Keyserver failure
03 Aug 2018 12:12 - 03 Aug 2018 13:09 #115503
by vibram
Keyserver failure was created by vibram
Good afternoon,
I try to install LinuxCNC on my Asus VC66 (64 bit)
I installed Debian 9 64-bit; Gnome 3.22.2 and I'm struggling with linuxCNC
I followed all these steps:
linuxcnc.org/docs/2.7/html/getting-start...th_preempt_rt_kernel
But when I enter this command:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
I always receive the same message: pgp: keyserver receive failed: Server indicated a failure.
I don't manage to bypass this with sudo apt-get --allow-unauthenticated update
I also try to add [trusted=yes] such as:
deb [trusted=yes] linuxcnc.org/ wheezy 2.7-uspace base
but still the same error
Do you have any idea?
This is too soon to have an error on the long way to get the mill working
Thank you
Thank you
Last edit: 03 Aug 2018 13:09 by vibram.
03 Aug 2018 13:09 #115512
by vibram
Replied by vibram on topic Keyserver failure
i resolved the issue with addind ":80" after the key url
let struggle with linuxcnc-uspace erreors now
04 Aug 2018 22:30 #115621
Replied by andypugh on topic Keyserver failure
I think I have generally not bothered with the key, and things seem to work regardless.
Time to create page: 0.148 seconds
