Install not working. Live is OK
04 Mar 2019 13:40 #127692
by cuagn
Install not working. Live is OK was created by cuagn
Five years ago I bought a Chinese CNC (3040Z-DQ) and play a lot using LinuxCNC on a Dell Optiplex SX270. Works fine.
Then I stopped using it.
I want now to do some work with my CNC.
I've downloaded the last version (2.7 Wheezy).
First issue, the size greater than a CD, my PC not supporting a DVD...
Using an USB memory I was able to boot with the LIVE. Well, no problem, all is OK.
I wanted to install it on the HDD.
The procedure is failing, for some unclear reason in regards to the VESA definition...
A message, which is not well displayed (very tiny size) is requiring either to abort or to give some number.
It's illisible and unclear but related to the display.
Question :
1 - seems curious that the HW is OK for a live usage but not for an install. Any idea?
2 - could I have an idea of what magic number must be given in order to continue the install?
Thank you,
Question :
Thank you,
04 Mar 2019 14:31 #127700
by pl7i92
Replied by pl7i92 on topic Install not working. Live is OK
s it still the Dell Optiplex SX270
then you may go direct to the USPACE DVD setup
www.linuxcnc.org/testing-stretch-rtpreempt/
The following user(s) said Thank You: cuagn
04 Mar 2019 16:23 - 04 Mar 2019 16:27 #127709
by cuagn
Replied by cuagn on topic Install not working. Live is OK
All is OK now.
Thank You
Yes - It is always this old computer - constraint of the parallel port of my driver
Thank You
Last edit: 04 Mar 2019 16:27 by cuagn.
05 Mar 2019 07:45 #127761
by pl7i92
A parport PCI Card is at 10USD
so it is no need to keep the old stuff
05 Mar 2019 09:31 #127770
by cuagn
Agreed.
It's also a question of the size and location of the devices.
The CNC is installed in a dedicated environment (my personal workshop) and the PC is close to this machinery far away from my office.
I have a choice between three computers having a parallel port. All are of the same generation (~2004)
- an old desktop (big tower...) still able of running an XP
- the Optiplex, which is OK now
- a laptop, Aspire 1350 which is probably the better solution: tiny and powerful enough.
I've tried to install the same ISO than for the Optiplex (i86).
Failed.
I will retry now and if you have an idea, I'll be happy.
Best regards
Marc
Failed.
Best regards
Marc
05 Mar 2019 09:37 #127771
by pl7i92
there are cheep Military PC for Frontline Use
as of the Desert storm opperation availabel
this will hold the dust and ofcause can take alot of hits
you may try to get one of thiem
05 Mar 2019 09:41 #127772
by cuagn
05 Mar 2019 13:54 #127783
Replied by andypugh on topic Install not working. Live is OK
I think that some people have reported that the installer can fail if there is no internet connection.
05 Mar 2019 14:11 #127788
by cuagn
I was with an internet connexion.
- Thank you received: 5972
05 Mar 2019 20:52 #127820
Replied by tommylight on topic Install not working. Live is OK
After it fails in the non graphical installer, chose a different server, it will work.
I choose the German EDU ones, they always work.
Time to create page: 0.095 seconds
