run EMC always as live-cd ( fully on ram )
- jonataapolinario
17 Aug 2010 18:13 #3794
by jonataapolinario
run EMC always as live-cd ( fully on ram ) was created by jonataapolinario
Hi All!
I would like to get the emc running fully on ram, like live-cd.
There is a way to do this?
i need it to be a secure way to do the machine, in a way that everything you do in the system will be erased at reboot, reducing the chanses of some errors, like file corruption, user manipulation, etc.
I need also to do the emc start directly, on boot, like a cnc only machine.
does anyone know if its possible?
18 Aug 2010 20:27 - 18 Aug 2010 20:29 #3810
by ulda
Replied by ulda on topic Re:run EMC always as live-cd ( fully on ram )
how much ram and time do you want to spare?
These are your options
1) use a solid state disk
2) put much ram in and use a small linux disstro, try to fit it with linux/rtai/emc2 and put it into a tar archive wich will be untarred into normal ram on boot
3) remaster the ubuntu-emc cdrom to do auto login into emc
4) use a normal harddisk install but mount root readonly and a tmpfs into /home and /tmp and untar a guest user before starting autologin (my favorite)
I hope this gives you a clue
/ulda
/ulda
Last edit: 18 Aug 2010 20:29 by ulda.
Time to create page: 0.164 seconds
