Live CD download ?
09 Aug 2010 16:05 #3657
by cwebs
Live CD download ? was created by cwebs
Witch emc2 is now on the live cd download? I tried to upgrade my 2.3.5 to 2.4.3 and I can no longer start EMC2. I tried to revert back to 3.5 but have no option to. It is grayed out. I might have to do a compleat re install. I use EMC3 almost daily but have no knowlage of Linux . Thnaks for any help. Carl
09 Aug 2010 20:53 #3658
by robh
Replied by robh on topic Re:Live CD download ?
when you did an upgrade did you read the WiKi on the upgrade notes?
as a few things have changed you need to changei n the ini file.
see here for some info, might be the NML part you did not remove from the ini
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UPD...ween_2_3_x_and_2_4_x
like all version upgrades please read the notes before hand.
09 Aug 2010 21:21 #3659
by cwebs
Replied by cwebs on topic Re:Live CD download ?
Thank you for the answer. I did not see that info on the file change. I only saw the info to change the repositories to 3.4.
I hope that will help. Thanks Carl
10 Aug 2010 15:25 #3673
by cwebs
Thanks for the help. "remove the inifile line (NML_FILE = emc.nml.)" . Worked and saved me a lot of trouble. I hope the bug fixes takes care of a bug I have where the program just stops. The "Power" button goes to off. I found that if I click the button back on and then "resume from here" I can cut for a whie. Thanks again, Carl
10 Aug 2010 18:03 #3674
by robh
grate glad it fixed your error there.
as for the EMC bug if this still happens it would be best to jump on the IRC channel and have a chat with the devs there about it. if you can include your gcode file this would help alot in locating the problem and to see if it can be reproduced again on a different system.
rob
rob
18 Aug 2010 22:33 #3812
by ezboy
Replied by ezboy on topic Re:Live CD download ?
where can i download emc2?
18 Aug 2010 22:36 #3813
by BigJohnT
Replied by BigJohnT on topic Re:Live CD download ?
Here.
18 Aug 2010 23:16 #3814
by ezboy
(how) do i download emc2?
i can't find the botton to push.
