New Linuxcnc install, terminated with error
- B.Reilly01
- Thank you received: 13
13 Mar 2019 01:57 - 14 Mar 2019 13:52 #128478
by B.Reilly01
New Linuxcnc install, terminated with error was created by B.Reilly01
So I had been successfully running LinuxCNC on my mill, but needed to upgrade the PC. I installed LinuxCNC on one partition, and PathPilot on the other, because I'd lke to be able to run PP. I built the config again in Pncconf, but when I go to launch I get the following error. I reflashed the 5i25, to no effect.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/cncmill/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/cncmill/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=3849
ERROR: Can't remove RTAI modules, kill the following process(es) first
3877Removing NML shared memory segments
Debug file information:
./my_LinuxCNC_machine.hal:366: Pin 'hm2_5i25.0.7i77.0.0.enc0.count' does not exist
3849
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
USER PID ACCESS COMMAND
/dev/rtai_shm: cncmill ....m halui
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cef57000 (usable)
[ 0.000000] BIOS-e820: 00000000cef57000 - 00000000cef98000 (reserved)
[ 0.000000] BIOS-e820: 00000000cef98000 - 00000000cefa4000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cefa4000 - 00000000cf059000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cf059000 - 00000000cf2f0000 (reserved)
[ 0.000000] BIOS-e820: 00000000cf2f0000 - 00000000cf520000 (usable)
[ 0.000000] BIOS-e820: 00000000cf520000 - 00000000cf6e4000 (reserved)
[ 0.000000] BIOS-e820: 00000000cf6e4000 - 00000000cf6f0000 (usable)
[ 0.000000] BIOS-e820: 00000000cf6f0000 - 00000000d0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffc00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000130000000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Source Code CDC-I/CDC-I, BIOS 4.6.5 08/23/2013
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcf6f0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E7FFF write-through
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F00000000 write-back
[ 0.000000] 1 base 100000000 mask FE0000000 write-back
[ 0.000000] 2 base 120000000 mask FF0000000 write-back
[ 0.000000] 3 base 0CF700000 mask FFFF00000 write-through
[ 0.000000] 4 base 0CF800000 mask FFF800000 uncachable
[ 0.000000] 5 base 0D0000000 mask FF0000000 uncachable
[ 0.000000] 6 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fd6d0] fd6d0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652e000 - 3728f000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 SCC)
[ 0.000000] ACPI: XSDT cef9a078 00074 (v01 SCC Certera 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP cefa2268 000F4 (v04 SCC Certera 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT cef9a180 080E6 (v02 SCC Certera 00000016 INTL 20051117)
[ 0.000000] ACPI: FACS cf052f80 00040
[ 0.000000] ACPI: APIC cefa2360 00072 (v03 SCC Certera 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT cefa23d8 00044 (v01 SCC Certera 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG cefa2420 0003C (v01 SCC Certera 01072009 MSFT 00000097)
[ 0.000000] ACPI: SLIC cefa2460 00176 (v01 SCC Certera 01072009 AMI 00010013)
[ 0.000000] ACPI: HPET cefa25d8 00038 (v01 SCC Certera 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT cefa2610 00655 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT cefa2c68 00259 (v01 PmRef Cpu0Tst 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT cefa2ec8 0020F (v01 PmRef ApTst 00003000 INTL 20051117)
[ 0.000000] ACPI: IFEU cefa30d8 00042 (v01 SCC Certera 01072009 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2430MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cf6f0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x000cef57
[ 0.000000] 0: 0x000cf2f0 -> 0x000cf520
[ 0.000000] 0: 0x000cf6e4 -> 0x000cf6f0
[ 0.000000] On node 0 totalpages: 848162
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b3e200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4862 pages used for memmap
[ 0.000000] HighMem zone: 616087 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at d0000000 (gap: d0000000:10000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 841524
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=9b6222c9-2dde-4717-9337-f6a66578fe58 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 6797056 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cf6f0)
[ 0.000000] Memory: 3338740k/3398592k available (3495k kernel code, 53908k reserved, 1237k data, 416k init, 2483796k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 1862.004 MHz processor.
[ 0.000004] Calibrating delay loop (skipped), value calculated using timer frequency.. 3724.00 BogoMIPS (lpj=7448016)
[ 0.000013] pid_max: default: 32768 minimum: 301
[ 0.000123] Security Framework initialized
[ 0.000132] AppArmor: AppArmor disabled by boot time parameter
[ 0.000176] Mount-cache hash table entries: 512
[ 0.000552] Initializing cgroup subsys cpuacct
[ 0.000558] Initializing cgroup subsys memory
[ 0.000577] Initializing cgroup subsys devices
[ 0.000582] Initializing cgroup subsys freezer
[ 0.000587] Initializing cgroup subsys net_cls
[ 0.000591] Initializing cgroup subsys blkio
[ 0.000605] Initializing cgroup subsys perf_event
[ 0.000658] Disabled fast string operations
[ 0.000665] CPU: Physical Processor ID: 0
[ 0.000669] CPU: Processor Core ID: 0
[ 0.000674] mce: CPU supports 5 MCE banks
[ 0.000685] CPU0: Thermal monitoring enabled (TM1)
[ 0.000761] ACPI: Core revision 20120320
[ 0.015819] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016250] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.055875] CPU0: Intel(R) Atom(TM) CPU D2550 @ 1.86GHz stepping 01
[ 0.162067] Performance Events: PEBS fmt0+, generic architected perfmon, Intel PMU driver.
[ 0.162083] ... version: 3
[ 0.162088] ... bit width: 40
[ 0.162092] ... generic registers: 2
[ 0.162097] ... value mask: 000000ffffffffff
[ 0.162102] ... max period: 000000007fffffff
[ 0.162106] ... fixed-purpose events: 3
[ 0.162110] ... event mask: 0000000700000003
[ 0.174375] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.186076] CPU 1 irqstacks, hard=f40d4000 soft=f40d6000
[ 0.186082] Booting Node 0, Processors #1
[ 0.199383] Initializing CPU#1
[ 0.199416] Disabled fast string operations
[ 0.201545] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.206046] CPU 2 irqstacks, hard=f4104000 soft=f4106000
[ 0.206052] #2
[ 0.215992] Initializing CPU#2
[ 0.216977] Disabled fast string operations
[ 0.219107] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.226005] CPU 3 irqstacks, hard=f4116000 soft=f4118000
[ 0.226010] #3 Ok.
[ 0.235952] Initializing CPU#3
[ 0.236935] Disabled fast string operations
[ 0.239071] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.239140] Brought up 4 CPUs
[ 0.239147] Total of 4 processors activated (14896.03 BogoMIPS).
[ 0.240272] devtmpfs: initialized
[ 0.240826] PM: Registering ACPI NVS region [mem 0xcefa4000-0xcf058fff] (741376 bytes)
[ 0.241121] dummy:
[ 0.241276] NET: Registered protocol family 16
[ 0.241572] ACPI: bus type pci registered
[ 0.241712] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.241721] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.241726] PCI: Using MMCONFIG for extended config space
[ 0.241731] PCI: Using configuration type 1 for base access
[ 0.243657] bio: create slab <bio-0> at 0
[ 0.243950] ACPI: Added _OSI(Module Device)
[ 0.243957] ACPI: Added _OSI(Processor Device)
[ 0.243966] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.243973] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.248842] ACPI: EC: Look up EC in DSDT
[ 0.254795] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.261289] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.262722] ACPI: SSDT cef64710 006D5 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.263955] ACPI: Dynamic OEM Table Load:
[ 0.263964] ACPI: SSDT (null) 006D5 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.264869] ACPI: SSDT cef66f10 0008D (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.266120] ACPI: Dynamic OEM Table Load:
[ 0.266130] ACPI: SSDT (null) 0008D (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.268568] ACPI: Interpreter enabled
[ 0.268583] ACPI: (supports S0 S3 S4 S5)
[ 0.268649] ACPI: Using IOAPIC for interrupt routing
[ 0.286696] ACPI: Power Resource [FN00] (off)
[ 0.288699] ACPI: No dock devices found.
