LCNC will not run without USB
- allenwg2005
- Topic Author
- Thank you received: 4
05 Apr 2019 16:59 #130355
by allenwg2005
LCNC will not run without USB was created by allenwg2005
Hi folks,
I installed LCNC on a new PC, I must have done something wrong.
When I try to start the PC now it will not boot, it states:
"Welcome to GRUB!
error: no such device xxxxxxxx"
If I put the USB in it will boot, what did I do wrong and how do I fix it?
Thanks in advance
"Welcome to GRUB!
Thanks in advance
- InMyDarkestHour
- User is blocked
- Thank you received: 111
05 Apr 2019 17:27 #130357
by InMyDarkestHour
Replied by InMyDarkestHour on topic LCNC will not run without USB
It sounds like you may have installed grub to the HDD (ssd) in the computer and installed Linuxcnc on the USB stick.
Easiest way is to start again and install Linuxcnc onto the HDD.
Your USB stick will be something like /dev/sdb and your HDD should be something like /dev/sda
The following user(s) said Thank You: allenwg2005
- allenwg2005
- Topic Author
05 Apr 2019 17:30 #130359
by allenwg2005
Replied by allenwg2005 on topic LCNC will not run without USB
Thanks, I got it up.
- InMyDarkestHour
- User is blocked
05 Apr 2019 17:34 #130361
by InMyDarkestHour
No probs....easy mistake to make
Time to create page: 0.065 seconds
