Installing from USB stick
- JohnBr00ker
- Topic Author
- Thank you received: 3
22 Apr 2019 01:45 #131448
by JohnBr00ker
Installing from USB stick was created by JohnBr00ker
Following the instructions on linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html, I've tried tree times.
It seems to install ok, but it doesn't detect my wireless network, so I select configure network later(or words to that effect).
I complete the process, but on rebooting it never recognises my password.
A comment I have read elsewhere, suggests that it will only work if I have a lan connection to the rest of my online system.
Is this correct, please?
going to get a very stiff drink.
22 Apr 2019 06:57 #131462
by pl7i92
Replied by pl7i92 on topic Installing from USB stick
NO
you can have a install without any Network at all and all mashine configs will work as you expect
the PASSWORD is the MAIN Thing on Linux
so choose a one you always remember
and do not Update to anything
the ISO is ready for 95% of all install mashines
- InMyDarkestHour
- User is blocked
- Thank you received: 111
22 Apr 2019 10:51 - 22 Apr 2019 10:58 #131489
by InMyDarkestHour
Replied by InMyDarkestHour on topic Installing from USB stick
The password problem you have is that the user password or the wifi password ?
Ok I'll need the exact make, model, pci id of your wireless adapter.
If can login with your user password from a terminal run
Additionallyand make a note of anything mentioning missing firmware
Usually no wifi is just a missing driver and or firmware
sudo lspci
Additionally
sudo dmesg
Last edit: 22 Apr 2019 10:58 by InMyDarkestHour.
- Thank you received: 5972
22 Apr 2019 12:38 #131496
Debian and it's derivatives use the "sudo" administration system that is more user friendly, so it does not use the root account in normal use.
Replied by tommylight on topic Installing from USB stick
If you are using the stretch or any other version of Debian, while installing when it asks for a ROOT password, do not enter anything ! Just move on and enter a password for the user you have created.I complete the process, but on rebooting it never recognises my password.
- JohnBr00ker
- Topic Author
22 Apr 2019 15:27 #131517
by JohnBr00ker
Replied by JohnBr00ker on topic Installing from USB stick
Thanks everyone for trying to help, but perhaps I need to start my questions in a simpler way.
The hdd of the Dell I am using has been formatted, so nothing on there.
I used www.linuxcnc.org/linuxcnc-2.7-wheezy.iso as a download using zsync, and copied onto my 8Gb memory stick .
I tried it as a live boot, and used it to do a latency test, which is good, <10,000 ns.
I then re-started and did a graphic install, and the only hiccup was it didn't recognise the wifi connection through my usb dongle, when it sid it couldn't detect a network, and I opted to set up the network later.
It asked for a password which I entered ( and yes, it's written down to make sure there was no mistake.)
It finished the installation, and when it re-booted, and asked for my password(nothing to do with the wifi), it didn't recognise it.
Note - when I entered it, and hit login, it cleared the password, so having waited some time, and nothing happened, I tried again. This time it told me it was an incorrect password.
This is where I am at the moment.
I'm now going off to Walmart to buy a lan line long enough to get from the garage to my router, and I'll go through the whole process again.
Unless, when I get back, someone has offered a solution.
Regards,
Regards,
22 Apr 2019 16:14 #131519
by tecno
Replied by tecno on topic Installing from USB stick
You must enter USER then PASSWORD
- JohnBr00ker
- Topic Author
22 Apr 2019 16:20 - 22 Apr 2019 16:22 #131521
by JohnBr00ker
Thank you for that clear and simple solution.
[Makes deep bow]
I hadn't spotted that the first request said "Login", then the second time it asked for a password.
Regards
I'm sure I'll find a use for a 25ft lan cable !
[Makes deep bow]
Regards
Last edit: 22 Apr 2019 16:22 by JohnBr00ker.
22 Apr 2019 16:23 #131523
by tecno
Been there - done that
- JohnBr00ker
- Topic Author
22 Apr 2019 18:34 - 22 Apr 2019 19:02 #131535
by JohnBr00ker
Final question here on this topic - reading the instructions on the link above in my post earlier today, is says in point 5, Updates to Linuxcnc " Warning Do not upgrade the operating system if prompted to do so."
Is this only during the installation process, and that I am able to update later, but not upgrade ?
EDIT
Too quick, I'm afraid.
Can't detect usb with lsusb - in terminal "command lsusb not found"
Can't install usbutils - no connection !
EDIT
Last edit: 22 Apr 2019 19:02 by JohnBr00ker.
- InMyDarkestHour
- User is blocked
22 Apr 2019 21:46 #131556
by InMyDarkestHour
You can run "apt-get update" & "apt-get dist-upgrade" (the safer option as opposed to upgrade) but you need configure you apt sources and adding a conf file.
So until you get a lan connection you can't install anything.
Does your M\B have a ethernet port ?
Time to create page: 0.144 seconds