[ 0.288713] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.289437] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.290141] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.290149] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.290156] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.290163] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.290169] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000effff]
[ 0.290176] pci_root PNP0A08:00: host bridge window [mem 0x000f0000-0x000fffff]
[ 0.290182] pci_root PNP0A08:00: host bridge window [mem 0xcf800000-0xcfffffff]
[ 0.290189] pci_root PNP0A08:00: host bridge window [mem 0xd0000000-0xfebfffff]
[ 0.290289] PCI host bridge to bus 0000:00
[ 0.290297] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.290303] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.290310] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.290316] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[ 0.290323] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff]
[ 0.290329] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
[ 0.290336] pci_bus 0000:00: root bus resource [mem 0xcf800000-0xcfffffff]
[ 0.290342] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfebfffff]
[ 0.290366] pci 0000:00:00.0: [8086:0bf3] type 00 class 0x060000
[ 0.290437] pci 0000:00:02.0: [8086:0be2] type 00 class 0x030000
[ 0.290459] pci 0000:00:02.0: reg 10: [mem 0xdfc00000-0xdfcfffff]
[ 0.290472] pci 0000:00:02.0: reg 14: [io 0xf0f0-0xf0f7]
[ 0.290614] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.290650] pci 0000:00:1b.0: reg 10: [mem 0xdff00000-0xdff03fff 64bit]
[ 0.290770] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.290824] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.290948] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.291012] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[ 0.291135] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.291192] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.291275] pci 0000:00:1d.0: reg 20: [io 0xf080-0xf09f]
[ 0.291339] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.291422] pci 0000:00:1d.1: reg 20: [io 0xf060-0xf07f]
[ 0.291484] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.291566] pci 0000:00:1d.2: reg 20: [io 0xf040-0xf05f]
[ 0.291631] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.291714] pci 0000:00:1d.3: reg 20: [io 0xf020-0xf03f]
[ 0.291791] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.291829] pci 0000:00:1d.7: reg 10: [mem 0xdff05000-0xdff053ff]
[ 0.291955] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.291999] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.292122] pci 0000:00:1f.0: [8086:27bc] type 00 class 0x060100
[ 0.292303] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.292336] pci 0000:00:1f.2: reg 10: [io 0xf0e0-0xf0e7]
[ 0.292356] pci 0000:00:1f.2: reg 14: [io 0xf0d0-0xf0d3]
[ 0.292376] pci 0000:00:1f.2: reg 18: [io 0xf0c0-0xf0c7]
[ 0.292396] pci 0000:00:1f.2: reg 1c: [io 0xf0b0-0xf0b3]
[ 0.292416] pci 0000:00:1f.2: reg 20: [io 0xf0a0-0xf0af]
[ 0.292436] pci 0000:00:1f.2: reg 24: [mem 0xdff04000-0xdff043ff]
[ 0.292487] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.292520] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.292603] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f]
[ 0.292774] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 0.292804] pci 0000:01:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.292849] pci 0000:01:00.0: reg 18: [mem 0xdfe04000-0xdfe04fff 64bit pref]
[ 0.292880] pci 0000:01:00.0: reg 20: [mem 0xdfe00000-0xdfe03fff 64bit pref]
[ 0.292959] pci 0000:01:00.0: supports D1 D2
[ 0.292964] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.297865] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.297876] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.297886] pci 0000:00:1c.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.297985] pci 0000:00:1c.3: PCI bridge to [bus 02-02]
[ 0.298064] pci 0000:03:00.0: [2718:5125] type 00 class 0x110000
[ 0.298091] pci 0000:03:00.0: reg 10: [mem 0xdfd00000-0xdfd0ffff]
[ 0.298261] pci 0000:00:1e.0: PCI bridge to [bus 03-03] (subtractive decode)
[ 0.298275] pci 0000:00:1e.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.298289] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.298296] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.298303] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.298310] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
[ 0.298317] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000effff] (subtractive decode)
[ 0.298324] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.298331] pci 0000:00:1e.0: bridge window [mem 0xcf800000-0xcfffffff] (subtractive decode)
[ 0.298338] pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xfebfffff] (subtractive decode)
[ 0.298372] pci_bus 0000:00: on NUMA node 0
[ 0.298381] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.298618] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT]
[ 0.298827] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.298973] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.299365] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.311760] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.311927] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.312093] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.312260] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 *7 11 12 14 15)
[ 0.312422] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
[ 0.312585] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.312747] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 *10 12 14 15)
[ 0.312907] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.313143] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.313166] vgaarb: loaded
[ 0.313172] vgaarb: bridge control possible 0000:00:02.0
[ 0.313258] PCI: Using ACPI for IRQ routing
[ 0.327107] PCI: pci_cache_line_size set to 64 bytes
[ 0.327237] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.327244] reserve RAM buffer: 00000000cef57000 - 00000000cfffffff
[ 0.327251] reserve RAM buffer: 00000000cf520000 - 00000000cfffffff
[ 0.327257] reserve RAM buffer: 00000000cf6f0000 - 00000000cfffffff
[ 0.327566] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.327581] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.329620] Switching to clocksource hpet
[ 0.329826] pnp: PnP ACPI init
[ 0.329855] ACPI: bus type pnp registered
[ 0.330274] pnp 00:00: [bus 00-ff]
[ 0.330282] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.330288] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.330294] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.330300] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.330307] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.330313] pnp 00:00: [mem 0x000e0000-0x000effff window]
[ 0.330319] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.330325] pnp 00:00: [mem 0xcf800000-0xcfffffff window]
[ 0.330332] pnp 00:00: [mem 0xd0000000-0xfebfffff window]
[ 0.330481] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.330531] pnp 00:01: [io 0x0000-0x001f]
[ 0.330537] pnp 00:01: [io 0x0081-0x0091]
[ 0.330542] pnp 00:01: [io 0x0093-0x009f]
[ 0.330548] pnp 00:01: [io 0x00c0-0x00df]
[ 0.330554] pnp 00:01: [dma 4]
[ 0.330614] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.330643] pnp 00:02: [mem 0xff000000-0xffffffff]
[ 0.330702] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.330917] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 0.331025] system 00:03: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.331035] system 00:03: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[ 0.331073] pnp 00:04: [io 0x00f0]
[ 0.331093] pnp 00:04: [irq 13]
[ 0.331155] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.331191] pnp 00:05: [io 0x002e-0x002f]
[ 0.331197] pnp 00:05: [io 0x004e-0x004f]
[ 0.331202] pnp 00:05: [io 0x0061]
[ 0.331207] pnp 00:05: [io 0x0063]
[ 0.331213] pnp 00:05: [io 0x0065]
[ 0.331218] pnp 00:05: [io 0x0067]
[ 0.331223] pnp 00:05: [io 0x0070]
[ 0.331228] pnp 00:05: [io 0x0080]
[ 0.331233] pnp 00:05: [io 0x0092]
[ 0.331239] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.331244] pnp 00:05: [io 0x0680-0x069f]
[ 0.331250] pnp 00:05: [io 0x1000-0x100f]
[ 0.331259] pnp 00:05: [io 0xffff]
[ 0.331265] pnp 00:05: [io 0xffff]
[ 0.331270] pnp 00:05: [io 0x0400-0x047f]
[ 0.331276] pnp 00:05: [io 0x0500-0x057f]
[ 0.331281] pnp 00:05: [io 0x0600-0x061f]
