 bmdma 0xf308 irq 19
[ 1.327058] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.327065] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.327084] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 1.327117] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.331015] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.331052] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfdffd000
[ 1.340017] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.340055] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.340059] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.340064] usb usb5: Product: EHCI Host Controller
[ 1.340067] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.340070] usb usb5: SerialNumber: 0000:00:1d.7
[ 1.341476] hub 5-0:1.0: USB hub found
[ 1.341490] hub 5-0:1.0: 6 ports detected
[ 1.341659] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.341665] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.341680] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 1.341712] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fa00
[ 1.341763] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.341768] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.341772] usb usb6: Product: UHCI Host Controller
[ 1.341775] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.341778] usb usb6: SerialNumber: 0000:00:1d.0
[ 1.341957] hub 6-0:1.0: USB hub found
[ 1.341964] hub 6-0:1.0: 2 ports detected
[ 1.342987] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.342994] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.343011] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 1.343050] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000f900
[ 1.343103] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.343107] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.343111] usb usb7: Product: UHCI Host Controller
[ 1.343114] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.343117] usb usb7: SerialNumber: 0000:00:1d.1
[ 1.343693] hub 7-0:1.0: USB hub found
[ 1.343702] hub 7-0:1.0: 2 ports detected
[ 1.345173] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.345180] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.345199] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 1.345234] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000f800
[ 1.345290] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.345294] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.345298] usb usb8: Product: UHCI Host Controller
[ 1.345301] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.345305] usb usb8: SerialNumber: 0000:00:1d.2
[ 1.345494] hub 8-0:1.0: USB hub found
[ 1.345502] hub 8-0:1.0: 2 ports detected
[ 1.346974] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.347037] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.352209] scsi2 : ata_piix
[ 1.356464] scsi3 : ata_piix
[ 1.356990] ata3: SATA max UDMA/133 cmd 0xf000 ctl 0xef00 bmdma 0xec00 irq 19
[ 1.356997] ata4: SATA max UDMA/133 cmd 0xee00 ctl 0xed00 bmdma 0xec08 irq 19
[ 1.600016] Refined TSC clocksource calibration: 1595.999 MHz.
[ 1.600024] Switching to clocksource tsc
[ 1.686988] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.697822] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.980016] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 2.120067] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.120080] ata1.01: SATA link down (SStatus 0 SControl 300)
[ 2.124062] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.124076] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 2.124089] ata2.01: link offline, clearing class 3 to NONE
[ 2.148125] ata2.00: ATAPI: PHILIPS DVD-ROM DROM6316, ODFN01, max UDMA/100
[ 2.148417] usb 3-1: New USB device found, idVendor=0461, idProduct=4d15
[ 2.148421] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.148425] usb 3-1: Product: USB Optical Mouse
[ 2.168586] ata1.00: ATA-7: ST3808110AS, 3.ADJ, max UDMA/133
[ 2.168592] ata1.00: 156250000 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.180139] ata2.00: configured for UDMA/100
[ 2.235205] ata1.00: configured for UDMA/133
[ 2.235361] scsi 0:0:0:0: Direct-Access ATA ST3808110AS 3.AD PQ: 0 ANSI: 5
[ 2.235944] scsi 1:0:0:0: CD-ROM PHILIPS DVD-ROM DROM6316 ODFN PQ: 0 ANSI: 5
[ 2.260692] sr0: scsi3-mmc drive: 0x/48x cd/rw xa/form2 cdda tray
[ 2.260698] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.260812] sd 0:0:0:0: [sda] 156250000 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 2.260899] sd 0:0:0:0: [sda] Write Protect is off
[ 2.260903] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.260942] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.262361] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.1/usb3/3-1/3-1:1.0/input/input0
[ 2.262671] generic-usb 0003:0461:4D15.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.1-1/input0
[ 2.262773] usbcore: registered new interface driver usbhid
[ 2.262777] usbhid: USB HID core driver
[ 2.263720] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.306669] sda: sda1 sda2 < sda5 >
[ 2.307145] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.322684] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.322846] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.388026] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 2.568423] usb 3-2: New USB device found, idVendor=04f2, idProduct=0841
[ 2.568429] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.568433] usb 3-2: Product: HP USB Multimedia Keyboard
[ 2.568437] usb 3-2: Manufacturer: CHICONY
[ 2.587100] input: CHICONY HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.1/usb3/3-2/3-2:1.0/input/input1
[ 2.587191] generic-usb 0003:04F2:0841.0002: input,hidraw1: USB HID v1.11 Keyboard [CHICONY HP USB Multimedia Keyboard] on usb-0000:00:1a.1-2/input0
[ 2.612519] input: CHICONY HP USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.1/usb3/3-2/3-2:1.1/input/input2
[ 2.612668] generic-usb 0003:04F2:0841.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [CHICONY HP USB Multimedia Keyboard] on usb-0000:00:1a.1-2/input1
[ 2.852029] usb 4-2: new full-speed USB device number 2 using uhci_hcd
[ 3.005459] usb 4-2: New USB device found, idVendor=10ce, idProduct=eb70
[ 3.005464] usb 4-2: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 3.005468] usb 4-2: Manufacturer: KTURT.LTD
[ 3.013682] generic-usb 0003:10CE:EB70.0004: hiddev0,hidraw3: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:1a.2-2/input0
[ 7.673906] PM: Starting manual resume from disk
[ 7.673914] PM: Hibernation image partition 8:5 present
[ 7.673917] PM: Looking for hibernation image.
