From Scratch
- Thank you received: 5972
23 Apr 2019 14:22 #131638
Replied by tommylight on topic From Scratch
There are some industrial plasma cutters that use 5i25 or 6i25 with a 7i77 i retrofitted. It will work with 7i76 also.
Keep in mind, shielding on signal and motor cables is connected only on one side, not both, the side nearest to sensitive electronics.
23 Apr 2019 14:24 #131639
by Firat
Replied by Firat on topic From Scratch
So 7i76e is enough to run a plasma ?
23 Apr 2019 14:42 #131643
by pl7i92
Replied by pl7i92 on topic From Scratch
you can run it on a 7i96 with full sucess
also on a simple 7i92 Mach3BOB
all will find your best
23 Apr 2019 14:54 #131650
by Firat
Friends I have already bought a 7i76e. I just ask if I need any other hardware beside it.
23 Apr 2019 15:22 #131654
Replied by rodw on topic From Scratch
Grab the Mesa THCAD board to read the voltage into LinuxCNC and you should be good to go. There are 2 versions. ONe for raw voltage 300 volt range and another THCAD-10 where you use some external resistors so you can scale to suit your needs. I have the THCAD-10 on a machine with a 30:1 voltage divider and also added some resistors as per the docs to run at raw arc voltaage which was presented on the CNC interface.
The Plasmac config is the way forward for sure. see the thread "Another Plasma Component"
23 Apr 2019 15:24 #131656
by Firat
Thank you very much rodw. I already bought THCAD-10 and 7i76e together. I would need your help prior to installation I guess.
24 Apr 2019 02:23 #131732
Rod and/or Norbert have posted very nice schematics for that exact wiring, just do a search for it.
The following user(s) said Thank You: Firat
Time to create page: 0.181 seconds
