Linuxcnc live usb does not work, cd works
05 Mar 2019 09:16 #127769
by Dencnc
Linuxcnc live usb does not work, cd works was created by Dencnc
Hi I am new to the world of linux:cheer: . I installed ubuntu on an old mac and it works well. Now I want to run linuxcnc on it. I burned the live cd and it works, I install it and the computer starts up again and there is a question mark on the screen. I have installed ubuntu back on it. and try to make a live usb and not work at all. Who can help with a simple explanation so that I can run linuxcnc on my old mac?
06 Mar 2019 07:38 #127865
by pl7i92
Replied by pl7i92 on topic Linuxcnc live usb does not work, cd works
The Mac will not run a live USB Stick as it blocks the Kernal to interfear the Hardware
While the DVD shidt do the Job
06 Mar 2019 09:40 #127872
by Dencnc
Replied by Dencnc on topic Linuxcnc live usb does not work, cd works
When I install the DVD I can finish everything through the entire menu. then I restart the computer. and then I get a question mark on the screen. And can then do nothing more. Do you have a solution?
06 Mar 2019 10:26 #127875
by pl7i92
at startup press E
the manuell start menue shows
then go to line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash lapic"
if there is no lapic enter it and restart with X
then go to line
06 Mar 2019 10:37 #127877
by Dencnc
When I press E, the computer just continues and opens ubuntu
06 Mar 2019 11:12 #127878
by Dencnc
If I press X, the computer also just starts and opens ubuntu
- Thank you received: 5972
06 Mar 2019 23:25 #127925
Replied by tommylight on topic Linuxcnc live usb does not work, cd works
Start the computer then immediately press and hold the SHIFT button to get to the GRUB screen, then follow his advice.
07 Mar 2019 05:43 #127950
by Dencnc
I hold shift and the computer starts and opens Ubuntu
07 Mar 2019 05:45 #127951
by Dencnc
Should perhaps tell that it is an imac
07 Mar 2019 07:34 #127954
by pl7i92
why dont you just use a Very Cheep 25USD old 2Core PC to get it in a workshop a mac is not the best to get
Time to create page: 0.232 seconds