[ 7.674179] PM: Image not found (code -22)
[ 7.674183] PM: Hibernation image not present or could not be loaded.
[ 7.717490] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.605966] udevd[345]: starting version 175
[ 10.089166] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 10.089175] ACPI: Power Button [PWRB]
[ 10.089283] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 10.089289] ACPI: Power Button [PWRF]
[ 10.168054] [drm] Initialized drm 1.1.0 20060810
[ 10.229839] iTCO_vendor_support: vendor-support=0
[ 10.425055] i915 0000:00:02.0: setting latency timer to 64
[ 10.444242] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 10.444248] [drm] Driver supports precise vblank timestamp query.
[ 10.444305] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 10.460956] [drm] initialized overlay support
[ 10.506378] fbcon: inteldrmfb (fb0) is primary device
[ 10.513953] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 10.514072] iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0460)
[ 10.515600] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.553759] Console: switching to colour frame buffer device 200x56
[ 10.561988] fb0: inteldrmfb frame buffer device
[ 10.561992] drm: registered panic notifier
[ 10.562010] No ACPI video bus found
[ 10.562540] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.674230] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 10.682477] coretemp coretemp.0: Using relative temperature scale!
[ 10.947391] PCI parallel port detected: 14f2:0121, I/O at 0xd900(0x0), IRQ 16
[ 10.947415] parport0: PC-style at 0xd900, irq 16 [PCSPP,TRISTATE,EPP]
[ 11.036091] PCI parallel port detected: 14f2:0121, I/O at 0xd700(0x0), IRQ 18
[ 11.036117] parport1: PC-style at 0xd700, irq 18 [PCSPP,TRISTATE,EPP]
[ 11.208360] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 11.215809] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 11.216110] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 11.216354] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 11.216592] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 11.216829] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 11.217068] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 11.217299] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 11.217532] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 13.063695] Adding 3211260k swap on /dev/sda5. Priority:-1 extents:1 across:3211260k
[ 13.087884] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.364075] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.523687] loop: module loaded
[ 15.431784] RPC: Registered named UNIX socket transport module.
[ 15.431790] RPC: Registered udp transport module.
[ 15.431792] RPC: Registered tcp transport module.
[ 15.431795] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.466077] FS-Cache: Loaded
[ 15.510341] NFS: Registering the id_resolver key type
[ 15.510371] FS-Cache: Netfs 'nfs' registered for caching
[ 15.517577] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 17.720116] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 19.484926] Bluetooth: Core ver 2.16
[ 19.485335] NET: Registered protocol family 31
[ 19.485341] Bluetooth: HCI device and connection manager initialized
[ 19.485345] Bluetooth: HCI socket layer initialized
[ 19.485348] Bluetooth: L2CAP socket layer initialized
[ 19.485357] Bluetooth: SCO socket layer initialized
[ 19.511209] Bluetooth: RFCOMM TTY layer initialized
[ 19.511217] Bluetooth: RFCOMM socket layer initialized
[ 19.511221] Bluetooth: RFCOMM ver 1.11
[ 19.564648] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.564653] Bluetooth: BNEP filters: protocol multicast
[ 19.777263] lp0: using parport0 (interrupt-driven).
[ 19.778389] lp1: using parport1 (interrupt-driven).
[ 19.882009] ppdev: user-space parallel port driver
[ 23.058169] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.153890] e1000e 0000:00:19.0: eth0: MAC Wakeup cause - Link Status Change
[ 27.752786] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 27.752794] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 27.752981] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 38.784012] eth0: no IPv6 routers present
[ 4126.912396] I-pipe: head domain RTAI registered.
[ 4126.912406] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4126.912415] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4126.912420] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1595865000, CPU_FREQ 1595865000
[ 4126.912424] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4126.912429] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12408500
[ 4126.959100] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4126.959162] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4126.959169] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 4126.959174] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1595865000 hz.
[ 4126.959177] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4126.984756] RTAI[math]: loaded.
[ 4127.205608] config string '0xd900 out 0xd700 out'
[ 4128.488868] RTAI[math]: unloaded.
[ 4128.492259] SCHED releases registered named ALIEN PEDV$D
[ 4128.500630] RTAI[malloc]: unloaded.
[ 4128.600017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4128.602799] I-pipe: head domain RTAI unregistered.
[ 4128.602813] RTAI[hal]: unmounted.
[ 4143.545068] I-pipe: head domain RTAI registered.