[ 0.331389] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.331396] system 00:05: [io 0x1000-0x100f] has been reserved
[ 0.331404] system 00:05: [io 0xffff] has been reserved
[ 0.331411] system 00:05: [io 0xffff] has been reserved
[ 0.331418] system 00:05: [io 0x0400-0x047f] has been reserved
[ 0.331428] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.331435] system 00:05: [io 0x0600-0x061f] has been reserved
[ 0.331444] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.331525] pnp 00:06: [io 0x06a0-0x06af]
[ 0.331531] pnp 00:06: [io 0x06b0-0x06ef]
[ 0.331632] system 00:06: [io 0x06a0-0x06af] has been reserved
[ 0.331640] system 00:06: [io 0x06b0-0x06ef] has been reserved
[ 0.331648] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.331680] pnp 00:07: [io 0x0070-0x0077]
[ 0.331694] pnp 00:07: [irq 8]
[ 0.331759] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.332103] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.332110] pnp 00:08: [io 0x0a00-0x0a1f]
[ 0.332116] pnp 00:08: [io 0x0a30-0x0a3f]
[ 0.332122] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.332223] system 00:08: [io 0x0a00-0x0a1f] has been reserved
[ 0.332231] system 00:08: [io 0x0a30-0x0a3f] has been reserved
[ 0.332239] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.333070] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.333086] pnp 00:09: [irq 4]
[ 0.333092] pnp 00:09: [dma 0 disabled]
[ 0.333247] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.334036] pnp 00:0a: [io 0x02f8-0x02ff]
[ 0.334052] pnp 00:0a: [irq 3]
[ 0.334058] pnp 00:0a: [dma 0 disabled]
[ 0.334197] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.335205] pnp 00:0b: [io 0x0378-0x037f]
[ 0.335219] pnp 00:0b: [irq 5]
[ 0.335225] pnp 00:0b: [dma 3]
[ 0.335612] pnp 00:0b: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.335685] pnp 00:0c: [io 0x0010-0x001f]
[ 0.335691] pnp 00:0c: [io 0x0022-0x003f]
[ 0.335701] pnp 00:0c: [io 0x0044-0x005f]
[ 0.335706] pnp 00:0c: [io 0x0062-0x0063]
[ 0.335712] pnp 00:0c: [io 0x0065-0x006f]
[ 0.335717] pnp 00:0c: [io 0x0072-0x007f]
[ 0.335723] pnp 00:0c: [io 0x0080]
[ 0.335728] pnp 00:0c: [io 0x0084-0x0086]
[ 0.335733] pnp 00:0c: [io 0x0088]
[ 0.335739] pnp 00:0c: [io 0x008c-0x008e]
[ 0.335744] pnp 00:0c: [io 0x0090-0x009f]
[ 0.335749] pnp 00:0c: [io 0x00a2-0x00bf]
[ 0.335755] pnp 00:0c: [io 0x00e0-0x00ef]
[ 0.335760] pnp 00:0c: [io 0x04d0-0x04d1]
[ 0.335877] system 00:0c: [io 0x04d0-0x04d1] has been reserved
[ 0.335886] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.336339] pnp 00:0d: [mem 0xfed1c000-0xfed1ffff]
[ 0.336346] pnp 00:0d: [mem 0x00000000-0x00003fff]
[ 0.336353] pnp 00:0d: [mem 0x00000000-0x00000fff]
[ 0.336358] pnp 00:0d: [mem 0x00000000-0x00000fff]
[ 0.336364] pnp 00:0d: [mem 0x00000000-0xffffffff disabled]
[ 0.336370] pnp 00:0d: [mem 0xfed45000-0xfed8ffff]
[ 0.336505] system 00:0d: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.336514] system 00:0d: [mem 0x00000000-0x00003fff] could not be reserved
[ 0.336522] system 00:0d: [mem 0x00000000-0x00000fff] could not be reserved
[ 0.336529] system 00:0d: [mem 0x00000000-0x00000fff] could not be reserved
[ 0.336537] system 00:0d: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.336546] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.337113] pnp 00:0e: [mem 0xfed14000-0xfed19fff]
[ 0.337121] pnp 00:0e: [mem 0xe0000000-0xefffffff]
[ 0.337273] system 00:0e: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.337281] system 00:0e: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.337290] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.337319] pnp 00:0f: [mem 0xff000000-0xffffffff]
[ 0.337436] pnp 00:0f: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.337852] pnp 00:10: [io 0x0400-0x047f]
[ 0.337860] pnp 00:10: [io 0x0500-0x053f]
[ 0.337867] pnp 00:10: [mem 0xfec00000-0xfec00fff]
[ 0.337873] pnp 00:10: [mem 0xfee00000-0xfee00fff]
[ 0.337878] pnp 00:10: [mem 0xfed1c000-0xfed1ffff]
[ 0.337884] pnp 00:10: [mem 0xfed20000-0xfed8ffff]
[ 0.337890] pnp 00:10: [mem 0xffc00000-0xffffffff]
[ 0.338046] system 00:10: [io 0x0400-0x047f] has been reserved
[ 0.338054] system 00:10: [io 0x0500-0x053f] has been reserved
[ 0.338062] system 00:10: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.338070] system 00:10: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.338077] system 00:10: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.338085] system 00:10: [mem 0xfed20000-0xfed8ffff] could not be reserved
[ 0.338093] system 00:10: [mem 0xffc00000-0xffffffff] has been reserved
[ 0.338101] system 00:10: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.338112] pnp: PnP ACPI: found 17 devices
[ 0.338116] ACPI: ACPI bus type pnp unregistered
[ 0.338123] PnPBIOS: Disabled by ACPI PNP
[ 0.379485] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-01] add_size 200000
[ 0.379509] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 0.379518] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 0.379526] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 02-02] add_size 200000
[ 0.379556] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.379564] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.379572] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.379580] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.379594] pci 0000:00:1c.0: BAR 15: assigned [mem 0xd0000000-0xd01fffff 64bit pref]
[ 0.379603] pci 0000:00:1c.3: BAR 14: assigned [mem 0xd0200000-0xd03fffff]
[ 0.379613] pci 0000:00:1c.3: BAR 15: assigned [mem 0xd0400000-0xd05fffff 64bit pref]
[ 0.379624] pci 0000:00:1c.3: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.379634] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.379642] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.379655] pci 0000:00:1c.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.379665] pci 0000:00:1c.0: bridge window [mem 0xd0000000-0xd01fffff 64bit pref]
[ 0.379680] pci 0000:00:1c.3: PCI bridge to [bus 02-02]
[ 0.379688] pci 0000:00:1c.3: bridge window [io 0x2000-0x2fff]
[ 0.379699] pci 0000:00:1c.3: bridge window [mem 0xd0200000-0xd03fffff]
[ 0.379710] pci 0000:00:1c.3: bridge window [mem 0xd0400000-0xd05fffff 64bit pref]
[ 0.379724] pci 0000:00:1e.0: PCI bridge to [bus 03-03]
[ 0.379737] pci 0000:00:1e.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.379824] pci 0000:00:1e.0: setting latency timer to 64
[ 0.379833] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.379840] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.379846] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.379852] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff]
[ 0.379858] pci_bus 0000:00: resource 8 [mem 0x000e0000-0x000effff]
[ 0.379865] pci_bus 0000:00: resource 9 [mem 0x000f0000-0x000fffff]
[ 0.379871] pci_bus 0000:00: resource 10 [mem 0xcf800000-0xcfffffff]
[ 0.379877] pci_bus 0000:00: resource 11 [mem 0xd0000000-0xfebfffff]
[ 0.379884] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.379890] pci_bus 0000:01: resource 1 [mem 0xdfe00000-0xdfefffff]
[ 0.379897] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xd01fffff 64bit pref]
[ 0.379903] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 0.379909] pci_bus 0000:02: resource 1 [mem 0xd0200000-0xd03fffff]
[ 0.379916] pci_bus 0000:02: resource 2 [mem 0xd0400000-0xd05fffff 64bit pref]
[ 0.379923] pci_bus 0000:03: resource 1 [mem 0xdfd00000-0xdfdfffff]
[ 0.379929] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.379935] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.379941] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.379947] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000dffff]
[ 0.379954] pci_bus 0000:03: resource 8 [mem 0x000e0000-0x000effff]
[ 0.379960] pci_bus 0000:03: resource 9 [mem 0x000f0000-0x000fffff]
[ 0.379966] pci_bus 0000:03: resource 10 [mem 0xcf800000-0xcfffffff]
[ 0.379973] pci_bus 0000:03: resource 11 [mem 0xd0000000-0xfebfffff]
[ 0.380197] NET: Registered protocol family 2
[ 0.380345] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.380847] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.381764] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.382164] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.382171] TCP: reno registered
[ 0.382180] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.382200] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.382481] NET: Registered protocol family 1
[ 0.382519] pci 0000:00:02.0: Boot video device
[ 0.401594] PCI: CLS 64 bytes, default 64
[ 0.401721] Unpacking initramfs...
