2.3 problems
26 May 2009 18:10 #352 by lelef
2.3 problems was created by lelef
2.3.1 it looks really better , improved interface and functions but it dosn't work :( (on my pc)
same problems founded here: www.linuxcnc.org/component/option,com_ku...imitstart,6/lang,en/
and also is impossible to use a joypad , the sistem see it but it can't use it joypad.hal or joypad_v3.hal or the x11 way dosn't run, when I try to lod it with halcmd the result is "err n3 import buttton 0 failed"
at the end I've installed 2.2 ad updated with synaptic to 2.3.1 ,It's a workaround but now all works fine
Lele
