Error on installation
05 Jun 2018 00:47 #111637
by truetrini
Error on installation was created by truetrini
Hi
Let me start by saying that I am a complete beginner to Linux and LinuxCNC but I have researched my error and could not find a reference or solution.
I am installing on a Dell PowerEdge T20 with Xeon E3-1225 processor and Crucial CT480M SSD. I get to boot off the USB drive but when I select Graphical Install, I immediately get the following error:
ERST: Failed to get Error Log Address Range
Nothing else on the screen. Is this a compatibility error? Can anyone help?
- InMyDarkestHour
- User is blocked
- Thank you received: 111
05 Jun 2018 02:17 #111640
by InMyDarkestHour
Replied by InMyDarkestHour on topic Error on installation
When you get the the screen to select your options for Linuxcnc press TAB then type
acpi=off (this may or may not work)
Read this page as well.
www.supermicro.com/support/faqs/faq.cfm?faq=15594
A google search of the term "ERST: Failed to get Error Log Address Range" will bring up quite a pages.
05 Jun 2018 03:02 #111642
by truetrini
Replied by truetrini on topic Error on installation
Thanks. I tried that (acpi=off) and it gave me a blank screen.
I also googled the error before I posted and tried all the solutions that were suggested. Maybe I missed something.
Any other ideas?
Any other ideas?
- InMyDarkestHour
- User is blocked
05 Jun 2018 03:33 #111643
by InMyDarkestHour
Ok no probs......you've had a good look.
It maybe just be the particular computer you are trying to use.
The most used system would appear to be a desktop type platform for Linuxcnc.......servers can be a bit finicky sometimes
Seems to happen a lot, and there seems to be multiple reasons why....Could be an issue with the kernel.
Have you tried booting any other Linux distros on this machine ? Just for a base line
06 Jun 2018 09:33 - 06 Jun 2018 09:34 #111731
Replied by andypugh on topic Error on installation
Assuming you are using the "normal" RTAI liveCD image one very easy variation to try is the experimental Stretch / preempt-rt image. That is a different kernel, different Linux version and different realtime system....
www.linuxcnc.org/testing-stretch-rtpreempt/
Last edit: 06 Jun 2018 09:34 by andypugh.
Time to create page: 0.108 seconds