[ 0.956431] Freeing initrd memory: 13700k freed
[ 0.969432] audit: initializing netlink socket (disabled)
[ 0.969469] type=2000 audit(1552419784.860:1): initialized
[ 0.992046] highmem bounce pool size: 64 pages
[ 0.992058] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.992689] VFS: Disk quotas dquot_6.5.2
[ 0.992757] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.992941] msgmni has been set to 1696
[ 0.993383] alg: No test for stdrng (krng)
[ 0.993475] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.993484] io scheduler noop registered
[ 0.993489] io scheduler deadline registered
[ 0.993552] io scheduler cfq registered (default)
[ 0.993999] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.994050] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.994056] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.994989] GHES: HEST is not enabled!
[ 0.995018] isapnp: Scanning for PnP cards...
[ 1.348673] isapnp: No Plug & Play device found
[ 1.348799] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.369385] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.390014] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.411180] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.431927] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.432551] Linux agpgart interface v0.103
[ 1.433022] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.433572] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.433603] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.433882] mousedev: PS/2 mouse device common for all mice
[ 1.433978] rtc_cmos 00:07: RTC can wake from S4
[ 1.434298] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 1.434347] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.434632] TCP: cubic registered
[ 1.434814] NET: Registered protocol family 10
[ 1.435308] Mobile IPv6
[ 1.435315] NET: Registered protocol family 17
[ 1.435327] Registering the dns_resolver key type
[ 1.435426] Using IPI No-Shortcut mode
[ 1.435769] PM: Hibernation image not present or could not be loaded.
[ 1.435801] registered taskstats version 1
[ 1.436585] rtc_cmos 00:07: setting system clock to 2019-03-12 19:43:05 UTC (1552419785)
[ 1.436876] Freeing unused kernel memory: 416k freed
[ 1.437251] Write protecting the kernel text: 3496k
[ 1.437309] Write protecting the kernel read-only data: 984k
[ 1.465669] udevd[59]: starting version 175
[ 1.538149] usbcore: registered new interface driver usbfs
[ 1.538240] usbcore: registered new interface driver hub
[ 1.540816] usbcore: registered new device driver usb
[ 1.542492] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.542670] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.542685] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.542770] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.542828] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.542858] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.546715] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.547403] r8169 0000:01:00.0: eth0: RTL8168e/8111e at 0xf8018000, 74:27:ea:40:90:a1, XID 0c200000 IRQ 16
[ 1.547418] r8169 0000:01:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.547978] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.548054] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xdff05000
[ 1.552817] SCSI subsystem initialized
[ 1.559603] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.559737] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.559748] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.559760] usb usb1: Product: EHCI Host Controller
[ 1.559769] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.559778] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.560106] hub 1-0:1.0: USB hub found
[ 1.560123] hub 1-0:1.0: 8 ports detected
[ 1.561407] libata version 3.00 loaded.
[ 1.562598] ata_piix 0000:00:1f.2: version 2.13
[ 1.562650] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.568661] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.581583] ACPI: Fan [FAN0] (off)
[ 1.605348] microcode: CPU0 sig=0x30661, pf=0x4, revision=0x10d
[ 1.649662] microcode: CPU1 sig=0x30661, pf=0x4, revision=0x10d
[ 1.655460] microcode: CPU2 sig=0x30661, pf=0x4, revision=0x10d
[ 1.661236] microcode: CPU3 sig=0x30661, pf=0x4, revision=0x10d
[ 1.667956] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.715311] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.716143] scsi0 : ata_piix
[ 1.716457] scsi1 : ata_piix
[ 1.716583] ata1: SATA max UDMA/133 cmd 0xf0e0 ctl 0xf0d0 bmdma 0xf0a0 irq 19
[ 1.716591] ata2: SATA max UDMA/133 cmd 0xf0c0 ctl 0xf0b0 bmdma 0xf0a8 irq 19
[ 1.716723] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.716740] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.716817] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.716888] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000f080
[ 1.717024] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.717034] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.717043] usb usb2: Product: UHCI Host Controller
[ 1.717051] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.717058] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.717442] hub 2-0:1.0: USB hub found
[ 1.717458] hub 2-0:1.0: 2 ports detected
[ 1.717750] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.717762] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.717792] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.717854] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000f060
[ 1.717983] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.717994] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.718002] usb usb3: Product: UHCI Host Controller
[ 1.718010] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.718018] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.718456] hub 3-0:1.0: USB hub found
[ 1.718477] hub 3-0:1.0: 2 ports detected
[ 1.718748] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.718762] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.718788] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.718885] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000f040
[ 1.719015] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.719025] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.719033] usb usb4: Product: UHCI Host Controller
[ 1.719041] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.719048] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.719510] hub 4-0:1.0: USB hub found
[ 1.719531] hub 4-0:1.0: 2 ports detected
[ 1.719831] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.719844] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.719879] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.719954] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000f020
[ 1.720050] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.720057] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.720064] usb usb5: Product: UHCI Host Controller
[ 1.720070] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.720075] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.720410] hub 5-0:1.0: USB hub found
[ 1.720423] hub 5-0:1.0: 2 ports detected
[ 1.871034] usb 1-6: new high-speed USB device number 2 using ehci_hcd
[ 1.882895] ata1.00: ATA-8: WDC WD2500AAKX-00ERMA0, 15.01H15, max UDMA/133
[ 1.882904] ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.891928] ata1.00: configured for UDMA/133
[ 1.892197] scsi 0:0:0:0: Direct-Access ATA WDC WD2500AAKX-0 15.0 PQ: 0 ANSI: 5
[ 1.902808] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.903128] sd 0:0:0:0: [sda] Write Protect is off
[ 1.903139] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.903241] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.934134] sda: sda1 sda2 sda3 sda4 < sda5 >
[ 1.935408] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.939736] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.962899] Refined TSC clocksource calibration: 1861.999 MHz.
