Building kernel 4.16.8 on Debian Stretch
- EricKeller
- Thank you received: 3
26 May 2018 14:46 #111147
by EricKeller
Building kernel 4.16.8 on Debian Stretch was created by EricKeller
This script is reported to work:
If you cut and paste, the line endings might not be right
cd ~
sudo apt-get update
sudo apt-get install build-essential bin86 libqt4-dev libncurses5-dev pkg-config
sudo apt-get install bison flex libelf-dev bc libssl-dev
mkdir rtlinux
cd rtlinux
wget https://www.kernel.org/pub/linux/kernel/v4.x/linux-4.16.8.tar.xz
wget https://www.kernel.org/pub/linux/kernel/projects/rt/4.16/patch-4.16.8-rt3.patch.gz
tar -xpf linux-4.16.8.tar.xz
gunzip patch-4.16.8-rt3.patch.gz
cp patch-4.16.8-rt3.patch linux-4.16.8
cd linux-4.16.8
cat patch-4.16.8-rt3.patch | patch -p1
make xconfig
# there are 3 main things you need to set in xconfig
# enable hpet
# set 64 bit if your OS is 64 bit and
# set for fully preemptable kernel
make -j4
sudo make modules_install
sudo make install
The following user(s) said Thank You: KCJ
- EricKeller
26 May 2018 15:06 #111148
by EricKeller
Replied by EricKeller on topic Building kernel 4.16.8 on Debian Stretch
making your new kernel default for boot:
unix.stackexchange.com/questions/198003/...paign=google_rich_qa
That is a bit confusing though
- EricKeller
26 May 2018 15:09 #111149
by EricKeller
this is for Prempt kernel, don't see how to edit anything
- EricKeller
26 May 2018 15:26 #111150
by EricKeller
Replied by EricKeller on topic Building kernel 4.16.8 on any distribution that uses apt
This should work on any system that uses apt, some packages may not be required depending on your distribution, but it doesn't hurt anything to try to install them.
30 May 2018 04:08 - 30 May 2018 04:24 #111301
by KCJ
Replied by KCJ on topic Building kernel 4.16.8 on any distribution that uses apt
The URL for the 4.16.8-rt3 patch is no longer valid. This causes the above script to silently fail to apply the patch and you will not have the proper options available on the kernel config screen.
Here is the updated script. Note, this installs 4.16.12 instead of 4.16.8.
cd ~
sudo apt-get update
sudo apt-get install build-essential bin86 libqt4-dev libncurses5-dev pkg-config bison flex libssl-dev libelf-dev
mkdir rtlinux
cd rtlinux
wget https://www.kernel.org/pub/linux/kernel/v4.x/linux-4.16.12.tar.xz
wget https://www.kernel.org/pub/linux/kernel/projects/rt/4.16/patch-4.16.12-rt5.patch.gz
tar -xpf linux-4.16.12.tar.xz
gunzip patch-4.16.12-rt5.patch.gz
cp patch-4.16.12-rt5.patch linux-4.16.12
cd linux-4.16.12
cat patch-4.16.12-rt5.patch | patch -p1
make xconfig
make -j4
sudo make install
Last edit: 30 May 2018 04:24 by KCJ. Reason: Update script
Time to create page: 0.250 seconds
