linuxcnc-2.7-wheezy.iso actually distribution update errors
01 Apr 2019 15:58 - 01 Apr 2019 16:15 #130108
by partec
after installing with linuxcnc-2.7-wheezy.iso only the first part of updates can be downloaded as usual, but further updates fail, so we can not get and install "gedit" e.g.
Last edit: 01 Apr 2019 16:15 by partec.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
01 Apr 2019 19:42 #130116
by InMyDarkestHour
Replied by InMyDarkestHour on topic linuxcnc-2.7-wheezy.iso actually distribution update errors
Will need to see the errors and your sources file.
01 Apr 2019 20:35 - 02 Apr 2019 11:53 #130117
by partec
Replied by partec on topic linuxcnc-2.7-wheezy.iso actually distribution update errors
deb http.debian.net/debian wheezy main contrib non-free
deb-src http.debian.net/debian wheezy main contrib non-free
deb http.debian.net/debian wheezy-updates main contrib non-free
deb-src http.debian.net/debian wheezy-updates main contrib non-free
deb security.debian.org/ wheezy/updates main contrib non-free
deb-src security.debian.org/ wheezy/updates main contrib non-free
ping to server is ok but something in the mirror may be not good?
Last edit: 02 Apr 2019 11:53 by partec.
- InMyDarkestHour
- User is blocked
02 Apr 2019 04:48 #130131
by InMyDarkestHour
Your mirrors specifically "http.debian.net" are wrong.
Check this list out and make your choice.
www.debian.org/mirror/list
The following user(s) said Thank You: partec
02 Apr 2019 06:07 #130139
by pl7i92
Replied by pl7i92 on topic linuxcnc-2.7-wheezy.iso actually distribution update errors
if you do a new install consider to use Uspace
from here
www.linuxcnc.org/testing-stretch-rtpreempt/
from here
02 Apr 2019 07:13 #130143
by partec
thank you, it is good to know, know it is updating again without errors!
(from linuxcnc-2.7-wheezy.iso it was installed in january 2019 - the sources.list has been created automatically and until march 2019 it worked a lot of times without this errors)
02 Apr 2019 07:16 - 02 Apr 2019 12:09 #130144
by partec
thank you - next time I would like to try it out this way!
just done: Live/Install for Debian Stretch, RT-PREEMPT, LinuxCNC 2.7.x
www.linuxcnc.org/testing-stretch-rtpreem...uspace-amd64-r13.iso
works fine including use of samba
then installed CamPY for LinuxCNC - Camera Edge Finder
all works fine - also In the terminal when typed: qv4l2 opens a new window to test the camera.
but then makes error with script:
sudo python CamPY_setup.py
File "CamPY_setup.py", line 23, in <module>
import apt
ImportError: No module named apt
import apt
Last edit: 02 Apr 2019 12:09 by partec.
04 Apr 2019 16:46 #130296
by TKR
Replied by TKR on topic linuxcnc-2.7-wheezy.iso actually distribution update errors
Hi partec,
i am running into the same problem, my update manager is giving me errors as well (freshly installed linuxcnc). Is it possible for you to post your working sources.list as a starting point for changing it to the german mirrors?
That would be great!
I actually want to work with mesa cards and need the uspace package installed, which is making problems as long as the packages are not found...
i will certainly try the "prepackaged" uspace version, mentioned before!
Thanks a lot, have a great day,
Tobi
Tobi
05 Apr 2019 14:14 - 05 Apr 2019 14:33 #130340
by partec
Tobi, exactly as annoyingmutt wrote to us above, we can
check this list out and make our choice.
Also exactly as pl7i92 wrote to us above, it's fine to
do a new install under use Uspace from here
Last edit: 05 Apr 2019 14:33 by partec.
05 Apr 2019 15:04 #130342
by Glite
Replied by Glite on topic linuxcnc-2.7-wheezy.iso actually distribution update errors
Those mirrors don't have Wheezy as it was moved to archive mirror.
It's needed to change them to archive.debian.org/debian/
Still it only has wheezy, but not wheezy-updates and secuirty.
Time to create page: 0.171 seconds