[ 1.962911] Switching to clocksource tsc
[ 2.003343] usb 1-6: New USB device found, idVendor=1a40, idProduct=0101
[ 2.003354] usb 1-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.003360] usb 1-6: Product: USB 2.0 Hub
[ 2.003797] hub 1-6:1.0: USB hub found
[ 2.003969] hub 1-6:1.0: 4 ports detected
[ 2.274524] usb 1-6.3: new high-speed USB device number 3 using ehci_hcd
[ 2.366842] usb 1-6.3: New USB device found, idVendor=1a40, idProduct=0101
[ 2.366851] usb 1-6.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.366858] usb 1-6.3: Product: USB 2.0 Hub
[ 2.367310] hub 1-6.3:1.0: USB hub found
[ 2.367466] hub 1-6.3:1.0: 4 ports detected
[ 2.653734] usb 1-6.3.1: new full-speed USB device number 4 using ehci_hcd
[ 2.765035] usb 1-6.3.1: New USB device found, idVendor=04e7, idProduct=0050
[ 2.765044] usb 1-6.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.765051] usb 1-6.3.1: Product: Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface
[ 2.765057] usb 1-6.3.1: Manufacturer: EloTouchSystems,Inc
[ 2.765062] usb 1-6.3.1: SerialNumber: 50U16779
[ 2.776162] input: EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface as /devices/pci0000:00/0000:00:1d.7/usb1/1-6/1-6.3/1-6.3.1/1-6.3.1:1.0/input/input0
[ 2.776431] generic-usb 0003:04E7:0050.0001: input,hidraw0: USB HID v1.00 Pointer [EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface] on usb-0000:00:1d.7-6.3.1/input0
[ 2.776500] usbcore: registered new interface driver usbhid
[ 2.776507] usbhid: USB HID core driver
[ 2.837423] usb 1-6.3.2: new high-speed USB device number 5 using ehci_hcd
[ 2.930119] usb 1-6.3.2: New USB device found, idVendor=0bda, idProduct=8812
[ 2.930127] usb 1-6.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.930134] usb 1-6.3.2: Product: 802.11n NIC
[ 2.930139] usb 1-6.3.2: Manufacturer: Realtek
[ 2.930144] usb 1-6.3.2: SerialNumber: 123456
[ 3.017105] usb 1-6.3.4: new full-speed USB device number 6 using ehci_hcd
[ 3.128780] usb 1-6.3.4: New USB device found, idVendor=046d, idProduct=c52b
[ 3.128791] usb 1-6.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.128798] usb 1-6.3.4: Product: USB Receiver
[ 3.128803] usb 1-6.3.4: Manufacturer: Logitech
[ 3.146624] logitech-djreceiver 0003:046D:C52B.0004: hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.7-6.3.4/input2
[ 3.151888] input: Logitech Unifying Device. Wireless PID:401b as /devices/pci0000:00/0000:00:1d.7/usb1/1-6/1-6.3/1-6.3.4/1-6.3.4:1.2/0003:046D:C52B.0004/input/input1
[ 3.152189] logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:401b] on usb-0000:00:1d.7-6.3.4:1
[ 3.155785] input: Logitech Unifying Device. Wireless PID:4016 as /devices/pci0000:00/0000:00:1d.7/usb1/1-6/1-6.3/1-6.3.4/1-6.3.4:1.2/0003:046D:C52B.0004/input/input2
[ 3.156024] logitech-djdevice 0003:046D:C52B.0006: input,hidraw3: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4016] on usb-0000:00:1d.7-6.3.4:2
[ 7.379824] PM: Starting manual resume from disk
[ 7.379833] PM: Hibernation image partition 8:2 present
[ 7.379838] PM: Looking for hibernation image.
[ 7.380187] PM: Image not found (code -22)
[ 7.380192] PM: Hibernation image not present or could not be loaded.
[ 7.394151] EXT4-fs (sda3): INFO: recovery required on readonly filesystem
[ 7.394160] EXT4-fs (sda3): write access will be enabled during recovery
[ 8.345972] EXT4-fs (sda3): recovery complete
[ 8.359345] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 9.710531] udevd[394]: starting version 175
[ 10.055832] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 10.055859] ACPI: Power Button [PWRB]
[ 10.056085] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 10.056100] ACPI: Sleep Button [SLPB]
[ 10.056286] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 10.056301] ACPI: Power Button [PWRF]
[ 10.095490] wmi: Mapper loaded
[ 10.354788] iTCO_vendor_support: vendor-support=0
[ 10.355911] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 10.356105] iTCO_wdt: Found a NM10 TCO device (Version=2, TCOBASE=0x0460)
[ 10.356273] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.363965] coretemp coretemp.0: Unable to read TjMax from CPU 0
[ 10.364021] coretemp coretemp.0: Unable to read TjMax from CPU 2
[ 10.475802] parport_pc 00:0b: reported by Plug and Play ACPI
[ 10.475878] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 10.620613] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 10.620895] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 10.621162] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 10.621409] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 10.621653] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 11.319227] RTL871X: module init start
[ 11.319239] RTL871X: rtl8812au v4.3.13_14061.20150505
[ 11.319246] RTL871X: build time: Mar 11 2019 15:19:06
[ 11.319331] RTL871X:
[ 11.319334] usb_endpoint_descriptor(0):
[ 11.319341] RTL871X: bLength=7
[ 11.319346] RTL871X: bDescriptorType=5
[ 11.319352] RTL871X: bEndpointAddress=81
[ 11.319358] RTL871X: wMaxPacketSize=512
[ 11.319364] RTL871X: bInterval=0
[ 11.319370] RTL871X: RT_usb_endpoint_is_bulk_in = 1
[ 11.319376] RTL871X:
[ 11.319379] usb_endpoint_descriptor(1):
[ 11.319385] RTL871X: bLength=7
[ 11.319391] RTL871X: bDescriptorType=5
[ 11.319397] RTL871X: bEndpointAddress=2
[ 11.319402] RTL871X: wMaxPacketSize=512
[ 11.319408] RTL871X: bInterval=0
[ 11.319414] RTL871X: RT_usb_endpoint_is_bulk_out = 2
[ 11.319420] RTL871X:
[ 11.319422] usb_endpoint_descriptor(2):
[ 11.319428] RTL871X: bLength=7
[ 11.319433] RTL871X: bDescriptorType=5
[ 11.319438] RTL871X: bEndpointAddress=3
[ 11.319444] RTL871X: wMaxPacketSize=512
[ 11.319450] RTL871X: bInterval=0
[ 11.319456] RTL871X: RT_usb_endpoint_is_bulk_out = 3
[ 11.319462] RTL871X:
[ 11.319465] usb_endpoint_descriptor(3):
[ 11.319471] RTL871X: bLength=7
[ 11.319476] RTL871X: bDescriptorType=5
[ 11.319481] RTL871X: bEndpointAddress=4
[ 11.319487] RTL871X: wMaxPacketSize=512
[ 11.319493] RTL871X: bInterval=0
[ 11.319498] RTL871X: RT_usb_endpoint_is_bulk_out = 4
[ 11.319505] RTL871X:
[ 11.319507] usb_endpoint_descriptor(4):
[ 11.319513] RTL871X: bLength=7
[ 11.319518] RTL871X: bDescriptorType=5
[ 11.319524] RTL871X: bEndpointAddress=85
[ 11.319529] RTL871X: wMaxPacketSize=64
[ 11.319534] RTL871X: bInterval=1
[ 11.319541] RTL871X: RT_usb_endpoint_is_int_in = 5, Interval = 1
[ 11.319549] RTL871X: nr_endpoint=5, in_num=2, out_num=3
[ 11.319552]
[ 11.319557] RTL871X: USB_SPEED_HIGH
[ 11.319629] RTL871X: CHIP TYPE: RTL8812
[ 11.319657] RTL871X: register rtw_netdev_ops to netdev_ops
[ 11.320074] RTL871X: ReadChipVersion8812A SYS_CFG(0xF0)=0x04411137
[ 11.320158] RTL871X: Chip Version Info: CHIP_8812_Normal_Chip_TSMC_C_CUT_2T2R_RomVer(0)
[ 11.320164] RTL871X: RF_Type is 2!!
[ 11.320170] RTL871X: _ConfigChipOutEP_8812 OutEpQueueSel(0x07), OutEpNumber(3)
[ 11.320176] RTL871X: ====> ReadAdapterInfo8812AU
[ 11.320281] RTL871X: Boot from EFUSE, Autoload OK !