[ 4143.545078] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4143.545087] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4143.545093] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1595865000, CPU_FREQ 1595865000
[ 4143.545097] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4143.545101] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12396000
[ 4143.572588] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4143.572649] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4143.572656] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 4143.572661] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1595865000 hz.
[ 4143.572664] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4143.591396] RTAI[math]: loaded.
[ 4143.792021] config string '0xd900 out 0xd700 out'
[ 4144.663175] RTAI[math]: unloaded.
[ 4144.666641] SCHED releases registered named ALIEN PEDV$D
[ 4144.675469] RTAI[malloc]: unloaded.
[ 4144.772014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4144.774830] I-pipe: head domain RTAI unregistered.
[ 4144.774844] RTAI[hal]: unmounted.
[ 4915.272018] usb 5-2: new high-speed USB device number 2 using ehci_hcd
[ 4915.406306] usb 5-2: New USB device found, idVendor=0930, idProduct=6545
[ 4915.406312] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4915.406316] usb 5-2: Product: TransMemory
[ 4915.406320] usb 5-2: Manufacturer: TOSHIBA
[ 4915.406323] usb 5-2: SerialNumber: 001D92AF7F805B8A0A06010C
[ 4915.518490] Initializing USB Mass Storage driver...
[ 4915.522625] scsi4 : usb-storage 5-2:1.0
[ 4915.523324] usbcore: registered new interface driver usb-storage
[ 4915.523330] USB Mass Storage support registered.
[ 4916.520850] scsi 4:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[ 4916.532384] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 4917.670200] sd 4:0:0:0: [sdb] 3966976 512-byte logical blocks: (2.03 GB/1.89 GiB)
[ 4917.670688] sd 4:0:0:0: [sdb] Write Protect is off
[ 4917.670694] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 4917.671189] sd 4:0:0:0: [sdb] No Caching mode page present
[ 4917.671194] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 4917.674941] sd 4:0:0:0: [sdb] No Caching mode page present
[ 4917.674948] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 4917.721416] sdb:
[ 4917.725333] sd 4:0:0:0: [sdb] No Caching mode page present
[ 4917.725341] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 4917.725347] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 5306.845840] I-pipe: head domain RTAI registered.
[ 5306.845850] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 5306.845859] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5306.845864] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1595865000, CPU_FREQ 1595865000
[ 5306.845869] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5306.845873] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12216250
[ 5306.859416] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5306.859478] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5306.859484] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 5306.859489] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1595865000 hz.
[ 5306.859492] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 5306.874024] RTAI[math]: loaded.
[ 5307.052026] config string '0xd900 out 0xd700 out'
[ 5308.102583] RTAI[math]: unloaded.
[ 5308.106079] SCHED releases registered named ALIEN PEDV$D
[ 5308.114998] RTAI[malloc]: unloaded.
[ 5308.212020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5308.214829] I-pipe: head domain RTAI unregistered.
[ 5308.214843] RTAI[hal]: unmounted.
[ 5539.569415] I-pipe: head domain RTAI registered.
[ 5539.569426] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 5539.569435] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5539.569440] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 1595865000, CPU_FREQ 1595865000
[ 5539.569444] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5539.569449] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12380250
[ 5539.583029] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5539.583089] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5539.583096] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 5539.583101] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1595865000 hz.
[ 5539.583104] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 5539.597030] RTAI[math]: loaded.
[ 5539.776028] config string '0xd900 out 0xd700 out'
[ 5540.811815] RTAI[math]: unloaded.
[ 5540.815200] SCHED releases registered named ALIEN PEDV$D
[ 5540.824050] RTAI[malloc]: unloaded.
[ 5540.924019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5540.927229] I-pipe: head domain RTAI unregistered.
[ 5540.927243] RTAI[hal]: unmounted.
Last edit: 29 May 2018 16:07 by andypugh.
26 May 2018 19:05 #111162
by dgarrett
Replied by dgarrett on topic Re-install LCNC
Per your log:
The use of system-wide halfiles was made available with commit:
8b44ccfa6 which was incorporated after 2.6.13:
So the version of LinuxCNC you report (2.6.13) is not
compatible with an ini file that requests a "LIB:" file
Use of this functionality requires a LinuxCNC version of 2.7 or
greater.
Ref: github.com/LinuxCNC/linuxcnc/commit/8b44ccfa6
LINUXCNC - 2.6.13
$ git tag --contains 8b44ccfa6
v2.7.0
greater.
- allenwg2005
- Topic Author
26 May 2018 20:29 #111166
by allenwg2005
dgarrett, good snag!!!
2.6.13??????
That's what I get for using Synaptic and a repository some what dated (I guess).
I didn't catch the 6 (I just thought it was 2.7.13).
Off I go to update to the latest.
Thanks so much.
2.6.13??????
Thanks so much.
- allenwg2005
- Topic Author
26 May 2018 20:55 #111169
by allenwg2005
Yup!
Got the correct repository and loaded 2.7.13 and it works just fine.
Thanks for the help folks.
Time to create page: 0.486 seconds
