Motenc-Lite DAC pinouts
07 Sep 2018 14:57 #117186
by dextaca
Motenc-Lite DAC pinouts was created by dextaca
Gents
Trying to do a retro with Motenc Lite.. and cannot get the pinouts right.. there is avery little info on the site..
Seems they have a common ground. but when applied to the servopakc , the common makes the servos crazy.. ( having major voltage leak. )
any idea..
Thank you kindly..
Peter
any idea..
Thank you kindly..
Peter
- Thank you received: 5942
07 Sep 2018 21:54 #117207
Replied by tommylight on topic Motenc-Lite DAC pinouts
We would need much more information to be able to help.
Making drives go crazy means you are missing a ground somewhere or miss wiring and all that assuming you are not touching the drive wires with your fingers Something is inducing the 50 or 60 Hz frequency to the drives so they try to rotate at alternate sides 50 or 60 times a second.
11 Sep 2018 14:16 #117331
Replied by andypugh on topic Motenc-Lite DAC pinouts
They seem fairly clear that they expect you to use www.vitalsystem.com/portal/breakout_board/um7525.pdf
And that you shouldn't need to know which wire it which.
I assume you are not using one of those?
(bottom of this page)
www.vitalsystem.com/portal/breakout_board/breakout.php
It doesn't seem to have any active components on the board, though.
11 Sep 2018 22:33 #117365
by dextaca
Replied by dextaca on topic Motenc-Lite DAC pinouts
got it all covered. the lite card has a diff pinouts than the -100 card.. got it straighten it up.. works like a charm..
thank you all..
thank you all..
Time to create page: 0.087 seconds