[ 11.584703] RTL871X: EEPROM ID=0x8129
[ 11.584711] RTL871X: VID = 0x0BDA, PID = 0x8812
[ 11.584716] RTL871X: Customer ID: 0x00, SubCustomer ID: 0xCD
[ 11.584723] RTL871X: hal_ReadMACAddress_8812AU MAC Address from EFUSE = 24:05:0f:f6:e9:e1
[ 11.584735] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 11.584743] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 11.584751] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 11.584758] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found
[ 11.584765] RTL871X: EEPROMRegulatory = 0x2 TxPwrCalibrateRate=0x0
[ 11.584769] RTL871X: Board Type: 0x 0
[ 11.584774] RTL871X: mlmepriv.ChannelPlan = 0x7f
[ 11.584778] RTL871X: CrystalCap: 0x10
[ 11.584783] RTL871X: ThermalMeter = 0x1b
[ 11.584787] RTL871X: Hal_ReadRemoteWakeup_8812A...bSupportRemoteWakeup(0)
[ 11.584793] RTL871X: SWAS: bHwAntDiv = 0, TRxAntDivType = 3
[ 11.584798] RTL871X: pHalData->PAType_2G is 0x3, pHalData->ExternalPA_2G = 0
[ 11.584803] RTL871X: pHalData->PAType_5G is 0x3, pHalData->ExternalPA_5G = 1
[ 11.584808] RTL871X: pHalData->LNAType_2G is 0x0, pHalData->ExternalLNA_2G = 0
[ 11.584814] RTL871X: pHalData->LNAType_5G is 0x88, pHalData->ExternalLNA_5G = 1
[ 11.584819] RTL871X: pHalData->TypeGPA = 0x0
[ 11.584823] RTL871X: pHalData->TypeAPA = 0x0
[ 11.584827] RTL871X: pHalData->TypeGLNA = 0x0
[ 11.584831] RTL871X: pHalData->TypeALNA = 0x0
[ 11.584836] RTL871X: RFE Type: 0x 0
[ 11.584840] RTL871X: PID= 0x8812, VID= bda
[ 11.584845] RTL871X: PID= 0x8812, VID= bda
[ 11.584849] RTL871X: Customer ID: 0x 0
[ 11.586586] RTL871X: hal_ReadUsbType_8812AU: antenna=2, wmode=3
[ 11.586595] RTL871X: hal_ReadUsbType_8812AU(): EFUSE_HIDDEN_812AU
[ 11.586602] RTL871X: ReadAdapterInfo8812AU <====
[ 11.586935] RTL871X: Hal_ChannelPlanToRegulation ChannelPlan:0x7f,Regulation(2_4G/5G):0x03,0x03
[ 11.586948] RTL871X: init_channel_set ChannelPlan ID 7f Chan num:37
[ 11.587747] RTL871X: NR_RECVBUFF: 8
[ 11.587753] RTL871X: MAX_RECVBUF_SZ: 32768
[ 11.587762] RTL871X: NR_PREALLOC_RECV_SKB: 8
[ 11.587977] RTL871X: rtw_alloc_macid(eth%d) if1, hwaddr:ff:ff:ff:ff:ff:ff macid:1
[ 11.588007] RTL871X: rtw_macaddr_cfg mac addr:24:05:0f:f6:e9:e1
[ 11.588014] RTL871X: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
[ 11.588033] RTL871X: rtw_ndev_init(wlan0)
[ 11.588879] RTL871X: _rtw_drv_register_netdev, MAC Address (if1) = 24:05:0f:f6:e9:e1
[ 11.588965] usbcore: registered new interface driver rtl8812au
[ 11.588974] RTL871X: module init ret=0
[ 11.660578] udevd[446]: renamed network interface wlan0 to wlan1
[ 12.574762] Adding 2097148k swap on /dev/sda2. Priority:-1 extents:1 across:2097148k
[ 12.609257] EXT4-fs (sda3): re-mounted. Opts: (null)
[ 12.928792] EXT4-fs (sda3): re-mounted. Opts: errors=remount-ro
[ 13.060286] loop: module loaded
[ 14.640485] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 15.612424] RPC: Registered named UNIX socket transport module.
[ 15.612432] RPC: Registered udp transport module.
[ 15.612437] RPC: Registered tcp transport module.
[ 15.612443] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.658271] FS-Cache: Loaded
[ 15.689418] NFS: Registering the id_resolver key type
[ 15.689475] FS-Cache: Netfs 'nfs' registered for caching
[ 15.698815] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 17.880056] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input11
[ 18.684277] Bluetooth: Core ver 2.16
[ 18.684326] NET: Registered protocol family 31
[ 18.684333] Bluetooth: HCI device and connection manager initialized
[ 18.684340] Bluetooth: HCI socket layer initialized
[ 18.684345] Bluetooth: L2CAP socket layer initialized
[ 18.684361] Bluetooth: SCO socket layer initialized
[ 18.707808] Bluetooth: RFCOMM TTY layer initialized
[ 18.707826] Bluetooth: RFCOMM socket layer initialized
[ 18.707838] Bluetooth: RFCOMM ver 1.11
[ 18.881269] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.881280] Bluetooth: BNEP filters: protocol multicast
[ 19.213192] lp0: using parport0 (interrupt-driven).
[ 19.501927] ppdev: user-space parallel port driver
[ 20.486593] r8169 0000:01:00.0: eth0: link down
[ 20.487024] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.491520] RTL871X: LeaveAllPowerSaveMode(wlan1): bup=0 Skip!
[ 20.491529] RTL871X: rtw_wx_set_scan: bDriverStopped=1, bup=0, hw_init_completed=0
[ 20.493057] RTL871X: +871x_drv - drv_open, bup=0
[ 20.493474] RTL871X: power-on :REG_SYS_CLKR 0x09=0xfc. REG_CR 0x100=0xea.
[ 20.493484] RTL871X: MAC has not been powered on yet.
[ 20.497589] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 20.562353] RTL871X: FirmwareDownload8812 fw source from Header
[ 20.562362] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 20.562369] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 20.606403] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070305
[ 20.608270] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 20.636228] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (221, 32ms), REG_MCUFWDL:0x000707c6
[ 20.636237] RTL871X: FWDL success. write_fw:1, 72ms
[ 20.636243] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 20.661432] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 2
[ 20.980753] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 21.600565] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 21.602558] RTL871X: MAC Address from REG_MACID = 24:05:0f:f6:e9:e1
[ 21.602566] RTL871X: rtl8812au_hal_init in 1112ms
[ 21.603058] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 21.603555] RTL871X: MAC Address = 24:05:0f:f6:e9:e1
[ 21.603690] RTL871X: -871x_drv - drv_open, bup=1
[ 21.604075] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 21.685574] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 21.685589] RTL871X: set_mode = IW_MODE_INFRA
[ 21.685707] RTL871X: set bssid:00:00:00:00:00:00
[ 21.685918] RTL871X: =>rtw_wx_set_essid
[ 21.685926] RTL871X: ssid=g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a, len=32
[ 21.685937] RTL871X: set ssid [g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a\xffffffb8\xffffffe4\xffffff86\xffffff85\xffffff86\xffffff85\xfffffff2\xffffffff\xffffffff\xffffffff\x1a\xffffff8b] fw_state=0x00000008
[ 21.685943] RTL871X: Set SSID under fw_state=0x00000008
[ 21.685956] RTL871X: <=rtw_wx_set_essid, ret 0
[ 21.686179] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 21.693164] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 23.320974] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 26.303210] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 26.337150] RTL871X: survey done event(2e) band:0 for wlan1
[ 26.337168] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 26.337174] RTL871X: try_to_join, but select scanning queue fail, to_roam:0
[ 26.337180] RTL871X: indicate disassoc
[ 26.337468] RTL871X: rtw_indicate_scan_done(wlan1)
[ 26.337697] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0)
[ 26.337709] RTL871X: beamforming_deinit_entry Idx 0
[ 26.337718] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 26.345885] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 26.345897] RTL871X: ==>ips_enter cnts:1
[ 26.345905] RTL871X: nolinked power save enter
[ 26.345911] RTL871X: ===> rtw_ips_pwr_down...................
[ 26.345919] RTL871X: ====> rtw_ips_dev_unload...
[ 26.356661] RTL871X: usb_read_port_cancel
[ 26.356740] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.356982] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.357095] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.357223] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.357343] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.357466] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.357591] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.357718] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 26.357739] RTL871X: usb_write_port_cancel
[ 26.357769] RTL871X: ==> rtl8812au_hal_deinit
[ 26.358727] RTL871X: hal_poweroff_8812au
[ 26.363362] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 26.369477] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=0
[ 26.369970] RTL871X: <=== rtw_ips_pwr_down..................... in 24ms
[ 26.437465] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 26.437477] RTL871X: ==>ips_leave cnts:1
[ 26.437483] RTL871X: ===> rtw_ips_pwr_up..............
[ 26.437498] RTL871X: ===> ips_netdrv_open.........
[ 26.437723] RTL871X: power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[ 26.437729] RTL871X: MAC has not been powered on yet.
[ 26.442470] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 26.506604] RTL871X: FirmwareDownload8812 fw source from Header
[ 26.506613] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 26.506619] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 26.549907] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705
[ 26.551777] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 26.579732] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (224, 28ms), REG_MCUFWDL:0x000707c6
[ 26.579739] RTL871X: FWDL success. write_fw:1, 72ms
[ 26.579745] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 26.604685] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 2
[ 26.922392] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 27.537207] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 27.539202] RTL871X: MAC Address from REG_MACID = 24:05:0f:f6:e9:e1
[ 27.539212] RTL871X: rtl8812au_hal_init in 1104ms
[ 27.539700] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 27.540220] RTL871X: <=== rtw_ips_pwr_up.............. in 1104ms
[ 27.540225] RTL871X: nolinked power save leave
[ 27.540319] RTL871X: ==> ips_leave.....LED(0x00022828)...
[ 27.540328] RTL871X: IW_SCAN_THIS_ESSID, ssid=VPN.2.4Ghz.Router, len=17
[ 29.174633] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 32.149256] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 32.183196] RTL871X: survey done event(31) band:0 for wlan1
[ 32.183210] RTL871X: rtw_indicate_scan_done(wlan1)
[ 32.186958] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 32.186976] RTL871X: set_mode = IW_MODE_INFRA
[ 32.187051] RTL871X:
[ 32.187054] wpa_ie(length:22):
[ 32.187064] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x04
[ 32.187074] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 32.187085] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00
[ 32.190564] RTL871X: SetHwReg8812A, 5710, RCR= f40060ca
[ 32.190599] RTL871X: rtw_wx_set_freq: set to channel 1
[ 32.190622] RTL871X: =>rtw_wx_set_essid
[ 32.190627] RTL871X: ssid=VPN.2.4Ghz.Router, len=17
[ 32.190637] RTL871X: set ssid [VPN.2.4Ghz.Router] fw_state=0x00000008
[ 32.190642] RTL871X: Set SSID under fw_state=0x00000008
[ 32.190658] RTL871X: [by_bssid:0][assoc_ssid:VPN.2.4Ghz.Router][to_roam:0] new candidate: VPN.2.4Ghz.Router(0c:9d:92:b9:8d:00, ch1) rssi:-66
[ 32.190692] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: VPN.2.4Ghz.Router(0c:9d:92:b9:8d:00, ch:1)
[ 32.190729] RTL871X: link to Artheros AP
[ 32.190743] RTL871X: [HT] HAL Support STBC = 0x01
[ 32.190750] RTL871X: [HT] Declare supporting RX STBC_2R
[ 32.190759] RTL871X: [VHT] Support STBC = 0x03
[ 32.190764] RTL871X: [VHT] Support Beamformee
[ 32.190816] RTL871X: <=rtw_wx_set_essid, ret 0
[ 32.190838] RTL871X: set bssid:0c:9d:92:b9:8d:00
[ 32.190845] RTL871X: Set BSSID under fw_state=0x00000088
[ 32.192313] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 32.192819] RTL871X: start_join_set_ch_bw: ch=1, bwmode=0, ch_offset=0
[ 32.230774] RTL871X: OnBeacon: beacon keys ready
[ 32.230782] RTL871X: link to Broadcom AP
[ 32.230788] RTL871X: start auth
[ 32.230794] RTL871X: issue_auth
[ 32.233860] RTL871X: OnAuthClient
[ 32.233865] RTL871X: auth success, start assoc
[ 32.233876] RTL871X: network.SupportedRates[0]=82
[ 32.233881] RTL871X: network.SupportedRates[1]=84
[ 32.233886] RTL871X: network.SupportedRates[2]=8B
[ 32.233890] RTL871X: network.SupportedRates[3]=96
[ 32.233894] RTL871X: network.SupportedRates[4]=0C
[ 32.233899] RTL871X: network.SupportedRates[5]=12
[ 32.233903] RTL871X: network.SupportedRates[6]=18
[ 32.233907] RTL871X: network.SupportedRates[7]=24
[ 32.233912] RTL871X: network.SupportedRates[8]=30
[ 32.233916] RTL871X: network.SupportedRates[9]=48
[ 32.233921] RTL871X: network.SupportedRates[10]=60
[ 32.233925] RTL871X: network.SupportedRates[11]=6C
[ 32.233930] RTL871X: bssrate_len = 12
[ 32.239749] RTL871X: OnAssocRsp
[ 32.239758] RTL871X: Current VHT STBC Setting = 0A
[ 32.239763] RTL871X: Current VHT Beamforming Setting = 01
[ 32.239772] RTL871X: report_join_res(4)
[ 32.239778] RTL871X: rtw_joinbss_update_network
[ 32.239786] RTL871X: +rtw_update_ht_cap()
[ 32.239800] RTL871X: rtw_alloc_macid(wlan1) if1, hwaddr:0c:9d:92:b9:8d:00 macid:0
[ 32.239804] RTL871X: rtw_joinbss_update_stainfo
[ 32.239812] RTL871X: RateBitmap=00000000000fffff , pVHTRate[0]=fa
[ 32.239835] RTL871X: supp_mcs_set = ff, ff, 00, rf_type=193, tx_ra_bitmap=00000000ffffffff
[ 32.239841] RTL871X: unexpected wireless mode!(psta->wireless_mode=43)
[ 32.239845] RTL871X: ### Set STA_(0) info ###
[ 32.239854] RTL871X: assoc success
[ 32.239900] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 32.240360] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 32.240721] RTL871X: WMM(0): 0, a42b
[ 32.240848] RTL871X: WMM(1): 0, a44f
[ 32.240969] RTL871X: WMM(2): 0, 5e4322
[ 32.241091] RTL871X: WMM(3): 0, 2f3222
[ 32.241097] RTL871X: wmm_para_seq(0): 0
[ 32.241101] RTL871X: wmm_para_seq(1): 1
[ 32.241105] RTL871X: wmm_para_seq(2): 2
[ 32.241110] RTL871X: wmm_para_seq(3): 3
[ 32.241115] RTL871X: HTOnAssocRsp
[ 32.241215] RTL871X: VHTOnAssocRsp
[ 32.241348] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x43, rate_bitmap:0x0fffffff
[ 32.241357] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x43, mask:0xffffffff
[ 32.241360] ==> rssi_level:0, rate_bitmap:0x0fffffff, psta->raid=1
[ 32.242468] RTL871X: [MacId], Set MacId Ctrl(original) = 0x10000
[ 32.244092] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 32.245216] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(1)
[ 32.246336] RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 512, RsvdPageNUm: 7
[ 32.246349] RTL871X: LocPsPoll: 2
[ 32.246358] RTL871X: LocNullData: 3
[ 32.246366] RTL871X: LocQosNull: 4
[ 32.246604] RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(2634), TotalPageNum(5)
[ 32.246641] RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0
[ 32.247708] RTL871X: wlan1: 1 DL RSVD page success! DLBcnCount:1, poll:1
[ 32.248456] RTL871X: Set RSVD page location to Fw.
[ 32.248580] RTL871X: Beamforming Config Capability = 0x08
[ 32.248587] RTL871X: beamforming_init_entry Idx 0
[ 32.250733] RTL871X: recv eapol packet
[ 32.252539] RTL871X: send eapol packet
[ 32.257444] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 32.257454] RTL871X: =>mlmeext_joinbss_event_callback
[ 32.269318] RTL871X: recv eapol packet
[ 32.269558] RTL871X: send eapol packet
[ 32.269599] RTL871X: ~~~~set sta key:unicastkey
[ 32.269637] RTL871X: set pairwise key camid:4, addr:0c:9d:92:b9:8d:00, kid:0, type:AES
[ 32.269752] RTL871X: ~~~~set sta key:groupkey
[ 32.269762] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[ 32.272796] RTL871X: set group key camid:5, addr:0c:9d:92:b9:8d:00, kid:1, type:AES
[ 32.273161] RTL871X: SetHwReg8812A, 5703, RCR= f40060ce
[ 32.390126] RTL871X: OnAction_back
[ 32.390134] RTL871X: OnAction_back, action=0
[ 32.390153] RTL871X: issue_addba_rsp(wlan1) ra=0c:9d:92:b9:8d:00 status=0, tid=6, size=64
[ 32.392228] RTL871X: beamforming_get_ndpa_frame LogSeq 17 LogRetryCnt 0 LogSuccessCnt 0
[ 32.393354] RTL871X: beamforming_get_ndpa_frame LogSeq 18 LogRetryCnt 0 LogSuccessCnt 1
[ 32.394466] RTL871X: beamforming_get_ndpa_frame LogSeq 19 LogRetryCnt 0 LogSuccessCnt 2
[ 33.834988] RTL871X: OnAction_back
[ 33.834996] RTL871X: OnAction_back, action=0
[ 33.835015] RTL871X: issue_addba_rsp(wlan1) ra=0c:9d:92:b9:8d:00 status=0, tid=0, size=64
[ 34.191115] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x43, rate_bitmap:0x0fffffff
[ 34.191126] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x43, mask:0xffffffff
[ 34.191129] ==> rssi_level:2, rate_bitmap:0x0fffffff, psta->raid=1
[ 40.189278] RTL871X: rtw_set_ps_mode(wlan1) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 40.191019] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 42.035784] RTL871X: rtw_set_ps_mode(wlan1) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 42.035798] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 42.037456] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 42.104481] RTL871X: Drop duplicate management frame with seq_num = 2860.
[ 42.115963] RTL871X: Drop duplicate management frame with seq_num = 2861.
[ 42.439779] usb 1-6.3.1: USB disconnect, device number 4
[ 42.480974] wlan1: no IPv6 routers present
[ 43.163906] usb 1-6.3.1: new full-speed USB device number 7 using ehci_hcd
[ 43.275206] usb 1-6.3.1: New USB device found, idVendor=04e7, idProduct=0050
[ 43.275215] usb 1-6.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 43.275222] usb 1-6.3.1: Product: Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface
[ 43.275228] usb 1-6.3.1: Manufacturer: EloTouchSystems,Inc
[ 43.275234] usb 1-6.3.1: SerialNumber: 50U16779
[ 43.279962] input: EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface as /devices/pci0000:00/0000:00:1d.7/usb1/1-6/1-6.3/1-6.3.1/1-6.3.1:1.0/input/input12
[ 43.280613] generic-usb 0003:04E7:0050.0007: input,hidraw0: USB HID v1.00 Pointer [EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xffffffc2\xffffffae\xffffffae USB Touchmonitor Interface] on usb-0000:00:1d.7-6.3.1/input0
[ 43.825382] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 44.192873] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 44.225192] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 46.193299] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 46.224997] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 46.231982] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 46.883734] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 46.917430] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 46.919672] RTL871X: survey done event(36) band:0 for wlan1
[ 46.919689] RTL871X: rtw_indicate_scan_done(wlan1)
[ 48.191525] RTL871X: rtw_set_ps_mode(wlan1) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 48.191538] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 62.195343] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 81.969838] RTL871X: rtw_set_ps_mode(wlan1) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 81.969853] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 81.972176] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 83.664586] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 84.203662] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 84.238473] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 86.204334] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 86.236782] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 86.243890] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 86.659304] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 86.693116] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 86.695877] RTL871X: survey done event(1a) band:0 for wlan1
[ 86.696022] RTL871X: rtw_indicate_scan_done(wlan1)
[ 88.951407] RTL871X: rtw_issue_addbareq_cmd, p=0
[ 88.951447] RTL871X: BA_starting_seqctrl = 220 for TID=0
[ 88.951467] RTL871X: issue_addba_req(wlan1) ra=0c:9d:92:b9:8d:00 tid=0
[ 88.955378] RTL871X: OnAction_back
[ 88.955386] RTL871X: OnAction_back, action=1
[ 88.955391] RTL871X: agg_enable for TID=0
[ 98.205276] RTL871X: rtw_set_ps_mode(wlan1) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 98.205291] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 141.869010] RTL871X: rtw_set_ps_mode(wlan1) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 141.869025] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 141.875171] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 143.557351] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 144.220208] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 144.256267] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 146.220761] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 146.252212] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 146.259192] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 146.559926] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 146.593366] RTL871X: SetHwReg8812A(wlan1): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 146.595986] RTL871X: survey done event(31) band:0 for wlan1
[ 146.596017] RTL871X: rtw_indicate_scan_done(wlan1)
[ 148.218945] RTL871X: rtw_set_ps_mode(wlan1) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 148.218957] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 154.737735] I-pipe: head domain RTAI registered.
[ 154.737748] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 154.737889] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 154.737897] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8311870, CLK_FREQ 1862004000, CPU_FREQ 1862004000
[ 154.737904] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 154.737912] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8311870, 8311870, 8251500
[ 154.763714] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 154.763819] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 154.763830] RTAI[sched]: hard timer type/freq = APIC/8311870(Hz); default timing: oneshot; linear timed lists.
[ 154.763839] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1862004000 hz.
[ 154.763844] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 154.790020] RTAI[math]: loaded.
[ 155.066566] hm2: loading Mesa HostMot2 driver version 0.15
[ 155.071978] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 155.072069] hm2_pci: discovered 5i25 at 0000:03:00.0
[ 155.074327] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 155.131420] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 155.134333] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 155.136785] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 155.141105] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 155.146410] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 155.242309] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 155.244926] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 155.347560] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 155.347568] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 155.347574] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 155.347580] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 155.347588] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 155.347595] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 155.347603] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 155.347611] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 155.347618] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 155.347626] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 155.347633] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 155.347640] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 155.347648] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 155.347655] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 155.347662] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 155.347670] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 155.347677] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 155.347684] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 155.347691] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 155.347697] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 155.347702] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 155.347708] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 155.347714] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 155.347720] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 155.347725] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 155.347731] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 155.347737] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 155.347742] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 155.347748] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 155.347754] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 155.347760] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 155.347765] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 155.347771] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 155.347777] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 155.347783] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 155.348105] hm2/hm2_5i25.0: registered
[ 155.348110] hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
[ 155.355939] config string '0 out'
[ 156.021512] hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
[ 156.021528] hm2/hm2_5i25.0: unregistered
[ 156.021635] hm2_pci: driver unloaded
[ 156.025347] hm2: unloading
Last edit: 14 Mar 2019 13:52 by andypugh. Reason: Added code tags
13 Mar 2019 03:22 #128481
Replied by PCW on topic New Linuxcnc install, terminated with error
The actual error is this:
./my_LinuxCNC_machine.hal:366: Pin 'hm2_5i25.0.7i77.0.0.enc0.count' does not exist
This probably means that you do not have the 7I77 I/O section mode set properly (to 3) to enable the MPG encoders
What does your current
loadrt hm2_pci
line look like?
loadrt hm2_pci
line look like?
16 Mar 2019 08:18 #128711
by pl7i92
Replied by pl7i92 on topic New Linuxcnc install, terminated with error
@pcw
can yiou tell us beside the user not answering what it shoudt be look like as many viewers here
